1,425
241
If you download this document, you will be lost 2000 Beer
Lexus RX450H Service Information Library [2009 - 2012]
03.2009 - 02.2012 / All Regions / 1 DVD / Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP / 32 & 64 bit
Lexus RX450H Service information library 03.2009 - 02.2012
GYL10, GYL15 series
Engines:
2GR-FXE 3.5L V6 24-Valve DOHC VVT-i
New car features
Electrical wiring diagram
Body Repair
Service data sheet
REPAIR MANUAL
Engine / Hybrid system
ENGINE CONTROL - SFI system, Ignition system, Camshaft oil control valve, Throttle body, ECM, Mass Air flow meter, Camshaft position sensor, Crankshaft position sensor, Ignition coil and spark plug, Engine coolant temperature sensor, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Relay
HYBRID / BATTERY CONTROL - Hybrid control system, Hybrid battery system, Coolant, Inverter with converter, Battery smart unit, HV battery, Water pump with motor, SUB radiator, Frame wire, Accelerator pedal sensor, Circuit Breaker sensor, Relay, HV relay assembly, Service plug grip, Battery plug, Battery blower
ENGINE MECHANICAL - Engine, Drive Belt, Camshaft, Cylinder head gasket, Front crankshaft oil seal, Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
FUEL - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pump, Fuel pump resistor, Fuel tank, Fuel sender gauge assembly
EMISSION CONTROL - Emission control system, EGR valve, EGR cooler, Vacuum sensor, Canister, Purge valve, Fuel vapor containment valve, Fuel tank pressure sensor, Fuel tank cap, PCV valve
INTAKE / EXHAUST - Intake system, Intake manifold, Exhaust manifold, Exhaust pipe
COOLING - Cooling system, Cooling fan system, Exhaust heat recirculation system, Coolant, Water pump, Temperature switch, Thermostat, Exhaust pipe gas control actuator, Cooling fan motor, Cooling fan ECU, Radiator, Relay
LUBRICATION - Lubrication system, Oil and Oil filter, Oil pressure switch, Oil pump, Engine oil cooler
STARTING - Power switch
CRUISE CONTROL - Cruise control system, Cruise control main switch, Dynamic Radar cruise control system, Driving support ECU, Millimeter wave radar sensor
Drivetrain
P313 HYBRID TRANSMISSION / TRANSAXLE - Hybrid transaxle system, Hybrid vehicle transaxle, Hybrid transaxle fluid, Transmission control cable, Oil pump, Oil cooler, Hybrid transaxle oil seal, Input shaft oil seal, Shift lever, Shift lever position sensor
Q211 HYBRID TRANSMISSION / TRANSAXLE - Rear traction motor, Hybrid transaxle fluid, Differential side gear shaft, HYbrid transaxle side gear oil seal, Hybrid transaxle mass damper
DRIVE SHAFT / PROPELLER SHAFT - Drive shaft system, Front drive shaft assembly, Rear drive shaft assembly (for AWD)
AXLE AND DIFFERENTIAL - Axle system, Front axle hub bolt, Front axle hub, Steering knuckle, Rear axle hub bolt, Rear axle hub, Rear axle carrier (for 2WD and AWD)
SUSPENSION CONTROL - Air suspension system, Active stabilizer suspension system, Suspension control system, Height control compressor, Pneumatic tank, Control valve assembly, Height control sensor, Suspension control ECU, Active stabilizer control ECU, Height control off switch, Height control switch,
ALIGNMENT / HANDLING DIAGNOSIS - Front / Rear wheel alignment
FRONT SUSPENSION - Front suspension system, Front shock absorber, Front lower suspension arm, Front lower ball joint, Front stabilizer bar, Front active stabilizer control actuator, Front suspension member
REAR SUSPENSION - Rear suspension system, Rear shock absorber, Rear coil spring, Rear pneumatic cylinder, Rear upper arm, Rear lower arm, Rear trailing arm, Rear stabilizer bar, Rear active stabilizer control actuator, Rear suspension member
TIRE PRESSURE MONITORING - Tire pressure warning system, Tire pressure warning receiver, Tire pressure warning valve, Tire pressure warning ECU, Tire pressure warning reset switch
TIRE / WHEEL - Tire and wheel system
BRAKE CONTROL / DYNAMIC CONTROL SYSTEMS - Electronically controlled brake system, Brake actuator, Front /Rear speed sensor, Yaw rate and acceleration sensor, Steering angle sensor, Brake pedal stroke sensor, Skid control ECU, Skid control buzzer, VSC off switch, Brake control power supply, Relay
BRAKE SYSTEM - Brake system, Brake line, Brake fluid, Brake pedal, Brake master cylinder
