makrini
Vip Member
Jul 11, 2015
Hi To all dhauto Members
Here Best/Famous Software NYO4
NOTE: NYO4 work in system 32bits with loader, and 64bits without loader (lic key needed)
and don't Work On Windows 8/8.1
After Download, just extract NYO4_2012 Folder Where you want
For 32bits system Use file "Nyo2012_user32.exe"
If you have issue, start same registration as 64bits below.
For 64bits system, delete file "Nyo2012_user32.exe"
Next click on file "Nyo4_2012.exe" , and Post your ID Here , We will help you with lic key
When you receive your Registration, simply extract and Paste to \NYO4_2012\FOLDER
Then You need to put "Nyo4_2012.exe" as Administrator & as Compatibility Mode for XP SP3 before starting Nyo4
P.S: if you can't see Pictures you must delete the nyo4.ini then you will see all pictures
Enjooooooy and Good Luck !
  • Nyo4_.txt
