- If you download this document, you will be lost 1000 Beer
Lexus GS300 / GS430 Service Information Library [2005 - 2008]
01.2005 - 08.2008 / All Regions / 1 CD / Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP / 32 & 64 bit
Lexus GS300 / GS430 2005 - 2008 Service information library
UZS190, GRS190 series
Engines:
3GR-FE 3.0L V6 24Valve DOHC Dual VVT-i
3GR-FSE 3.0L V6 24Valve DOHC D-4 Dual VVT-i
3UZ-FE 4.3L V8 32Valve DOHC VVT-i
New car features
Electrical wiring diagram
Body Repair
Service data sheet
REPAIR MANUAL
Engine control system
3GR-FE - SFI system, Camshaft timing oil control valve, Throttle body, ECM, Accelerator pedal, Mass air flow meter, Crankshaft position sensor, Engine coolant temperature sensor, Knock sensor, Integration relay, Fuel pump relay
3GR-FSE - SFI system, Camshaft timing oil control valve, Throttle body, ECM, Accelerator pedal, Mass air flow meter, Crankshaft position sensor, Engine coolant temperature sensor, Knock sensor, Integration relay, Fuel pump relay
3UZ-FE - SFI system, Camshaft timing oil control valve, Throttle body, ECM, Accelerator pedal, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Knock sensor, Integration relay, Fuel pump relay
Engine mechanical
3GR-FE - Engine, Drive belt, Engine assembly, Engine unit
3GR-FSE - Engine, Drive belt, Engine assembly, Engine unit
3UZ-FE - Engine, Drive belt, Valve clearance, Timing belt, Cylinder head, Engine assembly, Engine unit
Fuel
3GR-FE - Fuel system, Fuel injector, Fuel pressure pulsation damper, Fuel pump, Fuel pump resistor, Fuel tank
3GR-FSE - Fuel system, Fuel injector, Fuel pressure sensor, Fuel pressure pulsation damper, High pressure side fuel pump, Injector driver, Fuel pump, Fuel pump resistor, Fuel tank
3UZ-FE - Fuel system, Fuel injector, Fuel pressure pulsation damper, Fuel pump, Fuel pump resistor, Fuel tank
Emission Control
3GR-FE - Emission control system, Canister, Vacuum switching valve, Ventilation valve, Air fuel ratio sensor, Heated oxygen sensor
3GR-FSE - Emission control system, Canister, Vacuum switching valve, Ventilation valve, Air fuel ratio sensor, Heated oxygen sensor
3UZ-FE - Emission control system, Canister, Vacuum switching valve, Ventilation valve, Heated oxygen sensor
Intake / Exhaust
3GR-FE - Intake system, Exhaust pipe
3GR-FSE - Intake system, Exhaust pipe
3UZ-FE - Intake system, Intake manifold, Intake air control valve actuator, Vacuum tank, Vacuum switching valve, Exhaust pipe
Cooling
3GR-FE - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan ECU, Cooling fan relay, Radiator
3GR-FSE - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan ECU, Cooling fan relay, Radiator
3UZ-FE - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan ECU, Cooling fan relay, Radiator
Lubrication
3GR-FE - Lubrication system, Oil filter, Oil pump
3GR-FSE - Lubrication system, Oil filter, Oil pump
3UZ-FE - Lubrication system, Oil filter, Oil pump, Engine oil cooler
Ignition
3GR-FE - Ignition system, Ignition coil, VVT sensor
3GR-FSE - Ignition system, Ignition coil, VVT sensor
3UZ-FE - Ignition system, Ignition coil, VVT sensor
Starting
3GR-FE - Starting system, Starter, Starter relay, Starter cut relay, Engine switch, Entry and start system
3GR-FSE - Starting system, Entry and start system, Starter, Starter relay, Starter cut relay, Engine switch
3UZ-FE - Starting system, Entry and start system, Starter, Starter relay, Starter cut relay, Engine switch
Charging
3GR-FE - Charging system, Generator
3GR-FSE - Charging system, Generator
3UZ-FE - Charging system, Generator
Transmission
A760E Automatic transmission - Electronic controlled automatic transmission system, Fluid, Extension housing rear oil seal, Speed sensor, Transmission wire, Park / Neutral position switch, Valve body assembly, Shift lock system, Floor shift assembly, Automatic transmission assembly, Torque converter and drive plate, Transmission unit, Oil pump, Clutch drum and input shaft assembly, Valve body, Shift solenoid valve
A761E Automatic transmission - Electronic controlled automatic transmission system, Fluid, Extension housing rear oil seal, Speed sensor, Transmission wire, Park / Neutral position switch, Valve body assembly, Shift lock system, Floor shift assembly, Automatic transmission assembly, Torque converter and drive plate, Transmission unit, Oil pump, Clutch drum and input shaft assembly, Valve body, Shift solenoid valve
A960E Automatic transmission - Electronic controlled automatic transmission system, Fluid, Extension housing rear oil seal, Speed sensor, Transmission wire, Park / Neutral position switch, Valve body assembly, Shift lock system, Floor shift assembly, Automatic transmission assembly, Torque converter and drive plate, Transmission unit, Oil pump, Clutch drum and input shaft assembly, Valve body, Shift solenoid valve
Drive Line
Propeller Shaft - Propeller shaft system, Rear Propeller shaft assembly
Drive Shaft - Drive shaft system, Rear drive shaft assembly
