- If you download this document, you will be lost 600 Beer
Amazone Mulch Cultivator Cenius 3002-T to 4002-T Super_Special Operating Manual MG4442
Publication Date: 2012
Number Of Pages: 78 Pages
Brand: Amazone
Model: Amazone
Parts Number: MG4442
Type of Machine: Mulch Cultivator
1.1 Purpose of the document
1.2 Locations in the operating manual
1.3 Diagrams used
2.1 Obligations and liability
2.2 Representation of safety symbols
2.3 Organisational measures
2.4 Safety and protection equipment
2.5 Informal safety measures
2.6 User training
2.7 Safety measures in normal operation
2.8 Dangers from residual energy
2.9 Maintenance and repair work, fault elimination
2.10 Constructive changes
2.11 Cleaning and disposal
2.12 User workstation
2.13 Warning pictograms and other signs on the machine
2.14 Dangers of not observing safety instructions
2.15 Safety-conscious working
2.16 Safety information for users
4.1 Overview of subassemblies
4.2 Supply hoses between the tractor and the machine
4.3 Transportation equipment
4.4 Intended use
4.5 Danger area and danger points
4.6 Rating plate and CE marking
4.7 Technical data
4.8 Necessary tractor equipment
4.9 Noise production data
5.1 Tines
5.2 Coulter
5.3 Coulter arrangement
5.4 Levelling unit
5.5 Boundary discs
5.6 The wedge ring roller
5.7 Tensioned crosspiece
5.8 Stand
5.9 Feeler wheels (Option for Cenius 4002-T)
5.10 Safety chain for implements without brake system
5.11 Hydraulic connections
6.1 Checking the suitability of the tractor
6.2 Securing the tractor/machine against unintentional start-up and rolling
7.1 Coupling the machine
7.2 Uncoupling the machine
8.1 Working depth of the tines
8.2 Working depth of the levelling unit
8.3 Adjusting the stripper of the wedge ring rollers
8.4 Setting the feeler wheels
9.1 Changing from working to transport position
10.1 Changing from transport to working position
10.2 Operation
10.3 Headland
12.1 Cleaning
12.2 Lubrication instructions
12.3 Maintenance plan - overview
12.4 Installing and removing the tines
12.5 Changing the coulters
12.6 Replace the tension springs of the overload safety device (workshop work)
12.7 Installing and removing the disc segments (workshop work)
12.8 Replacing discs (workshop work)
12.9 Tine connection
12.10 Roller connection
12.11 Roller connection outside
12.12 Disc carrier connection
12.13 Hydraulic system (workshop work)
12.14 Lower link pins
13.1 Screw tightening torques
