Audi A4 1995 - 2002 A4 Avant 8D 8D2 8D5 Workshop Manual​
File Size: 304 MB
Brand: Audi
Manual Type: Workshop Manual
Model: Audi A4 (1995 - 2002), including:
A4 Avant, 8D, 8D2, 8D5
Date: 1995 - 2002
00055005020 Electrical System Self Diagnosis
00055005120 4 Cylinder Diesel Direct Injection Engine TDI Mechanics
00055005220 Automatic Gearbox 01N
00055005320 Automatic Gearbox 01VFWD And 4WD
00055005420 4 Cylinder Engine 2 Valve Mechanics
00055005520 Diesel Direct Injection And Glow Plug System 4 Cyl &gt 06 97
00055005620 MPI Fuel Injection And Ignition System
00055005720 MPFI Fuel Injection and Ignition System
00055005820 Motronic Injection And Ignition System 4 Cyl &gt 06 96
00055005920 Running Gear Front Wheel Drive And Four Wheel Drive
00055006020 Heating Air Conditioner
00055006120 5 Speed Manual Gearbox 012 01W Front wheel Drive
00055006220 5 Speed Manual Gearbox 01A 4WD
00055006320 6 Cylinder Engine 2 Valve Mechanics
00055006420 General Body Assembly Interior Repair Groups 68 69 70 72 74
00055006520 Motronic Injection And Ignition System 6 Cylinder
00055006620 6 Cylinder Engine 5 Valve Mechanics
00055006720 Simos Injection And Ignition System 4 Cylinder
00055006820 4 Cylinder Engine 2 Valve Mechanics
00055006920 Motronic Fuel Injection And Ignition System 4 Cyl Turbo &gt 07 96
00055007020 Motronic Fuel Injection And Ignition System 4 Cyl 07 96
00055007120 Running Gear Self Diagnosis For ABS ESP
00055007220 Motronic Fuel Injection And Ignition System 6 Cyl Turbo
00055007320 6 Cylinder Engine 5 Valve Turbo Mechanics
00055007420 6 Speed Manual Gearbox 01E Four Wheel Drive
00055007520 Motronic Injection And Ignition System 6 Cylinder
00055007620 4 Cylinder Engine 1.8 ltr 5 Valve Turbo Mechanics
00055007720 4 Cylinder Engine 5 Valve Mechanics
00055007820 Brake System
00055007920 Radio Telephone And Navigation System
00055008020 Automatic Gearbox 01N Self Diagnosis
00055008120 Fuel Supply System Petrol Engines
00055008220 6 Cylinder Diesel Direct Injection Engine TDI Mechanics
00055008320 5&6 Speed Manual Gearbox 01e Front Wheel Drive
00055008420 TDI Injection And Glow Plug System 6 Cyl
00055008520 Body Self Diagnosis
00055008620 Fuel Supply System Diesel Engines
00055008720 TDI Injection And Glow Plug System 4 Cyl 07 97 &gt 07 99
00055008820 General Body Assembly
00055009220 Motronic Injection And Ignition System 4 Cyl
00055009320 Motronic Injection And Ignition System 6 Cylinder
00055009420 Motronic Fuel Injection And Ignition System 6 Cyl
00055009520 Automatic Gearbox 01V Self Diagnosis
00055009620 Motronic Injection And Ignition System 4 Cyl Turbo
00055009720 TDI Diesel Direct Injection And Glow Plug System 4 Cyl Unit Injector
00055009820 Simos Injection And Ignition System 4 Cylinder
00055009920 TDI Diesel Injection And Glow Plug System 4 Cyl 08 99
00055020020 Audi A4 2.8 litre Fuel Injection Engine 128 kW Multi Point Injection 6 Cylinder Engine Code AAH From November 1994
00055200020 Audi A4 2.4 l Fuel Injection Engine 121 kW Motronic 5 Valve 6 Cylinders Engine Codes AGA From Model Year 1998 8D X 200000
00055210020 Basic Equipment From Model Year 2000
001EBA00020 Fitting Instructions Retrofitting Key Operated Switch To Deactivate Airbag On Front Passenger Side
00252167220 Fitting Instruction
00255015020 Maintenance
00355025920 Electrical System
A0054000120 Removing And Installing Air Mass Meter
A0055010020 4 Cyl TDI Engine Mechanics
A0055010120 Motronic Injection And Ignition System 6 Cyl Turbo
A0055010220 6 Cylinder Engine 2.7 ltr 5 Valve Turbo RS4 Mechanics
A0055010320 Motronic Fuel Injection And Ignition System 6 Cylinder
A0055010420 4 Cylinder Engine 5 Valve Turbo Mechanics
A0055208920 Motronic Fuel Injection And Ignition System 4 Cyl Turbo
A0055215920 Radio Telephone And Navigation System Self Diagnosis
A005AI00320 Servicing Automatic Gearbox 01V Front Wheel Drive And Four Wheel Drive
A008DKI0120 Body Repairs
A00ARRA0020 Wheels And Tyres
A0255212920 4 Cylinder Engine 2 Valve Roller Rocker Fingers Mechanics
D3E804905D7 5 Speed Manual Gearbox 012 01W Front Wheel Drive
D3E8049704D 5 And 6 Speed Manual Gearbox 01E Front Wheel Drive
D3E804A8B9E 5 Speed Manual Gearbox 01A Four Wheel Drive
  • Audi A4 1995 - 2002 A4 Avant 8D 8D2 8D5 Workshop Manual.txt
