Audi A4 RS4 S4 2001 - 2008 A4 RS4 S4 Avant 8E 8E2 8E5 8EC 8ED Workshop Manual and Wiring Diagram
Format: PDFTotal Size: 223.79 MB
Brand: Audi
Model: Audi A4, RS4, S4 Avant (8E, 8E2, 8E5, 8EC, 8ED)
Date: 2001 - 2008
Manual Type: Repair Manual, Service Manual, Workshop Manual, and Wiring Diagram
Number of Pages: 14,329 Pages
2.0 litre fuel injection engine (96 kW Motronic 4-cylinder) engine code ALT From model year 2003
4-cylinder direct petrol injection engine (2.0 ltr 4-valve) mechanics
4-cylinder direct petrol injection engine (2.0 ltr 4-valve turbo) mechanics
4-cylinder engine (2.0 ltr 5-valve) mechanics
4-cylinder engine (2-valve) Mechanics1
4-cylinder engine (2-valve) mechanics2
4-cylinder engine (5-valve turbo) mechanics
4-cylinder TDI unit injector engine (1.9 ltr 2.0 ltr 2-valve) mechanics
4-cylinder TDI unit injector engine (2.0 ltr 4-valve) mechanics
5-speed manual gearbox 01A four-wheel drive
5-speed manual gearbox 012 01W 0A9 front-wheel drive
6-cylinder diesel direct injection engine (TDI) mechanics
6-cylinder direct petrol injection engine (3.2 ltr 4-valve) mechanics
6-cylinder engine (3.0 ltr 5V) mechanics
6-cylinder engine mechanics
6-cylinder TDI engine (2.7 ltr 3.0 ltr 4-valve common rail) mechanics
6-speed manual gearbox 0A2 front-wheel drive
6-speed manual gearbox 0A3 four-wheel drive
6-speed manual gearbox 01E 0A1 front-wheel drive
6-speed manual gearbox 01E four-wheel drive
-6-speed manual gearbox 01X front-wheel drive
6-speed manual gearbox 02X four-wheel drive
8-cylinder direct petrol injection engine (4.2 ltr 4-valve RS 4) mechanics
8-cylinder engine (4.2 ltr 5-valve with timing chains) mechanics
Air conditioner with refrigerant R134a
Air conditioning
Automatic gearbox 01V front-wheel drive and four-wheel drive
Automatic gearbox 09L four-wheel drive
Auxiliary heater
Basic equipment Lowline from model year 2001
Body Repairs
Body Repairs General Body Repairs
Bodywork Self-diagnosis
Brake system
Communication
Direct petrol injection and ignition system (4-cyl 2.0 ltr 4-valve turbo)
Direct petrol injection and ignition system (8-cyl 4.2 ltr 4-valve) RS 4
Electrical system General information
Fitting instruction
Fitting instructions radio communication systems
Fitting instructions retrofitting key-operated switch to deactivate airbag on front passenger side
Fuel supply system diesel engines
Fuel supply system petrol engines
General body repairs exterior
General body repairs interior
Heating
Maintenance
Motronic Direct Injection and Ignition System (4-Cyl)
Motronic injection and ignition system (4-cyl turbo)
Motronic injection and ignition system (4-cylinder)
Motronic injection and ignition system (4-cylinder turbo)
Motronic injection and ignition system (8-cyl)
multitronic 0AN front-wheel drive
multitronic 01J front-wheel drive
Rear final drive 0AR
Rear final drive 01R
Rear final drive 08V
Removing and installing air mass meter
Running gear front-wheel drive and four-wheel drive
Servicing 6-speed manual gearbox 0A2 front-wheel drive
Servicing 6-speed manual gearbox 0A3 four-wheel drive
Servicing automatic gearbox 01V front-wheel drive and four-wheel drive
Servicing automatic gearbox 09L four-wheel drive
Servicing multitronic 01J and 0AN
Simos direct petrol injection and ignition system (6-cyl 3.2 ltr 4-valve)
Simos injection and ignition system (4-cyl)
TDI injection and glow plug system (4-cyl 1.9 ltr 2.0 ltr unit injector 2-valve)
TDI injection and glow plug system (4-cyl 2.0 ltr unit injector 4-valve)
TDI injection and glow plug system (6-cyl)
TDI injection and glow plug system (6-cyl 2.7 ltr 3.0 ltr 4-valve common rail)
Technical data for engines
Wheels and tyres
