TOYOTA ALPHARD / VELLFIRE 2008 SERVICE & REPAIR INFORMATION MANUAL
Toyota Alphard / Vellfire Service information library 04.2008
ANH20, GGH20 series
Engines:
2GR-FE - 3.5L V6 24Valve DOHC Dual VVT-i
2AZ-FE - 2.4L 4cylinder 16Valve DOHC VVT-i
New car features
Electrical wiring diagram
Body Repair
Service data sheet
REPAIR MANUAL
ENGINE
ENGINE CONTROL SYSTEM
2AZ-FE - SFI system, Mass air flow meter, Ignition system, Camshaft oil control valve, Camshaft position sensor, Crankshaft position sensor, Ignition coil and spark plug, Engine coolant temperature sensor, Throttle body, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Relay, ECM, Accelerator pedal
2GR-FE - SFI system, Mass air flow meter, Ignition system, Camshaft oil control valve, Camshaft position sensor, Crankshaft position sensor, Ignition coil and spark plug, Engine coolant temperature sensor, Throttle body, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Relay, ECM, Accelerator pedal
ENGINE MECHANICAL
2AZ-FE - Engine, Drive belt, Valve clearance, Camshaft, Cylinder head gasket, Front/Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
2GR-FE - Engine, Drive belt, Camshaft, Cylinder head gasket, Front/Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
FUEL
2AZ-FE - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pressure pulsation damper, Fuel pump, Fuel tank, Fuel sender gauge assembly
2GR-FE - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pump, Fuel pump resistor, Fuel tank, Fuel sender gauge assembly
EMISSION CONTROL
2AZ-FE - Emission control system, Canister, Purge valve, PCV valve, Fuel tank cap
2GR-FE - Emission control system, Canister, Purge valve, PCV valve, Fuel tank cap
INTAKE / EXHAUST
2AZ-FE - Intake system, Intake manifold, Exhaust manifold, Exhaust pipe
2GR-FE - Intake system, Intake manifold, Exhaust manifold, Exhaust pipe
COOLING
2AZ-FE - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Fan motor, Relay, Radiator
2GR-FE - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Fan motor, Fan ECU, Relay, Radiator
LUBRICATION
2AZ-FE - Lubrication system, Oil and oil filter, Oil pressure switch, Oil pump, Engine oil cooler
2GR-FE - Lubrication system, Oil and oil filter, Oil pressure switch, Oil pump
STARTING
2AZ-FE - Starting system, Starter, Engine switch, Relay
2GR-FE - Starting system, Starter, Engine switch, Relay
Cruise control - Cruise control system, Cruise control main switch
DRIVETRAIN
U241E Automatic Transmission / Transaxle - Automatic transaxle system, Fluid, Speed sensor, Transmission wire, Valve body assembly, Park / Neutral position switch, Shift lever, Transmission control cable assembly, Differential oil seal, Automatic transaxle assembly, Torque converter clutch and drive plate, Transaxle unit, Oil pump, Differential case
U660E Automatic Transmission / Transaxle - Automatic transaxle system, Fluid, Speed sensor, ATF temperature sensor, Transmission wire, Valve body assembly, Park / Neutral position switch, Air cooled oil cooler, Shift lever, Transmission control cable assembly, Differential oil seal, Automatic transaxle assembly, Torque converter clutch and drive plate, TCM, Oil pump, Differential case
K112 Multidrive / CVT - Continuously variable transaxle system, Fluid, Transaxle assembly, Park / Neutral position switch, Shift lever, Transmission control cable assembly, Front differential oil seal, Oil pan, Oil cooler, Torque converter and drive plate, Revolution sensor, Oil pressure sensor, Oil pump, Differential case
Drive Shaft / Propeller shaft - Drive shaft system, Front drive shaft assembly
Axle and Differential - Axle system, Front axle hub bolt, Front axle hub, Steering knuckle, Rear axle hub bolt, Rear axle hub
SUSPENSION
