Audi A3 S3 RS3 2003 - 2012 A3 S3 RS3 8P 8P1 8PA Workshop Manual and Wiring Diagram
File Size: 294.95 MBFile Format: PDF
Brand: Audi
Manual Type: Repair Manual, Service Manual, Workshop Manual and Wiring Diagram
Model: Audi A3 S3 RS3 2003 - 2012 A3 S3 RS3 8P 8P1 8PA
Date: 2003 - 2012
Number of Pages: 15950 Pages
Our policies and instructions: https://dhtauto.com/dht/threads/rules-when-using-the-forum-update-to-03-01-2022.90280/4-cylinder direct injection engine (1.2 ltr 2-valve TFSI) mechanics
4-cylinder direct injection engine (1.4 ltr 4-valve TFSI) mechanics
4-cylinder direct injection engine (1.8 ltr 2.0 ltr 4-valve TFSI)
4-cylinder direct petrol injection engine (1.6 ltr 4-valve) mechanics
4-cylinder direct petrol injection engine (2.0 ltr 4-valve) mechanics
4-cylinder direct petrol injection engine (2.0 ltr 4-valve turbo) mechanics
4-cylinder injection engine (1.6 ltr 2-valve) mechanics
4-cylinder TDI engine (1.6 ltr 4-valve common rail) mechanics
4-cylinder TDI engine (2.0 ltr 4-valve common rail) mechanics
4-cylinder TDI engine (2.0 ltr 4-valve common rail generation II) mechanics
4-cylinder TDI unit injector engine (1.9 ltr 2.0 ltr 2-valve) mechanics
4-cylinder TDI unit injector engine (1.9 ltr 2-valve) mechanics
4-cylinder TDI unit injector engine (2.0 ltr 4-valve) mechanics
5-cylinder direct injection engine (2.5 ltr 4-valve TFSI)
5-speed manual gearbox 0A4
5-speed manual gearbox 0AF
6-cylinder injection engine (3.2 ltr 4-valve) mechanics
6-speed manual gearbox 0AG
6-speed manual gearbox 0AJ
6-speed manual gearbox 02Q four-wheel drive
6-speed manual gearbox 02Q front-wheel drive
6-speed manual gearbox 02S
7-speed dual clutch gearbox 0AM (S tronic)
7-speed dual clutch gearbox 0BH (S tronic)
Air conditioner with refrigerant R134a
Automatic gearbox 09G
Auxiliary heating
Basic equipment From May 2006
Basic equipment with battery in engine compartment from model year 2004
Body Repairs
Body Repairs General Body Repairs
Brake system
Communication
Direct injection and ignition system (4-cyl 1.4 ltr 4-valve TFSI engine)
Direct injection and ignition system (4-cyl 1.2 ltr 2-valve TFSI engine)
Direct petrol injection and ignition system (4-cyl 1.8 ltr 4-valve turbo with timing chain)
Direct petrol injection and ignition system (4-cyl 2.0 ltr 4-valve)
Direct petrol injection and ignition system (4-cyl 2.0 ltr 4-valve turbo)
Direct petrol injection and ignition system (4-cyl 2.0 ltr 4-valve turbo with timing chain)
Direct petrol injection and ignition system (5-cyl 2.5 ltr 4-valve turbo)
Direct shift gearbox 02E four-wheel drive
Direct shift gearbox 02E front-wheel drive
Electrical system General information
Fitting instruction
Fitting Instructions Radio Communication Systems1
Fitting instructions radio communication systems2
Fitting instructions retrofitting key-operated switch to deactivate airbag on front passenger side
Fuel supply system diesel engines
Fuel supply system petrol engines
General body repairs exterior
General body repairs interior
Heating air conditioning
Injection and ignition system (6-cyl 3.2 ltr 4-valve injection engine)
Maintenance
Motronic direct injection and ignition system (4-cyl)
Rear final drive 02D 0AV
Rear final drive 02D 0AV 0BR 0BY
Running gear front-wheel drive and four-wheel drive
Servicing 6-speed manual gearbox 02Q front-wheel drive and four-wheel drive
Servicing 7-speed dual clutch gearbox 0AM 0CW
Simos injection and ignition system (4-cylinder)
Specifications for testing the braking force (according to German legislation)
TDI injection and glow plug system (4-cyl 1.9 ltr 2.0 ltr unit injector 2-valve)
TDI injection and glow plug system (4-cyl 1.6 ltr 4-valve common rail)
TDI injection and glow plug system (4-cyl 1.9 ltr unit injector 2-valve)
TDI injection and glow plug system (4-cyl 2.0 ltr 4-valve common rail)
TDI injection and glow plug system (4-cyl 2.0 ltr 4-valve common rail generation II)
TDI injection and glow plug system (4-cyl 2.0 ltr unit injector 4-valve)
Technical data for engines
Trailer Operation Guide
Wheel Tyre Guide
Wheels and tyres
