Audi A5 RS5 Coupé 2008 - 2016 8T 8T3 8TA Workshop Manual and Wiring Diagram
Format: PDFTotal Size: 514.82 MB
Brand: Audi
Model: Audi A5 RS5 Coupé (Type 8T, 8T3, 8TA)
Publication Date: 2008 - 2016
- Workshop Manual and Wiring Diagram
List of files:
A005A400320 Direct petrol injection and ignition system (4 cyl 1.8 ltr 4 valve turbo with timing chain)
A005A400520 6 cylinder TDI engine (2.7 ltr 3 0 ltr 4 valve common rail)
A005A400620 Fuel supply system diesel engines
A005A400720 Fuel supply system petrol engines
A005A400820 6 cylinder direct petrol injection engine (3.2 ltr 4 valve)
A005A400920 System description adaptive cruise control
A005A401320 4 cylinder TDI engine (2 0 ltr 4 valve common rail)
A005A401720 4 cylinder direct injection engine (1 8 2 0 ltr 4 valve TFSI generation II)
A005A402020 TDI injection and glow plug system (4 cyl 2 0 ltr 4 valve common rail)
A005A402320 6 speed manual gearbox 0B1 front wheel drive
A005A402420 Running gear axles steering
A005A402720 6 speed manual gearbox 0B4 four wheel drive
A005A402820 6 speed manual gearbox 0B2 four wheel drive
A005A402920 System description lane change assist (Audi side assist)
A005A403020 multitronic 0AW front wheel drive
A005A403420 System description lane departure warning (Audi lane assist)
A005A403520 Direct petrol injection and ignition system (4 cyl 2 0 ltr 4 valve turbo with timing chain)
A005A403620 6 speed manual gearbox 0B3 front wheel drive
A005A403720 Simos direct petrol injection and ignition system (6 cyl 3 0 ltr TFSI 4 valve)
A005A403820 7 speed dual clutch gearbox 0B5 (S tronic)
A005A500120 Heating air conditioning
A005A500220 Auxiliary heater supplementary heater
A005A500320 TDI injection and glow plug system (6 cyl 2 7 ltr 3 0 ltr 4 valve common rail)
A005A500420 Direct petrol injection and ignition system (8 cyl 4.2 ltr 4 valve)
A005A500520 System description infotainment and navigation system
A005A500620 System description infotainment and audio output (MOST)
A005A500720 System description Extended service interval
A005A500820 System description exterior lights
A005A500920 System description wiper and washer systems
A005A501020 Running gear front wheel drive and four wheel drive
A005A501120 System description entry and start authorisation
A005A501220 System description Running gear steering wheel
A005A501320 System description Windows and doors
A005A501420 System description Exterior mirrors
A005A501520 Electrical system
A005A501620 Communication
A005A501720 Brake system
A005A502420 8 cylinder direct injection engine (4.2 ltr 4 valve)
A005A502620 System description interior lights
A005A502720 Rear final drive 0BC 0BD 0BE 0BF
A005A502820 Rear final drive 0BD
A005A502920 Simos direct petrol injection and ignition system (6 cyl 3.2 ltr 4 valve)
A005A503420 Direct petrol injection and ignition system (4 cyl 1.8 ltr 4 valve turbo with timing chain)
A005A503520 Automatic gearbox 0B6 four wheel drive
A005A503820 Fitting instructions Filling roof side member with foam
A005A520020 Basic equipment From June 2007
A008TKI0120 Body Repairs
A00ARRA0020 Wheels and tyres
A00IGA50220 Maintenance
D3E801AA929 Rear final drive 0BF and 0BE sport differential
D3E801B23C3 6 cylinder direct injection engine with supercharger (3 0 ltr 4 valve TFSI)
D3E8020C619 General body repairs interior
D3E8021B228 General body repairs exterior
D3E80220B4A Servicing 6 speed manual gearbox 0B1 front wheel drive
D3E802237D6 Servicing 6 speed manual gearbox 0B2 four wheel drive
D3E8024D043 Direct petrol injection and ignition system (8 cyl 4.2 ltr 4 valve) RS 4 RS 5
D3E80253497 Servicing 6 speed manual gearbox 0B4 four wheel drive
D3E80258C5F 8 cylinder direct injection engine (4.2 ltr 4 valve RS 4 RS 5)
D3E80265C83 Servicing 6 speed manual gearbox 0B3 front wheel drive
D3E8033D012 Servicing multitronic 0AW
D3E8033D040 4 cylinder TDI engine (2 0 ltr 4 valve common rail generation II)
D3E80349A2E TDI injection and glow plug system (4 cyl 2 0 ltr 4 valve common rail generation II)
D3E803F5263 6 cylinder TDI engine (3 0 ltr 4 valve common rail generation II)
D3E803F744A TDI injection and glow plug system (6 cyl 3 0 ltr 4 valve common rail generation II)
D3E80415784 Direct injection and ignition system (4 cyl 1.8 ltr 2 0 ltr 4 valve turbo generation III)
D3E80428DD0 4 cylinder direct injection engine (1 8 2 0 ltr 4 valve TFSI generation III)
D3E80439E38 Servicing 7 speed dual clutch gearbox 0B5 (S tronic)
D4B802C0B14 8 speed automatic gearbox 0BK four wheel drive
D4B8036A195 Wheel Tyre Guide
D4B8038B340 4 cylinder TDI engine 2 0 ltr 4 valve common rail (EA 288 Gen I)
D4B8043D074 6 cylinder direct injection engine with supercharger (3 0 ltr 4 valve TFSI EA837evo)
D4B804EA6B2 Specifications for testing the braking force (according to German legislation)
D4B805AB6B6 Technical data for petrol engines
D4B805ADD42 Technical data for diesel engines
D4B8063201D Air conditioners with refrigerant R1234yf General information
D4B8065FFD6 Servicing 4 cylinder engine 2 0 ltr 4 valve TFSI (EA 888 Gen III)
D4B806E8263 Maintenance
D4B8072D26D Servicing 8 speed automatic gearbox
D4B807499F5 Servicing 4 cylinder engine 1.8 ltr 2 0 ltr 4 valve TFSI (EA 888 Gen II)
