1,425
241
Multiecuscan 3.6 Instruction Full [04.2017]
Description: Multiecuscan is a vehicle diagnostic software with advanced functions. It allows you to perform various diagnostics tasks on the supported vehicles/modules. In order to use the software you need an interface. The following interfaces are currently supported by the software: KL (also known as Vag Com 409), ELM327 (1.3 or newer), OBD Key 1.40, OBD Link, ELM Scan 5, CAN tie CAR.
Bluetooth OBD Key, ELM 327 and OBD Link interfaces are fully supported but not recommended for special functions (like PROXI Alignment, remote control programming, IMA coding, etc.)!
CAN tie CAR is a professional multi-protocol interface with multiplexing capabilities.
1. Uninstall any previous version installed
2. Install SetupMultiecuscan36.msi
3. Replace / overwrite all files in "multiecuscan" with the patched files in "Patch_Multiecuscan"
4. Launch and register with this serial key: 77C1B-20088-32A258
5. Multiecuscan will restart.
6. Enjoy. You are now registered
  • Multiecuscan 3.6 Instruction Full [04.2017].txt
