Audi A4 A5 S5 RS5 2008 - 2016 A4 A5 S5 RS5 8T 8T3 8TA Workshop Manual and Wiring Diagram
Format: PDFTotal Size: 294.62 MB
Brand: Audi
Model: Audi A4, A5, S5, RS5 (8T, 8T3, 8TA)
Date: 2008 - 2016
Manual Type: Repair Manual, Service Manual, Workshop Manual, and Wiring Diagram
Number of Pages: 16,119 Pages
4-cylinder direct injection engine (1.8 2.0 ltr 4-valve generation II)
4-cylinder direct injection engine (1.8 2.0 ltr 4-valve TFSI generation III)
4-cylinder TDI engine (2.0 ltr 4-valve common rail)
4-cylinder TDI engine (2.0 ltr 4-valve common rail generation II)
4-cylinder TDI engine 2.0 ltr 4-valve common rail (EA 288 Gen I)
6-cylinder direct injection engine (evo) with supercharger (3.0 ltr 4-valve TFSI)
6-cylinder direct injection engine with supercharger (3.0 ltr 4-valve TFSI)
6-cylinder direct petrol injection engine (3.2 ltr 4-valve)
6-cylinder TDI engine (2.7 ltr 3.0 ltr 4-valve common rail)
6-cylinder TDI engine (3.0 ltr 4-valve common rail generation II)
6-speed manual gearbox 0B1 front-wheel drive
6-speed manual gearbox 0B2 four-wheel drive
6-speed manual gearbox 0B3 front-wheel drive
6-speed manual gearbox 0B4 four-wheel drive
7-speed dual clutch gearbox 0B5 (S tronic)
8-cylinder direct injection engine (4.2 ltr 4-valve)
8-cylinder direct injection engine (4.2 ltr 4-valve RS 4 RS 5)
8-speed automatic gearbox 0BK four-wheel drive
Air conditioner with refrigerant R134a
Air conditioners with refrigerant R1234yf General information
Automatic gearbox 0B6 four-wheel drive
Auxiliary heater supplementary heater
Basic equipment From June 2007
Body Repairs
Body Repairs General Body Repairs
Brake system
Communication
Direct injection and ignition system (4-cyl 1.8 ltr 2.0 ltr 4-valve turbo generation III)
Direct petrol injection and ignition system (4-cyl 1.8 ltr 4-valve turbo with timing chain)1
Direct petrol injection and ignition system (4-cyl 1.8 ltr 4-valve turbo with timing chain)2
Direct petrol injection and ignition system (4-cyl 2.0 ltr 4-valve turbo with timing chain)
Direct petrol injection and ignition system (8-cyl 4.2 ltr 4-valve)
Direct petrol injection and ignition system (8-cyl 4.2 ltr 4-valve) RS 4 RS 5
Electrical system General information
Fitting instructions Filling roof side member with foam
Fitting instructions radio communication systems
Fuel supply system diesel engines
Fuel supply system petrol engines
General body repairs exterior
General body repairs interior
Heating air conditioning
Maintenance
Multitronic 0AW front-wheel drive
Rear final drive 0BC 0BD 0BE 0BF
Rear final drive 0BD
Rear final drive 0BF and 0BE sport differential
Running gear axles steering
Running gear front-wheel drive and four-wheel drive
Servicing 6-speed manual gearbox 0B1 front-wheel drive
Servicing 6-speed manual gearbox 0B2 four-wheel drive
Servicing 6-speed manual gearbox 0B3 front-wheel drive
Servicing 6-speed manual gearbox 0B4 four-wheel drive
Servicing 7-speed dual clutch gearbox 0B5 (S tronic)
Servicing multitronic 0AW
Simos direct petrol injection and ignition system (6-cyl 3.0 ltr TFSI 4-valve)
Simos direct petrol injection and ignition system (6-cyl 3.2 ltr 4-valve)
Specifications for testing the braking force (according to German legislation)
System description adaptive cruise control
System description entry and start authorisation
System description Extended service interval
System description exterior lights
System description Exterior mirrors
System description infotainment and audio output (MOST)
System description infotainment and navigation system
System description interior lights
System description lane change assist (Audi side assist)
System description lane departure warning (Audi lane assist)
System description Running gear steering wheel
System description Windows and doors
System description wiper and washer systems
TDI injection and glow plug system (4-cyl 2.0 ltr 4-valve common rail generation II)
TDI injection and glow plug system (4-cyl 2.0 ltr 4-valve common rail)
TDI injection and glow plug system (6-cyl 2.7 ltr 3.0 ltr 4-valve common rail)
TDI injection and glow plug system (6-cyl 3.0 ltr 4-valve common rail generation II)
Technical data for diesel engines
Technical data for petrol engines
Trailer Operation Guide
Wheel Tyre Guide
Wheels and tyres
