Amazone Sowing Tank Pneumatic FRS FPS Instructions Manual MG484​
Type of Machine: Sowing Tank Pneumatic
Number Of Pages: 120 Pages
Model: Amazone
Brand: Amazone
Type of Manual: Instructions Manual
Parts Number: MG484
Publication Date: 1998
Details about the machine
Putting into operation
only front frame sowing tank pneumatic FRS and front packer sowing tank pneumatic FPS:
FRS / FPS front mounted
Blower fan with hydraulic drive
Blower fan with Diesel engine drive
Sowing tank filling/emptying and monitoring the seed level
Setting the metering unit to the seed
Determining the gearbox setting for for the desired sowing rate
Adjusting gearbox setting with AMADOS seed rate remote control (special option) ..
only pack top sowing module AS:
Fixing pack top sowing module AS on combinations
with tyre packer roller RP or wedge ring roller KW
with tooth packer roller PW
Setting the depth placement of the seed
Track marker
Extra coverage following harrow
Creating tramlines with AMADOS tramlining control (special option) ....
all types:
Transport on public roads
Maintenance and care
Details of the machine
Range of application
Manufacturer
Declaration of conformity
Details
when making enquiries and ordering parts ..
Type plate
Type plate
Front frame-sowing tank pneumatic
FRS 1, FRS 2
Type plate
front packer-sowing tank
Pneumatic FPS 1, FPS 2
Type plate
Pack top sowing module AS
Technical data
Technical data
Front frame-sowing tank pneumatic FRS
Technical data
Front packer-Sowing Tank Pneumatic FPS
Technical data
Pack top sowing module AS .
Hydraulic system
Details about noise level
Designed use
DHT-amazone-sowing-tank-pneumatic-frs-fps-instructions-manual-mg484-01164010042025-1.jpg
DHT-amazone-sowing-tank-pneumatic-frs-fps-instructions-manual-mg484-01164010042025-2.jpg
