ohenry
746
79
27
ho chi minh
If you download this document, you will be lost 5350 Beer
Truckcom Toyota BT Forklift 3.2.0
Description: TruckCom ToyotaBT 3.1.0 [2021] is a service tool software designed to run on a personal computer (PC) under Microsoft Windows. It will communicate with the Electronic Control Modules (ECMs) through a communication unit (diagnostic adapter) thus allowing you to diagnose existing and potential problems, configure the product, and obtain data for analysis.
Software information
Software type: Diagnostic
Type Vehicle: Forklift
Version: 3.2.0
Size Installed: 94 MB
Region: All regions
Interface Languages: English
Database Language: English
Software features
Added
Added BMS event log error codes with timestamps to BMS truck report.
Added BMS parameter limit values to BMS truck report.
Added BMS startup error cause to BMS truck report.
Added BMS protective mode error with timestamp to BMS truck report.
Added support for DMB17-024 revision 3.0.
Added BMS diagnostics dialog.
Added support for Italian language.
BMS protective mode error code is cleared from BMS when generating truck report (Production ONLY).
Added a new DHU2+ form for activating/deactivating the shock sensor.
Added “truck and battery” as a choice in production, which will ignore a missing _BP-file.
When only battery is selected in production, a warning/error will be displayed if _BP-file is present and BMS node is not detected.
Added support to dump raw data from BMS to file.
Added BMS slave modules to BMS Configure general tab.
Changed
Configuration failure of the BMS now also displays a more informative text described in the package file.
Generic BMS pachage has been updated.
Fixed
Fixed error when downloading layout to ZPU that would cause TruckCom to crash unexpectedly.
Generated truck reports no longer writes data in different order each time the amount of data in the report is changed.
System OS
Windows® 7
Windows® 10
Windows® 11
  • Truckcom Toyota BT Forklift 3.2.0.txt
