Audi A6 1991 - 1997 A6 Avant 4A 4A2 4A5 Workshop Manual​
File Size: 1.86 GB
Brand: Audi
Manual Type: Workshop Manual
Model: Audi A6 (1991 - 1997), including:
A6 Avant, 4A, 4A2, 4A5
Date: 1991 - 1997
00052505020 Electrical System
00052505120 Brake System
00052505220 Running Gear Front Wheel Drive And Four Wheel Drive
00052505320 General Body Repairs
00052505420 Heating Air Conditioner
00052505520 4 Cylinder Engine 2 Valve Mechanical Components
00052505620 5 Cylinder Engine 2 Valve Mechanical Components
00052505720 6 Cyl Injection Engine 2 Val Mechanical Components
00052505820 MPI Fuel Injection And Ignition System 6 Cyl 05 94
00052505920 KE III Jetronic Ignition System 5 Cylinder
00052506020 Mono Motronic Injection And Ignition System 4 Cyl 06 92
00052506120 5 Speed Manual Gearbox 012 01W Front Wheel Drive
00052506220 5 Speed Manual Gearbox 01A Four Wheel Drive
00052506320 Automatic Gearbox 097
00052506420 5 Cyl Diesel Engine Mechanical Components 2.4l Engine
00052506520 Diesel Direct Injection And Glow Plug System 2.4l Engine
00052506620 KE Motronic Injection And Ignition System 4 Cylinder
00052506720 5 Cyl Diesel Engine Mechanical Components 2.5l Engine
00052506820 Diesel Direct Injection And Glow Plug System TDI 5 Cylinder
00052506920 Motronic Fuel Injection And Ignition System 5 Cylinder
00052507020 5 Cylinder Engine 4 Valve Turbo Mechanics
00052507120 5 And 6 Speed Manual Gearbox 01E Front Wheel Drive
00052507220 Automatic Gearbox 01F 4WD
00052507320 Automatic Gearbox 01K Front Wheel Drive
00052507420 KE Motronic Injection And Ignition System 4 Valve
00052507520 MPFI Fuel Injection And Ignition System 6 Cyl
00052507620 6 Cyl Injection Engine 2 Val Mechanical Components AAH ABC ACZ AEJ
00052507820 K Jetronic TCI H Ignition System
00052507920 5 And 6 Speed Manual Gearbox 01E Four Wheel Drive
00052508020 Digifant Injection And Ignition System 4 Cyl
00052508120 Mono Motronic Injection And Ignition System 4 Cyl 07 92
00052508220 Motronic Injection And Ignition System 8 Cyl
00052508320 8 Cylinder Engine Mechanical Components
00052508420 Diesel Direct Injecton And Glow Plug System TDI 4 Cyl
00052508520 MPI Fuel Injection And Ignition System 6 Cyl 06 94
00052508620 Automatic Gearbox 01N
00052508720 Motronic Injection And Ignition System 4 Cyl
00052508820 Motronic Injection And Ignition System 6 Cylinder
00052508920 6 Cyl Engine 5 Valve Mechanical Components
00052509020 4 Cyl Diesel Direct Injection Engine TDI Mechanical Components
00052509120 4 Cyl Engine 5 Valve Mechanical Components
00052509220 Motronic Fuel Injection And Ignition System 8 Cyl
00052509320 Automatic Gearbox 01F And 01K Self Diagnosis
00052509820 Automatic Gearbox 018 Self Diagnosis
00052583020 Audi 100 1991
00052605020 Basic Equipment And 2.8l Fuel Injection Engine 128 kW Injection Control Unit 6 Cylinder Engine Codes AAH Model year 1997
00552515020 Booklet No 54 Audi 100 1991
A0050120020 General Information
A0052500120 Fuel Supply System Diesel Engines
A0052509420 Automatic Gearbox 01N Self Diagnosis