REAR / FRONT BRAKE - Front / Rear brake, Front / Rear brake flexible hose
PARKING BRAKE - Parking brake system, Parking brake pedal, Parking brake cable, Parking brake switch, Parking brake assembly
POWER ASSIST SYSTEMS - Power steering system, Power steering ECU, DC/DC converter
STEERING COLUMN - Power tilt and power telescopic steering column system, Steering lock system, Steering system, Steering column assembly, Steering wheel, Multiplex tilt and telescopic ECU, Tilt and telescopic manual switch
STEERING GEAR / LINKAGE - Steering gear
Audio / Visual / Telematics
AUDIO / VIDEO - Audio and visual system, Rear seat entertainment system, Radio receiver, Stereo component amplifier, Luggage speaker, Front door speaker, Rear door speaker, Instrument panel speaker, Rear package tray speaker, Television display, Radio antenna cord, Amplifier antenna, Stereo jack adapter assembly, Rear seat entertainment ECU, Multi-media interface ECU, Microphone, Window glass antenna wire, Noise filter
NAVIGATION / MULTI INFO DISPLAY - Navigation system (for DVD/HDD), Navigation receiver, Multi display, Hard disk drive, Remote touch, Navigation antenna
PARK ASSIST/ MONITORING - Intuitive parking assist system, Parking assist monitor system, Side monitor system, Rear view monitor system, Clearance warning ECU, Warning buzzer, Ultrasonic sensor, Television camera, Parking assist ECU
GARAGE DOOR OPENER - Garage door opener system, Opener transmitter
CELLULAR COMMUNICATION - Safety connect system, Lexus enform system, DCM, Back-up battery, Manual SOS switch, Telephone and GPS antenna cords, Telephone microphone
Power source / Network
BATTERY / CHARGING - Battery, Battery thermometer sensor
POWER DISTRIBUTION - Main body ECU, Power management control ECU, Integration relay
NETWORKING - LIN communication system, CAN communication system
Vehicle Interior
DOOR LOCK - Power door lock control system, Wireless door lock control system, Transmitter battery, Door control transmitter, Door control switch, Front / Rear door lock, Door control receiver, Wireless door lock buzzer
THEFT DETERRENT / KEYLESS ENTRY - Smart access system with push-button start, Engine immobiliser system, Theft deterrent system, Electrical key oscillator, Entry lock and unlock switch, Engine hood courtesy switch, Security horn assembly, Security indicator light assembly, ID code box, Certification ECU
LIGHTING - Lighting system, Vanity light, Personal light, Room light, Luggage compartment room light, Door courtesy light, Glove box light, Console box light, Footwell light, Scuff plate light, Front / Rear / Back door courtesy switch
METER / GAUGE / DISPLAY - Meter / Gauge system, Clock system, Combination meter, Accessory meter, Headup display, Light control rheostat, Satellite switch
MIRROR - Inner rear view mirror
SUPPLEMENTAL RESTRAINT SYSTEMS - Airbag system, Occupant classification system, Steering pad, Spiral cable, Knee airbag assembly, Front passenger airbag assembly, Curtain shield airbag assembly, Front seat side airbag assembly, Rear seat side airbag assembly, Center airbag sensor assembly, Front airbag sensor, Side airbag sensor, Rear airbag sensor, Seat position sensor, Occupant classification ECU
PRE-COLLISION - Pre-collision system, Seat belt control ECU
SEAT - Front power seat control system, Seat heater system, Climate control seat system, Front seat assembly, Rear seat assembly, Seat memory switch, Power seat switch, Lumbar switch, Seat variable cushion switch, Seat heater switch, Front seatback heater, Front seat cushion heater, Seat heater control
SEAT BELT - Seat belt tension reducer system, Seat belt warning system, Front passenger seat belt warning light, Occupant detection sensor, Front seat inner belt assembly, Front seat outer belt assembly, Rear seat inner belt assembly, Rear seat outer belt assembly, Rear center seat inner belt assembly, Rear center seat outer belt assembly
HEATING / AIR CONDITIONING - Air conditioning system, Refrigerant, Refrigerant line, Air conditioning unit, Blower unit, Front blower motor, Compressor, Condenser, Room temperature sensor, Ambient temperature sensor, Front evaporator temperature sensor, Solar sensor, Smog ventilation sensor, Air conditioning pressure sensor, Heater water pump, Air conditioning panel, Air conditioning amplifier
