Audi A4 S4 RS4 Avant 2001 - 2008 8E 8E2 8E5 8EC 8ED Workshop Manual and Wiring Diagram
Format: PDFTotal Size: 334.56 MB
Brand: Audi
Model: Audi A4 S4 RS4 Avant (8E, 8E2, 8E5, 8EC, 8ED)
Publication Date: 2001 - 2008
- Workshop Manual
- Wiring Diagram
List of files:
001EBA00020 Fitting instructions retrofitting key operated switch to deactivate airbag on front passenger side
00252167220 Fitting instruction
A0054000120 Removing and installing air mass meter
A0059005020 General body repairs exterior
A0059005120 General body repairs interior
A0059005220 Running gear front wheel drive and four wheel drive
A0059005320 Brake system
A0059005420 6 cylinder diesel direct injection engine (TDI) mechanics
A0059005620 5 speed manual gearbox 012 01W 0A9 front wheel drive
A0059005720 6 speed manual gearbox 01E four wheel drive
A0059005920 Air conditioning
A0059006020 multitronic 01J front wheel drive
A0059006120 Fuel supply system diesel engines
A0059006220 Fuel supply system petrol engines
A0059006320 6 cylinder engine (3 0 ltr 5V) mechanics
A0059006520 Electrical system
A0059006620 Communication
A0059006720 Motronic injection and ignition system (4 cylinder)
A0059006820 Motronic injection and ignition system (4 cyl turbo)
A0059006920 Simos injection and ignition system (4 cyl )
A0059007020 5 speed manual gearbox 01A four wheel drive
A0059007120 4 cylinder engine (5 valve turbo) mechanics
A0059007220 4 cylinder TDI unit injector engine (1.9 ltr 2 0 ltr 2 valve) mechanics
A0059007320 TDI injection and glow plug system (4 cyl 1.9 ltr 2 0 ltr unit injector 2 valve)
A0059007420 TDI injection and glow plug system (6 cyl )
A0059007520 Automatic gearbox 01V front wheel drive and four wheel drive
A0059007620 4 cylinder engine (2 valve) Mechanics
A0059007720 Bodywork Self diagnosis
A0059009020 4 cylinder direct petrol injection engine (2 0 ltr 4 valve) mechanics
A0059009120 Motronic Direct Injection and Ignition System (4 Cyl )
A0059009320 8 cylinder engine (4.2 ltr 5 valve with timing chains) mechanics
A0059009420 Motronic injection and ignition system (8 cyl )
A0059009620 Automatic gearbox 09L four wheel drive
A0059015020 Maintenance
A0059020020 Basic equipment Lowline from model year 2001
A0059118920 Heating
A0059148920 6 speed manual gearbox 01E 0A1 front wheel drive
A0059152920 6 cylinder engine mechanics
A0059165920 Auxiliary heater
A0059175920 6 speed manual gearbox 0A3 four wheel drive
A0059182920 6 speed manual gearbox 02X four wheel drive
A0059185920 6 speed manual gearbox 01X front wheel drive
A0059188920 6 speed manual gearbox 0A2 front wheel drive
A0059192920 TDI injection and glow plug system (4 cyl 2 0 ltr unit injector 4 valve)
A0059195920 4 cylinder TDI unit injector engine (2 0 ltr 4 valve) mechanics
A0059198920 6 cylinder TDI engine (2.7 ltr 3 0 ltr 4 valve common rail) mechanics
A0059200020 2 0 litre fuel injection engine (96 kW Motronic 4 cylinder) engine code ALT From model year 2003
A0059202920 TDI injection and glow plug system (6 cyl 2 7 ltr 3 0 ltr 4 valve common rail)
A0059205920 Direct petrol injection and ignition system (4 cyl 2 0 ltr 4 valve turbo)
A0059215920 4 cylinder direct petrol injection engine (2 0 ltr 4 valve turbo) mechanics
A0059218920 6 cylinder direct petrol injection engine (3.2 ltr 4 valve) mechanics
A0059222920 Simos direct petrol injection and ignition system (6 cyl 3.2 ltr 4 valve)
A0059228920 8 cylinder direct petrol injection engine (4.2 ltr 4 valve RS 4) mechanics
A0059232920 Direct petrol injection and ignition system (8 cyl 4.2 ltr 4 valve) RS 4
A0059235920 multitronic 0AN front wheel drive
A005A600920 Rear final drive 01R
A005AA00120 Rear final drive 0AR
A005AA00220 Rear final drive 08V
A005AI00220 Servicing multitronic 01J and 0AN
A005AI00320 Servicing automatic gearbox 01V front wheel drive and four wheel drive
A005AI00420 Servicing 6 speed manual gearbox 0A3 four wheel drive
A005AI00520 Servicing 6 speed manual gearbox 0A2 front wheel drive
A008EKI0120 Body Repairs
A00ARRA0020 Wheels and tyres
A0259112920 4 cylinder engine (2 valve) mechanics
A0359042920 4 cylinder engine (2 0 ltr 5 valve) mechanics
D3E802E5B95 Motronic injection and ignition system (4 cylinder turbo)
D3E8049058D Servicing automatic gearbox 09L four wheel drive
D4B805AB668 Technical data for engines
