Audi A4 and Allroad 2015 - 2020 8W 8W2 8W5 8WH Workshop Manual and Wiring Diagram
File Size: 776.23 MBFile Format: PDF
Brand: Audi
Manual Type: Workshop Manual and Wiring Diagram
Model: Audi A4 and Allroad 2015 - 2020 type 8W, 8W2, 8W5, 8WH
Date: 2015 - 2020
List of files:
Our policies and instructions: https://dhtauto.com/dht/threads/rules-when-using-the-forum-update-to-03-01-2022.90280/001KAH00020 Body Repairs General Body Repairs
A0058W20020 Basic equipment (L0L) From July 2015
A00ARRA0020 Wheels and tyres
D4B8036A199 Wheel Tyre Guide
D4B803D27C9 Servicing 7 speed dual clutch gearbox 0CJ 0CL 0CK 0DN 0DP 0HL
D4B804EA6B2 Specifications for testing the braking force (according to German legislation)
D4B80529C8E Rear final drive 0D2 0D3 0DB 0B0 0BX 0DG 0G2 09R
D4B8056E0C8 Servicing 6 speed manual gearbox 0CS 0DJ 0CX
D4B80576B67 Servicing 4 cylinder TDI engine common rail (EA 288 Gen I)
D4B805823A0 Servicing 4 cylinder engine 2 0 ltr 4 valve TFSI (EA 888 Gen III B cycle)
D4B80585975 Brake system
D4B80585990 General body repairs interior
D4B8058AFF9 Fuel supply system
D4B8058B01D Heating air conditioning
D4B8058BF1E 6 cylinder TDI engine 3 0 ltr 4 valve common rail (EA 897 Gen I)
D4B8058D863 Body Repairs
D4B8058D90C 4 cylinder TDI engine 2 0 ltr 4 valve common rail (EA 288 Gen I)
D4B8058D921 8 speed automatic gearbox 0D5
D4B8058F4E5 Maintenance
D4B8058F64B Auxiliary supplementary heater
D4B8059029F 6 speed manual gearbox 0CS 0DJ 0CX
D4B80593892 General body repairs exterior
D4B805938BF 4 cylinder direct injection engine (1.4 ltr 4 valve TFSI EA211)
D4B80593910 Servicing 6 cylinder TDI engine common rail (EA 897 Gen I)
D4B8059399A Communication
D4B8059399E Electrical system
D4B80595B99 4 cylinder direct injection engine (2 0 ltr 4 valve TFSI EA 888 Gen III B cycle)
D4B80597318 7 speed dual clutch gearbox 0CJ 0CK 0CL 0DN 0DP
D4B80597353 4 cylinder direct injection engine (2 0 ltr 4 valve TFSI EA 888 Gen III)
D4B805A9193 Running gear axles steering
D4B805AB65B Technical data for engines
D4B8063201D Air conditioners with refrigerant R1234yf General information
D4B8063F1EB 6 cylinder direct injection engine (2.9 ltr 3 0 ltr 4 valve TFSI EA 839)
D4B80641D39 Servicing 6 cylinder engine 2.9 ltr 3 0 ltr 4 valve TFSI EA 839
D4B8065FFD6 Servicing 4 cylinder engine 2 0 ltr 4 valve TFSI (EA 888 Gen III)
D4B8067409D Servicing 6 cylinder TDI engine common rail (EA 897 Gen II)
D4B80674178 6 cylinder TDI engine 3 0 ltr 4 valve common rail (EA 897 Gen II)
D4B806878F3 Brake system
D4B806E4CA8 Maintenance
D4B806FF7C8 Natural gas engines General information
D4B80719E20 Fuel supply system g tron
D4B8072D26D Servicing 8 speed automatic gearbox
D4B808575E7 Servicing 4 cylinder TDI engine common rail (EA 288 EVO)
D4B80884A1F 4 cylinder TDI engine 2 0 ltr 4 valve common rail (EA 288 EVO)
D4B80900E6E 6 cylinder TDI engine 3 0 ltr 4 valve common rail (EA 897 Gen II S4 S5)
