Audi A1 2011 - 2018 8X 8X1 8XA 8XF 8XK Workshop Manual and Wiring Diagram
File Size: 487.11 MBFile Format: PDF
Brand: Audi
Manual Type: Workshop Manual , Wiring Diagram
Model: Audi A1 2011 - 2018 type 8X, 8X1, 8XA, 8XF, 8XK
Date: 2011 - 2018
List of files:
Our policies and instructions: https://dhtauto.com/dht/threads/rules-when-using-the-forum-update-to-03-01-2022.90280/001KAH00020 Body Repairs General Body Repairs
A005A120020 Basic equipment From April 2010
A00ARRA0020 Wheels and tyres
D3E802996E4 Direct petrol injection and ignition system (4 cyl 1.4 ltr 4 valve turbo with timing chain)
D3E802996E5 TDI injection and glow plug system (4 cyl 1.6 ltr 4 valve common rail)
D3E802AC1A1 Fuel supply system petrol engines
D3E802AC1A7 Fuel supply system diesel engines
D3E802BC475 4 cylinder direct injection engine (1.4 ltr 4 valve TFSI EA111)
D3E802C1A1C 4 cylinder TDI engine (1.6 ltr 4 valve common rail)
D3E802CF565 Maintenance
D3E802CF582 Heating air conditioning
D3E802CF5A1 5 speed manual gearbox 02R 0A4
D3E802CF5CC General body repairs interior
D3E802D0518 Running gear front wheel drive and four wheel drive
D3E802D1C18 Brake system
D3E802D1C1B General body repairs exterior
D3E802D1C22 7 speed dual clutch gearbox 0AM 0CW (S tronic)
D3E802D2302 Communication
D3E802D3B8D Electrical system
D3E802D5B8D Direct petrol injection and ignition system (4 cyl 1.2 ltr 2 valve turbo with timing chain)
D3E802DB99A Body Repairs
D3E802E5B03 4 cylinder direct injection engine (1.2 ltr 2 valve TFSI EA111)
D3E802EBB56 6 speed manual gearbox 02U
D3E802F44C0 5 speed manual gearbox 02T 0DF
D3E80323F89 4 cylinder direct petrol injection engine (1.4 ltr 4 valve turbo with supercharger EA111)
D3E80332DCA Direct petrol injection and ignition system (4 cyl 1.4 ltr 4 valve turbo with supercharger and timing chain)
D3E803D25D1 TDI injection and glow plug system (4 cyl 2 0 ltr 4 valve common rail)
D3E803F8C86 4 cylinder TDI engine (2 0 ltr 4 valve common rail)
D3E804022FF 6 speed manual gearbox 0A8 front wheel drive
D3E804C6E77 4 cylinder direct petrol injection engine (2 0 ltr 4 valve turbo EA113)
D3E804CBBC6 Fuel supply system petrol engines four wheel drive
D3E804CED7E 4 cylinder direct injection engine (1.4 ltr 4 valve TFSI EA211)
D3E804D0737 Servicing 7 speed dual clutch gearbox 0AM 0CW
D3E804D3BC9 Direct petrol injection and ignition system (4 cyl 2 0 ltr 4 valve turbo)
D4B8036A18F Wheel Tyre Guide
D4B803D5026 Rear final drive 0AY 0BR 0BS 0CR
D4B803E2057 4 cylinder direct injection engine (1 8 2 0 ltr 4 valve TFSI generation III)
D4B804BDDB5 4 cylinder TDI engine 1.6 ltr 4 valve common rail (EA 288 Gen I)
D4B804C90D8 3 cylinder direct injection engine (1 0 ltr 4 valve TFSI EA211)
D4B804EA6B2 Specifications for testing the braking force (according to German legislation)
D4B804EFA59 3 cylinder TDI engine 1.4 ltr 4 valve common rail (EA 288 Gen I)
D4B805ADD6B Technical data for engines
D4B8063201D Air conditioners with refrigerant R1234yf General information
D4B806E19A0 Maintenance
D4B806F5E2E Servicing 4 cylinder engine 2 0 ltr 4 valve TFSI (EA 888 Gen III)
