1,425
229
If you download this document, you will be lost 4400 Beer
CAT SIS 01.2020 FULL
Description: Service Information System (SIS) is a software tool that distributes electronic parts and service information for Caterpillar machines and engines released since 1977. Caterpillar SIS (CAT SIS) 2020 is illustrated a guide to the maintenance and repair of the full range of cat vehicles, contains guidance on repair equipment and machinery caterpillar, program help diagnose production caterpillar, operating instructions spare parts and equipment caterpillar.
You can access information by:
Systems & Components (Product Structure)
Documentation (Document Structure)
SMCS Code
Basic Search
Media Search
As Shipped Product
Parts Search
Numerical Parts Record (NPR)
Remanufactured Parts Search
Type: Parts catalogs, Repair manuals, Wiring and hydraulic diagrams
Capacity: 197 GB
Version: 01.2020
Brand: Caterpillar
Region: All Region
Language: English, Spanish, Italian, Chinese, German, French
Sofware Feature:
Service Repair Information (Systems Operation, Testing and Adjusting, Troubleshooting, Disassembly and Assembly, Specifications)
Applied Failure Analysis
Bench Test Procedures
Contamination Control Guidelines
Custom Hydraulic Service
Custom Service Information
Engine News
General Service Information
Reuse And Salvage Guidelines
Information Release Memo
Microfiche
Operation and Maintenance Manual
Parts Identification
Schematics
Service Letter
Service Magazine
Shop Review
Special Instructions
Systems Operation
Systems Operation-Fundamentals
Technical Information Bulletin
Tool Operating Manual
Torque Specifications
Troubleshooting
Truck Engine News
Undercarriage Reconditioning Bulletin
WinXP ,VISTA, Win 7, WIN8,Windows 10
Microsoft Internet Explorer, Versions 7.0 and 8.0
Note: These browsers must support Java Script and HTML, Version 2
2.4 GHz Pentium-compatible processor or higher
2 GB RAM or higher
Third generation DVD drive (required) Note: Has to be able to read dual layer DVDs.
15" or larger Super VGA (needs to support 1024 x 768 resolution) adapter and monitor/Open GL supported Graphics Card (Recommend 128MB+ RAM) Monitor capability of supporting 1024 x 768 resolution and Open GL supported Graphics Card (Recommend 128MB+ RAM)
LaserJet V or compatible printer
Pointing device built in or external
Emulation or LAN adapter and software suitable for the dealer host computer
Modem: at dealership's discretion
Installation Instructions:
Passwords NO NEED for Caterpillar SIS data and update disks 2019-07.
1. Mount the image.iso image. Run the file "Setup.exe". Following the prompts of the installer, install the electronic catalog.
2. Mount the image "RERD0010.iso" from the folder "Updates". Run the file "Setup.exe". Following the installer’s prompts, install the updates. Repeat the same process with all the images "RERD001x.iso".
3. Copy the hacked files "sis_libFNP.dll" and "sis.exe" to the folder C:\Caterpillar\SIS\Bin. Owerwrite if asked.
4. Run "Keygen.exe". Copy the MAC address of your computer’s network card, paste it into Keygen. Set the date until which the program will work. Click on the "Generate" button. Copy the resulting "license.dat" file to the C:\Caterpillar folder.
5. Copy the "User Authorization" folder to the C:\Caterpillar folder.
6. Run the file "Environment.reg", agree to make changes to the registry. Reboot the PC.
7. Launch the electronic catalog. Import the User Authorization.xml account from the C:\Caterpillar\User Authorization folder. The login and password for the account are stored in the file "C:\Caterpillar\User Authorization\User ID.txt".
8. Create folders for each data drive, get C:\Caterpillar\Data\USB01 .... USB04
9. Copy data from each disk to the appropriate folder.
10. After all the DVDs have been unpacked to the folder you specified, you need to exit SIS in the browser (if you did not exit before),
hover over the tray icon on the right SIS
-> right click
-> Configure
-> Attach Data DVD
-> Add
-> We select the first disk (USB01) - we press ADD
Repeat Add for all DVDs (4pcs).
After everything is finished, click SAVE below, SIS will offer to connect the disks and reboot (reboot the server, in the tray)
After the icon appears in the tray, you can work - everything is installed.
A few verification VIN-codes of tractors are in folder No. 11.
  • CAT SIS 01.2020.txt
  • Like
Reactions: KHADIBI
