1,425
241
If you download this document, you will be lost 1000 Beer
Lexus RX400H Service Information Library [2005 - 2008]
03.2005 - 12.2008 / All Regions / 1 CD / Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP / 32 & 64 bit
Lexus RX400H Service information library 03.2005 - 12.2008
MHU38 series
Engines:
3MZ-FE - 3.3L 24-valve V6 DOHC
New car features
Electrical wiring diagram
Body Repair
Service data sheet
REPAIR MANUAL
Diagnostic
Engine - SFI system
Hybrid System - Hybrid control system, Hybrid battery system
Drive line - Drive shaft system
Suspension & Axle - Axle system, Suspension system
Brake - Electronically controlled brake system, Brake system, Parking brake system
Steering - Steering system, Power tilt and power telescopic steering column, Power steering system, Electronic power steering system
Heater & Air conditioning - Air conditioning system
Restraints - Air bag system, Seat belt warning system
Securities - Theft deterrent system, Engine immobiliser system
Cruise Control system - Cruise control system
Body Electrical - Lighting system, Wiper and washer system, Power door lock control, Wireless door lock control, Key reminder warning system, Meter/Gauge system, Audio and Visual system, Navigation system, Parking assistant monitor system, Horn system
Body - Power window control system, Window defogger system, Power mirror control system, Front power seat control, Seat heater system, Back door closer system, Power back door system, Electrical back door outside handle system, Fuel lid opener, Sliding roof system
Communication system - Multiplex communication system, CAN communication system
Installation / Removal
Engine - Camshaft timing oil control valve assembly, Crankshaft position sensor, Throttle body, Knock sensor, Timing belt, Camshaft, Cylinder head, Engine front/rear oil seal, Engine assembly, Engine unit, Fuel injector, Fuel pump, Fuel tank, Canister, Air fuel ratio sensor, Heated oxygen sensor, Exhaust pipe, Thermostat, Radiator, Oil filter, Oil pump, VVT sensor
Hybrid system - Inverter with converter, Hybrid vehicle control ECU, Water pump with motor, SUB radiator, Frame wire, Accelerator pedal, Front circuit breaker sensor, HV battery, Battery smart unit, HV relay assembly, Battery plug, Battery fuse/blower, Shift lever position sensor (P310 Hybrid transaxle), Oip pump assembly, Transaxle assembly, Shift lever, Hybrid transaxle oil seal, Input shaft oil seal, Transaxle control cable assembly, Dust cover (Q211 Hybrid transaxle), Differential side gear shaft, Hybrid transaxle side gear oil seal (Q211 Hybrid transaxle), Rear traction motor
Drive line - Front/Rear drive shaft
Suspension & Axle - Front/Rear axle hub/bolt, Rear axle carrier, Rear/Front shock absorber, Front suspension N1 lower arm, Front lower ball joint, Front/Rear stabilizer bar, Rear trut, Rear suspension N1/2 arm
Brake - Brake actuator, Front/Rear speed sensor, Yaw rate sensor, Steering sensor, Skid control ECU, Brake control power supply, Brake pedal stroke sensor, Brake pedal, Brake master cylinder, Front brake, Front brake flexible hose, Rear brake, Rear brake flexible hose, Parking brake pedal (LHD & RHD), Parking brake cable, Parking brake assembly
Steering - Steering column assembly, Multiplex tilt and telescopic ECU, Power steering gear/ECU, DC-DC converter
Heater & Air conditioning sytem - Refrigerant line, Air conditioning unit, Blower unit, Electric inverter compressor, Condenser, Heater water pump, Center cluster integration switch, Air conditioning amplifier)
Restraints - Steering pad, Spiral cable, Driver side knee airbag assembly, Front passenger airbag assembly, Curtain shield airbag assembly, Center airbag sensor assembly, Front/Rear/Side airbag sensor, Seat position sensor, Front seat inner/outer belt assembly, Rear center seat inner/outer assembly
Cruise Control system - Cruise control main switch
Body Electrical - Headlight assembly, Sideturn signal light assembly, Fog light, Rear combination light, Back-up light, Licence plate light, High mounted stop light, Rear fog light, Headlight dimmer switch, Height control sensor, Wiper switch, Rain sensor, Front speakers, TV camera and much much more
Body - Windshield glass, Rear quarter window glass, Back door glass, Inner/Outer rear view virror, Instrument panel safety pad, Rear console box, Front/Rear seat assemble, Hood, Front/Rear/Back door, Front/Rear bumper and much much more
Inspection
Engine, Hybrid System, Drive line, Suspension & Axle, Brake, Steering, Heater & Air conditioning,
Restraints, Securities, Cruise Control system, Body Electrical, Body, Communication system
ELECTRICAL WIRING DIAGRAM
Engine - Engine control, Ignition, Radiator Fan
Hybrid System - Hybrid system, Shift control system
Transmission - Shift lock
Brake - Brake control system
Steering - EPS, Power tilt and power telescopic
Heater & Air conditioning - Automatic air conditioner
Restraints - SRS, Seat belt warning
Securities - Hybrid vehicle immobiliser system, Theft deterrent
Body Electrical - Audio system, Back-up light, Door lock control, Double locking, Front fog light, Horn, Headlight, Front wiper and washer, Illumination, Navigation system, Auto turn off system, Power distributor/outlet/source and much much more, diagrams for all car units
Body - Automatic Glare-Resistant EC mirror, Backdoor opener, Front window deicer, Fuel lid opener, Mirror heater, Power back door, Power seat, Power window, Rear window defogger, Remote control mirror, Seat heater, Sliding roof
NEW CAR FEATURES
New model outline, Hybrid system II, Engine, Exterior, Interior, Chassis, Body, Body electrical
MAINTENANCE
BODY REPAIR
OTHER INFORMATION
  • Lexus RX400H Service Information Library [2005 - 2008].txt