Differential - Differential system, Differential oil, Rear differential side gear shaft oil seal, Rear differential carrier assembly
Suspension & Axle
Axle - Axle system, Front axle hub bolt, Front axle hub, Steering knuckle, Rear axle hub bolt, Rear axle hub
Suspension control - Adaptive variable suspension system, Front/Rear acceleration sensor, Absorber control ECU
Suspension - Suspension system, Front wheel alignment, Rear wheel alignment, Front shock absorber, Front suspension upper arm, Front lower suspension arm, Front lower ball joint, Front stabilizer bar, Rear shock absorber, Rear upper No1 control arm, Rear upper No2 control arm, Rear No1 suspension arm, Rear No2 suspension arm, Toe control link, Rear stabilizer bar
Tire and Wheel - Tire and wheel system, Tire pressure warning system, Tire pressure monitor
Brake Control - Vehicle stability control system, Electronically controlled brake system, Brake actuator, Front speed sensor, Rear speed sensor, Yaw rate sensor, Steering sensor, Skid control ECU, Brake control power supply, Brake pedal stroke sensor, ABS main relay, ABS motor relay
Brake - Brake system, Fluid, Brake pedal, Master cylinder, Brake booster, Front brake, Front brake flexible hose, Rear brake, Rear brake flexible hose, Stop light switch
Parking Brake - Parking brake system, Brake pedal, Parking brake cable, Parking brake assembly
Steering Column - Steering system, Power tilt and power telescopic steering column system, Electric steering lock system, Steering control ECU, Steering column assembly, Multiplex tilt and telescopic ECU, Variable gear ratio steering system
Power Steering - Power steering system, Electronic power steering system, Steering gear, Power steering ECU, EPS relay
Heater & Air Conditioning system
Air Conditioning - Air conditioning system, Refrigerant, Refrigerant line, Air conditioning unit, Blower unit, Blower motor, Compressor and pulley, Condenser, Room temperature sensor, Ambient temperature sensor, Evoporator temperature sensor, Solar sensor, Pressure switch, Heater glow plug, Water hose joint, Air conditioning amplifier, Air outlet register
Restraints
Pre-crash safety system - Pre-crash safety system
Supplemental Restraint System - Airbag system, Steering pad, Spiral cable, Driver side knee airbag assembly, Front passenger side knee airbag assembly, Front passenger airbag assembly, Curtain shield airbag, Front seat side airbag, Rear seat airbag assembly, Center airbag sensor, Front airbag sensor, Side airbag sensor, Rear airbag sensor, Seat position sensor
Seat Belt - Seat belt tension reducer, Seat belt warning system, Front seat inner belt assembly, Front seat outer belt assembly, Rear seat inner belt, Rear seat outer belt, Child restraint seat tether anchor, Child restraint seat anchor bracket, Seat belt control ECU
Securities
Theft Deterrent - Theft deterrent system, Engine hood courtesy switch, Security horn assembly
Engine Immobiliser - Engine immobiliser system
Cruise Control System
Cruise Control - Cruise control system, Dynamic radar cruise control system, Cruise control main switch, Cruise control ECU
Body Electrical
Lighting, Wiper and Washers, Door Lock, Meter, Audio/Visual, Navigation, Park Assit/Monitoring, Horn
Body
Windshield/Windowglass, Mirror, Instrument Panel, Seat, Engine Hood/Door, Exterior, Interior, Sliding Roof
Communication System
CAN communication system, Multiplex communication system
NEW CAR FEATURES
New model outline, Engine, Transmission, Brake, Body, Body electrical, Technical specifications
ELECTRICAL WIRING DIAGRAM
Engine - Charging, Cooling fan, DLC3, Engine control, Ignition, Smart entry and Start system
Transmission - ECT and A/T indicator, Shift lock
Suspension & Axle - Electronic modulated suspension, Tire pressure warning system
Brake - ABS, TRS, VSC, Steering, Dynamics integrated management
Steering - EPS, Power tilt and power telescopic, VGRC system
Heater & Air Conditioner System - Air conditioner
Restraints - Electric tension reducer, Pre-crash safety system, Seat belt warning, SRS
Securities - Theft deterrent
Cruise Control System - Cruise control system, Dynamic radar cruise control
Body Electrical - Adaptive front lighting system, Audio system, Automatic light control, Back-up light, Cigarette lighter, Front fog light, Headlight, Interior light, Multi display, Stop light, Navigation system and much much more
Body - Climate control seat, Door lock control, Double locking, Fuel lid opener, Mirror heater, Power seat, Power thunk lid, Power windows, Rear window defogger, Remote control mirror, Seat heater, Sliding roof
Communication System - Multiplex communication system
BODY REPAIR
OTHER INFORMATION
Engines:
New car features
Body Repair
Service data sheet
REPAIR MANUAL
Engine mechanical
Fuel
Emission Control
Intake / Exhaust
Cooling
Lubrication
Ignition
Starting
Charging
Transmission
Drive Line
Suspension & Axle
Restraints
Securities
Body Electrical
Body
NEW CAR FEATURES
BODY REPAIR
OTHER INFORMATION
