Audi A1 2011 - 2018 8X 8X1 8XA 8XF 8XK Workshop Manual
File Size: 632 MBFormat: PDF
Brand: Audi
Manual Type: Workshop Manual
Model: Audi A1 (2011-2018), including:
8X, 8X1, 8XA, 8XF, 8XK
Date: 2011 - 2018
A005AA00420 Electrical System General Information
A00ARRA0020 Wheels And Tyres
D3E802996E4 Direct Petrol Injection And Ignition System 4 Cyl 1.4 ltr 4 Valve Turbo With Timing Chain
D3E802996E5 TDI Injection And Glow Plug System 4 Cyl 1.6 ltr 4 vAlve Common Rail
D3E802AC1A1 Fuel Supply System Petrol Engines
D3E802AC1A7 Fuel Supply System Diesel Engines
D3E802BC475 4 Cylinder Direct Injection Engine 1.4 ltr 4 Valve TFSI EA111
D3E802C1A1C 4 Cylinder TDI Engine 1.6 ltr 4 Valve Commonrail
D3E802CF565 Maintenance
D3E802CF582 Heating Air Conditioning
D3E802CF5A1 5 Speed Manual Gearbox 02R 0A4
D3E802CF5CC General Body Repairs Interior
D3E802D0518 Running Gear Front Wheel Drive And All Wheel Drive
D3E802D1C18 Brake System
D3E802D1C1B General Body Repairs Exterior
D3E802D1C22 7 Speed Dual Clutch Gearbox 0AM 0CW S Tronic
D3E802D2302 Communication
D3E802D3B8D Electrical System
D3E802D5B8D Direct Petrolin Jection And Ignition System 4 Cyl 1.2 ltr 2 Valve Turbo With Timing Chain
D3E802DB99A Body Repairs
D3E802E5B03 4 Cylinder Direct Injection Engine 1.2 ltr 2 Valve TFSI EA111
D3E802EBB56 6 Speed Manual Gearbox 02U
D3E802F44C0 5 Speed Manual Gearbox 02T 0DF
D3E80323F89 4 Cylinder Direct Petrol Injection Engine 1.4 ltr 4 Valve Turbo With Super Charger EA111
D3E80332DCA Direct Petrol Injection And Ignition System 4 Cyl 1.4 ltr 4 Valve Turbo With Super Charger And Timing Chain
D3E803D25D1 TDI Injection And Glow Plug System 4 Cyl 2.0 ltr 4 Valve Common Rail
D3E803F8C86 4 Cylinder TDI Engine 2.0 ltr 4 Valve Common Rail
D3E804022FF 6 Speed Manual Gear Box 0A8 Front Wheel Drive
D3E804C6E77 4 Cylinder Direct Petrol Injection Engine 2.0 ltr 4 Valve Turbo EA113
D3E804CAB67 6 Speed Manual Gear Box 0A8 All Wheel Drive
D3E804CBBC6 Fuel Supply System Petrol Engines Four Wheel Drive
D3E804CED7E 4 Cylinder Direct Injection Engine 1.4 ltr 4 Valve TFSI EA211
D3E804D0737 Servicing 7 Speed Dual Clutch Gear Box 0AM 0CW
D3E804D3BC9 Direct Petrol Injection And Ignition System 4 Cyl 2.0 ltr 4 Valve Turbo
D4B8036A18F Wheel Tyre Guide
D4B803D5026 Rear Final Drive 0AY 0BR 0BS 0CR
D4B803E2057 4 Cylinder Direct Injection Engine 1.8 2.0 ltr 4 Valve TFSI Generation III
D4B804BDDB5 4 Cylinder TDI Engine 1.6 ltr 4 Valve Common Rail EA288 Gen I
D4B804C90D8 3 Cylinder Direct Injection Engine 1.0 ltr 4 Valve TFSI EA211
D4B804EFA59 3 Cylinder TDI Engine 1.4 ltr 4 Valve Common Rail EA288 Gen I
D4B805ADD6B Technical Data For Engines
D4B8063201D Air Conditioners With Refrigerant R1234yf General Information
D4B806E19A0 Maintenance
D4B806F5E2E Servicing 4 Cylinder Engine 2.0 ltr 4 valve TFSI EA888 Gen III
