Doorman
Vip Member
Jul 13, 2021
86
70
If you download this document, you will be lost 4400 Beer
ToyoLex 4 Black Diamond Edition
- Supports Generation 1, 2 and 3 files from Toyota and Lexus Denso ECUs with the below MCU cores:
- Denso Generation 3: R7F701202 and R7F701216 .
- Denso Generation 2: D76F0199GD, D76F0196F1, D76F0219F1.
- Denso Generation 1: NEC 76F00XX series (Currently not support old Denso core 76F0004GD mask found on some 2001-2004 MY cars)
- Exclusive algorithm that recognizes immobilizer block into Flash file, doing the disable task only in such memory and with only one click.
- Automatic special function that do erasing of DTCs togheter with Immobilizer disable function.
- By doing the process only in Flash memory, most immobilizer disable tasks can be performed through the OBD II port without the need to open the ECU!
- Not more cut / uninstall any wire or module after do Immo off, simply program the file generated by ToyoLex 4 BDE and start the engine!
- Support and process files from ALL Denso ECUs for DIESEL and GASOLINE engines.
- Work with ZERO risk on Denso Generation 3 ECUs.
- Allow binary files from any Flashing tool of the market that support Denso ECUs for Toyota and Lexus cars.
- Tested on systems with key blade and START-STOP systems.
- NOT support ECUs for Hybrid Vehicles (1) and locked Gen 3 ECU by wrong programming.
- Not tested on Factory virgin ECUs (New not installed yet ECUs).
Toylex 4 Unlocked no need activation
  • SoToLE4Ch.txt
