Audi A4 S4 RS4 Avant 1995 - 2002 8D 8D2 8D5 Workshop Manual and Wiring Diagram
Format: PDFTotal Size: 275.24 MB
Brand: Audi
Model: Audi A4 S4 RS4 Avant (8D, 8D2, 8D5)
Publication Date: 1995 - 2002
- Workshop Manual
- Wiring Diagram
List of files:
00055005020 Electrical system self diagnosis
00055005120 4 cylinder Diesel Direct Injection Engine (TDI) Mechanics
00055005220 Automatic gearbox 01N
00055005320 Automatic Gearbox 01VFWD and 4WD
00055005420 4 Cylinder engine (2 valve) Mechanics
00055005520 #Diesel direct injection and glow #plug system (4 cyl )> 06 97
00055005620 MPI fuel injection and ignition system
00055005720 MPFI Fuel Injection and Ignition System
00055005820 Motronic Injection and Ignition System (4 cyl )> 06 96
00055005920 Running gear Front wheel drive and four wheel drive
00055006020 Heating Air Conditioner
00055006120 5 Speed Manual Gearbox 012 01W Front wheel Drive
00055006220 5 Speed Manual Gearbox 01A (4WD)
00055006320 6 cylinder Engine (2 valve) Mechanics
00055006420 General Body Assembly Interior (Repair groups 68 69 70 72 74)
00055006520 Motronic injection and ignition system (6 cylinder)
00055006620 6 cylinder engine (5 valve) mechanics
00055006720 Simos injection and ignition system (4 cylinder)
00055006820 4 cylinder engine (2 valve) mechanics
00055006920 Motronic fuel injection and ignition system (4 cyl turbo) > 07 96
00055007020 Motronic Fuel Injection and ignition system (4 cyl ) 07 96ä
00055007120 Running Gear Self diagnosis for ABS ESP
00055007220 Motronic Fuel Injection and Ignition System (6 cyl Turbo)
00055007320 6 Cylinder engine (5 valve turbo) Mechanics
00055007420 6 speed manual gearbox 01E Four wheel drive
00055007520 Motronic Injection and Ignition System (6 cylinder)
00055007620 4 cylinder engine (1.8 ltr 5 valve turbo) mechanics
00055007720 4 Cylinder engine (5 valve) Mechanics
00055007820 Brake System
00055007920 Radio Telephone and Navigation System
00055008020 Automatic gearbox 01N Self diagnosis
00055008120 Fuel supply system Petrol engines
00055008220 6 cylinder diesel direct injection engine (TDI) mechanics
00055008320 5 & 6 Speed manual gearbox 01E Front wheel drive
00055008420 TDI injection and glow plug system (6 cyl )
00055008520 Body Self diagnosis
00055008620 Fuel supply system Diesel engines
00055008720 TDI Injection and Glow Plug System (4 cyl ) 07 97 > 07 99
00055008820 General Body Assembly
00055009220 Motronic injection and ignition system (4 cyl )
00055009320 Motronic injection and ignition system (6 cylinder)
00055009420 Motronic fuel injection and ignition system (6 cyl )
00055009520 Automatic Gearbox 01V Self diagnosis
00055009620 Motronic injection and ignition system (4 cyl turbo)
00055009720 TDI® diesel direct injection and glow plug system (4 cyl unit injector)
00055009820 Simos injection and ignition system (4 cylinder)
00055009920 TDI diesel injection and glow plug system (4 cyl ) 08 99 ä
00055020020 Audi A4 (2 8 litre fuel injection engine 128 kW multi point injection 6 cylinder) engine code AAH From November 1994
00055200020-Audi_A4_(2_4_l_fuel_injection_engine__121_kW__Motronic_(5_valve)__6-cylinders)__engine_codes_AGA__From_model_year_1998__▸_8D-X-200000
00055210020-Basic_equipment__From_model_year_2000
001EBA00020-Fitting_instructions__retrofitting_key-operated_switch_to_deactivate_airbag_on_front_passenger_side
001KAH00020-Body_Repairs__General_Body_Repairs(1)
00252167220-Fitting_instruction
00255015020-Maintenance
00355025920-Electrical_system
A0053300220-Air_conditioner_with_refrigerant_R134a
A0054000120-Removing_and_installing_air_mass_meter
A0055010020-4-Cyl__TDI®Engine__Mechanics
A0055010120-Motronic_injection_and_ignition_system_(6_cyl__turbo)
A0055010220-6-cylinder_engine__2_7_ltr__5-valve_turbo_(RS 4)__mechanics
A0055010320-Motronic_Fuel_Injection_and_Ignition_System_(6-cylinder)
A0055010420-4-cylinder_engine_(5-valve_turbo)__mechanics
A0055208920-Motronic_Fuel_Injection_and_Ignition_System_(4-cyl)_Turbo
A0055215920-Radio__Telephone_and_Navigation_System_-_Self-diagnosis
A005AI00320-Servicing_automatic_gearbox_01V__front-wheel_drive_and_four-wheel_drive
A008DKI0120-Body_repairs
A00ARRA0020-Wheels_and_tyres
A0255212920-4-cylinder_engine_(2-valve__roller_rocker_fingers)__mechanics
D3E804905D7-5-speed_manual_gearbox_012_01W__front-wheel_drive
D3E8049704D-5_and_6-speed_manual_gearbox_01E__front-wheel_drive
D3E804A8B9E-5-speed_manual_gearbox_01A__four-wheel_drive
