Audi A3 2003 - 2007 8P 8P1 8PA Workshop Manual
Brand: AudiModel: Audi A3 2003-2007 8P 8P1 8PA
Type of Manual: Workshop Manual
Date: 2003 - 2007
001EBA00020 Fitting Instructions Retrofitting Key Operated Switch To Deactivate Airbag On Front Passenger Side
00252167220 Fitting Instruction
A0050305020 Simos Injection And Ignition System 4 Cylinder
A0050305120 4 Cylinder Direct Petrol Injection Engine 2.0 ltr 4 Valve Mechanics
A0050305220 Direct Petrol Injection And Ignition System 4 Cyl 2.0 ltr 4 Valve
A0050305320 Communication
A0050305420 4 Cylinder TDI Unit Injector Engine 2.0 ltr 4 Valve Mechanics
A0050305520 4 Cylinder Injection Engine 1.6 ltr 2 Valve Mechanics
A0050305620 Electrical System
A0050305720 Fuel Supply System Petrol Engines
A0050305820 Fuel Supply System Diesel Engines
A0050305920 Brake System
A0050306020 Running Gear Front Wheel Drive And Four Wheel Drive
A0050306120 General Body Repairs Interior
A0050306220 General Body Repairs Exterior
A0050306320 TDI Injection And Glow Plug System 4 Cyl 2.0 ltr Unit Injector 4 Valve
A0050306420 5 Speed Manual Gearbox 0A4
A0050306520 Automatic Gearbox 09G
A0050306620 Heating Air Conditioning
A0050306720 5 Speed Manual Gearbox 0AF
A0050306820 6 Speed Manual Gearbox 02Q Front Wheel Drive
A0050306920 6 Speed Manual Gearbox 02S
A0050307020 4 Cylinder TDI Unit Injector Engine 1.9 ltr 2 Valve Mechanics
A0050307120 TDI Injection And Glow Plug System 4 Cyl 1.9 ltr Unit Injector 2 Valve
A0050315020 Maintenance
A0050320020 Basic Equipment With Battery In Engine Compartment From Model Year 2004
A0050398920 6 Cylinder Injection Engine 3.2 ltr 4 Valve Mechanics
A0050402920 Injection And Ignition System 6 Cyl 3.2 ltr 4 Valve Injection Engine
A0050405920 Motronic Direct Injection And Ignition System 4 Cyl
A0050408920 Fitting Instructions Radio Communication Systems
A0050415920 Rear Final drive 02D 0AV
A0050418920 Direct Shift Gearbox 02E Four Wheel Drive
A0050422920 4 Cylinder Direct Petrol Injection Engine 1.6 ltr 4 Valve Mechanics
A0050425920 6 Speed Manual Gearbox 02Q Four Wheel Drive
A0050428920 6 Speed Manual Gearbox 0AG
A0050432920 Direct Shift Gearbox 02E Front Wheel Drive
A0050435920 Auxiliary Heating
A0050438920 4 Cylinder Direct Petrol Injection Engine 2.0 ltr 4 Valve Turbo Mechanics
A0050442920 Direct Petrol Injection And Ignition System 4 Cyl 2.0 ltr 4 Valve Turbo
A0050445920 4 Cylinder TDI Unit Injector Engine 1.9 ltr 2.0 ltr 2 Valve Mechanics
A0050448920 TDI Injection And Glow Plug System 4 Cyl 1.9 ltr 2.0 ltr Unit Injector 2 Valve
A0050452920 Direct Petrol Injection And Ignition System 4 Cyl 1.8 ltr 4 Valve Turbo With Timing Chain
A0050455920 4 Cylinder Direct Injection Engine 1.8 2.0 ltr 4 Valve TFSI Generation II
A0050458920 Direct Petrol Injection And Ignition System 4 Cyl 2.0 ltr 4 Valve Turbo With Timing Chain
A0050462920 4 Cylinder Direct Injection Engine 1.4 ltr 4 Valve TFSI Mechanics
A0050465920 6 Speed Manual Gearbox 0AJ
A0050468920 Direct Injection And Ignition System 4 Cyl 1.4 ltr 4 Valve TFSI Engine
A0050472920 7 Speed Dual Clutch Gearbox 0AM S Tronic
A0050475920 4 Cylinder TDI Engine 2.0 ltr 4 Valve Common Rail Mechanics
A0050478920 TDI Injection And Glow Plug System 4 Cyl 2.0 ltr 4 Valve Common Rail
A005AA00320 Rear Final Drive 02D 0AV 0BR 0BY
A005AA00420 Electrical System General Information
A008PKI0120 Body Repairs
A00ARRA0020 Wheels And Tyres
A0750320020 Basic Equipment From May 2006
D3E801F3E24 4 Cylinder TDI Engine 1.6 ltr 4 Valve Common Rail Mechanics
D3E801FD11C TDI Injection And Glow Plug System 4 Cyl 1.6 ltr 4 Valve Common Rail
D3E802351A7 TDI Injection And Glow Plug System 4 Cyl 2.0 ltr 4 Valve Common Rail Generation II
D3E8023F0E5 4 Cylinder TDI Engine 2.0 ltr 4 Valve Common Rail Generation II Mechanics
D3E8024B499 Direct Injection And Ignition System 4 Cyl 1.2 ltr 2 Valve TFSI Engine
D3E8024FF43 4 Cylinder Direct Injection Engine 1.2 ltr 2 Valve TFSI Mechanics
D3E8034CBC7 Direct Petrol Injection And Ignition System 5 Cyl 2.5 ltr 4 Valve Turbo
D3E8035674C 5 Cylinder Direct Injection Engine 2.5 ltr 4 Valve TFSI
D3E80362404 7 Speed Dual Clutch Gearbox 0BH S Tronic
D3E8047924E Servicing 6 Speed Manual Gearbox 02Q Front Wheel Drive And Four Wheel Drive
D3E804D0737 Servicing 7 Speed Dual Clutch Gearbox 0AM 0CW
D4B8036A192 Wheel Tyre Guide
D4B804EA6B2 Specifications For Testing The Braking Force According To German Legislation
D4B805AB61D Technical Data For Engines
D4B806DFD2D Maintenance
D4B8074A14E Servicing 4 Cylinder Engine 1.8 ltr 2.0 ltr 4 Valve TFSI EA888 Gen II