POWER OUTLETS - Accessory socket system, Voltage inverter, Inverter relay, Inverter main switch, Power outlet socket, Rear power outlet socket
INTERIOR PANELS / TRIM - Instrument panel safety pad, Front console box, Roof headlining
Vehicle Exterior
WINDOW / GLASS - Power window control system, Power window master switch, Front passenger side power window switch, Rear power window switch, Power window regulator motor, Windshield glass, Front side fix window glass, Back door glass, Windshield deicer system, Window defogger system, Windshield deicer switch, Window defogger wire, Quarter window glass, Relay
SLIDING ROOF / CONVERTIBLE - Sliding roof system, Sliding roof housing, Sliding roof switch assembly
DOOR / HATCH - Back door closer system, Power back door system, Fuel lid opener system, Hood, Hood support, Hood lock control cable assembly, Front door, Rear door, Back door, Back door opener switch, Power back door main switch, Power back door control switch, Power back door closer switch, Power back door touch sensor, Power back door drive unit, Power back door warning buzzer, Back door support, Fuel lid opener motor assembly, Fuel lid opener switch, Fuel lid courtesy switch
MIRROR - Power mirror control system, Outer rear view mirror, Outer mirror switch, Outer mirror control ECU
WIPER / WASHER - Wiper and washer system, Front wiper motor, Rear wiper motor, Front wiper motor, Front / Rear wiper rubber, Wiper switch, Washer motor, Washer nozzle, Washer level warning switch, Headlight cleaner actuator, Headlight cleaner switch, Headlight cleaner motor, Rain sensor, Relay
LIGHTING - Lighting system, Headlight assembly, Fog light assembly, Side turn signal light assembly, Rear side marker light assembly, Rear combination light assembly, Rear light, Licence plate light, High mounted stop light, Headlight dimmer switch, Hazard warning switch, Stop light switch, Automatic light control sensor, AFS ECU, Height control sensor, Headlight leveling ECU, Turn signal flasher assembly, Stop light control relay, Relay
HORN - Horn system, Low pitched horn, High pitched horn, Relay
POWER OUTLETS - Towing converter system, Towing socket, Towing converter relay
EXTERIOR PANELS / TRIM - Front bumper, Rear bumper, Front spoiler, Rear spoiler, Radiator grille, Name plate, Roof rack, Front door belt moulding, Rear door belt moulding, Rocker panel moulding, Side moulding, Front door window frame moulding, Rear door window frame moulding, Roof drip side finish moulding, Quarter panel wheel opening moulding, Back door outside garnish, Rear wheel house plate
NEW CAR FEATURES
Engine / Hybrid System - ENGINE CONTROL, HYBRID / BATTERY CONTROL, ENGINE MECHANICAL, FUEL, EMISSION CONTROL, INTAKE / EXHAUST, COOLING, CRUISE CONTROL, LUBRICATION
Drivetrain - HYBRID TRANSMISSION / TRANSAXLE, DRIVE SHAFT / PROPELLER SHAFT, AXLE AND DIFFERENTIAL
Suspension - SUSPENSION CONTROL, FRONT / REAR SUSPENSION, TIRE PRESSURE MONITORING, TIRE / WHEEL
Brake - BRAKE CONTROL / DYNAMIC CONTROL SYSTEMS, BRAKE SYSTEM, FRONT / REAR BRAKE, PARKING BRAKE
Steering - POWER ASSIST SYSTEMS, STEERING COLUMN
Audio/Visual/Telematics - AUDIO/ VIDEO, NAVIGATION / MULTI INFO DISPLAY, PARKING ASSIST / MONITORING, GARAGE DOOR OPENER, CELLULAR COMMUNICATION
Power Source, Network - POWER DISTRIBUTION, NETWORKING
Vehicle Interior, Vehicle Exterior - DOOR LOCK, THEFT DETERRENT / KEYLESS ENTRY, LIGHTING, METER / GAUGE / DISPLAY, SUPPLEMENTAL RESTRAINT SYSTEM, SEAT, HEATING / AIR CONDITIONING,
WINDOW / GLASS, SLIDING ROOF / CONVERTIBLE, DOOR / HATCH, MIRROR, WIPER / WASHER, LIGHTING, EXTERIOR PANELS / TRIM
ELECTRICAL WIRING DIAGRAM
COOLING FAN, IGNITION, SHIFT LOCK, AIR SUSPENSION, ACTIVE STABILIZER SUSPENSION SYSTEM, TIRE PRESSURE WARNING SYSTEM, VEHICLE DYNAMICS INTEGRATION MANAGEMENT, EPS, POWER TILT AND POWER TELESCOPIC, AUDIO SYSTEM, GARAGE DOOR OPENER, PARKING ASSIST, SAFETY CONNECT, MULTIPLEX COMMUNICATION, POWER SOURCE, SRS, HYBRID SYSTEM, LIGHT and others
BODY REPAIR
INTRODUCTION, BODY PANEL REPLACEMENT, BODY DIMENSIONS, PAINTING / COATING
OTHER INFORMATION
  • Lexus RX450H Service Information Library [2009 - 2012].txt
  • RX 450h Repair Manual.txt
