80
If you download this document, you will be lost 3775 Beer
VMWare Techline Connect lastest (GDS2 Full database and Unlimited day) + Tech2Win
1. Techline Connect
Techline Connect (formerly TIS2Web) rollout of the new application to dealerships begins in 2019 brings together all the common resources technicians use every day for diagnosis and repairs in one simple application. The all-new application has a single sign-on for access to nine applications — integrating Service Information, reprogramming, programing, diagnostics, vehicle information and other features — to help technicians efficiently and accurately manage the information available to them in the service department.
Like other tech companies that do not support older, out of date applications, GM cannot continue to support TIS2Web, which is based on legacy technology and outdated security applications. In addition to GDS2, other diagnostic features will be removed gradually until the full retirement of TIS2Web in mid- to late-2021.
Techline Connect supports all diagnostic tools available in TIS2Web and all development of future capabilities going forward will be focused on enhancing and expanding the Techline Connect experience.
The Techline Connect application has a single sign-on for access to nine applications, seamlessly integrating Service Information (SI), a scan tool (GDS2), the Service Programming System (SPS2), and other applications with vehicle-specific information. All information and applications are available on a technicianfriendly dashboard with an intuitive interface that also automatically displays Investigate Vehicle History (IVH) information, Field Actions, and Warranty History when connected to a vehicle.
2. GDS2 (GLOBAL DIAGNOSTIC SYSTEM 2)
GDS2 is the diagnostic scan tool required to use MDI, MDI2 or J2534. It allows technicians to scan the vehicle for data and trouble codes. GDS2 is supported in 2014 and newer models. Support on earlier model year vehicles varies between Tech2Win and GDS2 software.
Techline Connect also does not require an internet connection to use GDS2 Diagnostics, thanks to the Stand-alone Mode. Bypass the log-in by selecting Stand-alone Mode from the log-in screen. Techline Connect will open with only the GDS2 icon. There will be no connection to the Service Information and programming. In the Stand-alone Mode, Techline Connect uses the MDI and vehicle connection function to establish vehicle communications.
3. Tech2Win
Tech2Win is a PC program that executes Tech2 software on a Windows PC. It is used for some old car and can be used for various vehicles brands.
4. Supported Hardware
  • + GM MDI
  • + GM MDI 2
  • + J2534 device (Tech2Win not support J2534)
4. System Requirements:
  • + OS: Windows: 10, Windows 11
  • + Free hard drive: 50 GB or more
  • + CPU: Core i3 or above
  • + Ram: 8 GB or more
  • + VMware 16.x or above
  • SoGMTLoff20534.txt
DHTmaster
Administrators
Staff member
Dec 15, 2021
876
100
43