A0052509520 Automatic Gearbox 097 Self Diagnosis
A0052509620 Running Gear Self Diagnosis
A0052509720 Automatic Gearbox 018 Four Wheel Drive
A0052509920 Fuel Supply System Petrol Engines
A005AA00420 Electrical System General Information
A00ARRA0020 Wheels And Tyres
A195A620020 3.0l Petrol Engine DLZA From June 2018
D4B8036A18B Wheel Tyre Guide
D4B803D27C9 Servicing 7 Speed Dual Clutch Gearbox 0CJ 0CL 0CK 0DK 0DN 0DP 0HL
D4B80529C8E Rear Final Drive 0D2 0D3 0DB 0B0 0BX 0DG 0G2 09R
D4B80576B67 Servicing 4 Cylinder TDI Engine Common Rail EA288 Gen I
D4B805823A0 Servicing 4 Cylinder Engine 2.0 ltr 4 Valve TFSI EA888 Gen III B Cycle
D4B80593910 Servicing 6 Cylinder TDI Engine Common Rail EA897 Gen I
D4B80593999 Basic Information On High Voltage Vehicles
D4B8063201D Air Conditioners With Refrigerant R1234yf General Information
D4B80641D39 Servicing 6 Cylinder Engine 2.9 ltr 3.0 ltr 4 Valve TFSI EA839
D4B8065FFD6 Servicing 4 Cylinder Engine 2.0 ltr 4 Valve TFSI EA888 Gen III
D4B8067409D Servicing 6 Cylinder TDI Engine Common Rail EA897 Gen II
D4B8072D26D Servicing 8 Speed Automatic Gearbox
D4B807D25C6 Fuel Supply System
D4B807EDF7B Auxiliary Supplementary Heater
D4B807F52E8 Heating Air Conditioning
D4B807F531B General Body Repairs Seats
D4B807F5355 6 Cylinder TDI Engine 3.0 ltr 4 Valve Common Rail EA897 Gen II
D4B807F670A Brake System
D4B807FAEB3 7 Speed Dual Clutch Gearbox 0CJ 0CK 0HL 0DN 0DP
D4B807FAECC 6 Cylinder Direct Injection Engine 2.9 ltr 3.0 ltr 4 Valve TFSI EA839
D4B807FAEEB Running Gear Axles Steering
D4B807FDDD3 Communication
D4B807FDE06 Electrical System
D4B8080014C 8 Speed Automatic Gearbox 0D5
D4B808051B4 General Body Repairs Exterior
D4B8082883D General Body Repairs Interior
D4B8082887C Servicing 8 Cylinder Engine 4.0 ltr 4 Valve TFSI EA825
D4B808348C6 Maintenance
D4B808548FA Body Repairs
D4B80854B89 4 Cylinder Direct Injection Engine 2.0 ltr 4 Valve TFSI EA888 Gen III
D4B808575E7 Servicing 4 Cylinder TDI Engine Common Rail EA288 evo
D4B8085CC87 4 Cylinder TDI Engine 2.0 ltr 4 Valve Common Rail EA288 evo
D4B8089A267 Technical Data For Engines
D4B808EC56E 4 Cylinder Direct Injection Engine 2.0 ltr 4 Valve TFSI EA888 Gen III B Cycle
D4B808FDB2A 6 Cylinder TDI Engine 3.0 ltr 4 Valve Common Rail EA897 Gen II S6 S7
D4B8091CE04 Driver Assist Systems
D4B809353C8 6 Cylinder TDI Engine 3.0 ltr 4 Valve Common Rail EA897 Gen I
D4B80939645 7 Speed Dual Clutch Gearbox 0DK
D4B8093F438 Wheel Tyre Guide
D4B809AE669 8 Cylinder Direct Injection Engine 4.0 ltr 4 Valve TFSI EA825
D4B809C0A9B 8 Speed Automatic Gearbox 0D6
D4B80A3F26C 4 Cylinder Direct Injection Engine 2.0 ltr 4 Valve TFSI EA888 evo4
D4B80A4533A 4 Cylinder TDI Engine 2.0 ltr 4 Valve Common Rail EA288 Gen I
D4B80A8313E 6 Cylinder TDI Engine 3.0 ltr 4 Valve Common Rail EA897 Gen III
D4D807C6C39 6 Cylinder TDI Engine 3.0 ltr 4 Valve Common Rail EA 897Gen III S4 S5 S6 S7 SQ5
D4D80993FB0 Safety And Repair Instructions
  • Audi A6 1991 - 1997 A6 Avant 4A 4A2 4A5 Workshop Manual.txt