Suspension - Suspension system, Front wheel alignment, Rear wheel alignment, Front shock absorber, Front suspension lower arm, Front lower ball joint, Front stabilizer bar, Front suspension member, Rear coil spring, Rear shock absorber, Rear axle beam
Tire and Wheel - Tire and wheel system
BRAKE
Brake Control / Dynamic control systems - Vehicle stability control, Brake actuator, Front speed sensor, Rear speed sensor, Yaw rate and acceleration sensor, Steering angle sensor, Skid control buzzer, VSC off switch, Brake pedal load sensing switch
Brake - Brake system, Brake line, Fluid, Brake pedal, Master cylinder, Brake booster, Front brake, Front brake flexible hose, Rear brake, Rear brake flexible hose
Parking Brake - Parking brake system, Parking brake pedal, Parking brake cable, Parking brake assembly, Parking brake switch
STEERING
Steering Column - Steering system, Steering lock system, Steering column assembly, Steering wheel
Power Assist Systems - Power steering system, Power steering ECU
Steering gear / Linkage - Steering gear
AUDIO / VISUAL / TELEMATICS
Audio / Video - Audio and visual system, Rear seat entertainment system, Radio receiver, Stereo component amplifier, Front door speaker, Rear door speaker, Quarter trim speaker, Front seat speaker, Instrument panel speaker, Roof speaker, Television display, Radio antenna cord, Amplifier antenna, Stereo jack adapter assembly, Microphone, Window glass antenna wire
Navigation / Multi info display - Navigation system, Navigation receiver, Hard disk drive, Navigation antenna
POWER SOURCE / NETWORK
Battery / Charging - Charging system, Generator, Battery current sensor, Battery thermometer sensor
Power distribution - Main body ECU
Networking - LIN communication system, CAN communication system, Network gateway ECU
VEHICLE INTERIOR / EXTERIOR
THEFT DETERRENT / KEYLESS ENTRY, LIGHTING, METER / GAUGE / DISPLAY, SUPPLEMENTAL RESTRAINT SYSTEMS, AIRBAG SYSTEM,
SEAT, SEAT BELT, HEATING / AIR CONDITIONING, POWER OUTLETS, INTERIOR PANELS / TRIM, WINDOW / GLASS, SLIDING ROOF / CONVERTIBLE,
DOOR / HATCH, WIPER / WASHER, MIRROR, LIGHTING EXTERNAL, HORN, EXTERIOR PANELS / TRIM
NEW CAR FEATURES
New model outline, Engines, Chassis, Body, Body electrical, Features, Technical specifications
ELECTRICAL WIRING DIAGRAM
Engine - Engine control, Ignition, Starting, Cooling fan, Cruise control
Drivetrain - CVT and Shift indicator, ECT, Shift lock
Brake - ABS, TRC, VSC
Steering - EPS, Steering lock
Audio/Visual/Telematics - Audio system, Navigation system, Parking assist
Power Source / Network - Charging, DLC3, Multiplex communication system, Power source
Vehicle Interior - Air conditioner, Door lock, Engine immobiliser, Illumination, Light, Power seat, Seat heater, Smart entry / Start system, SRS, Wireless door lock control, Theft deterrent, Seat belt warning, Power outlet, Combination meter, Cigarette lighter, Automatic glare resistant EC mirror
Vehicle Exterior - Automatic light control, Back door closer, Front fog light, Back up light, Wiper and washer, Headlight, Front window deicer, Headlight beam level control, Headlight cleaner, Horn, Mirror heater, Power back door, Power slide door, Power window, Rear fog light, Rear window defogger, Remote control mirror, Slide door closer, Sliding roof, Stop light, Taillight, Turn signal and hazard warning light
BODY REPAIR
OTHER INFORMATION
Code:
Product Code: Toyota
Availability: In Stock
04.2008
Market : All Regions
Quantity of DVDV 1 DVD
ANH20, GGH20 series
Engines:
New car features
Body Repair
Service data sheet
REPAIR MANUAL
ENGINE
ENGINE MECHANICAL
FUEL
EMISSION CONTROL
INTAKE / EXHAUST
COOLING
LUBRICATION
STARTING
DRIVETRAIN
SUSPENSION
BRAKE
STEERING
NEW CAR FEATURES
BODY REPAIR
OTHER INFORMATION
