- If you download this document, you will be lost 500 Beer
Lexus CT200H Service Information Library [2010 - 2015]
12.2010 --> / All Regions / 1 DVD / Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP / 32 & 64 bit
Lexus CT200H Service information library 12.2010 - up
ZWA10 series
Engines:
2ZR-FXE 1.8L VVT-i 4-cylinder
New car features
Electrical wiring diagram
Body Repair
Service data sheet
REPAIR MANUAL
Engine / Hybrid system
ENGINE CONTROL - SFI system, Ignition system, Camshaft oil control valve, Throttle body, ECM, Mass Air flow meter, Camshaft position sensor, Crankshaft position sensor, Ignition coil and spark plug, Engine coolant temperature sensor, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Integration relay
HYBRID / BATTERY CONTROL - Hybrid control system, Hybrid battery system, Coolant, Inverter with converter, Battery smart unit, HV battery, Water pump with motor, SUB radiator, Frame wire, Accelerator pedal sensor, Relay, HV relay assembly, Combination switch, Service plug grip, Battery blower
ENGINE MECHANICAL - Engine, Camshaft, Cylinder head gasket, Front crankshaft oil seal, Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
FUEL - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pump, Fuel tank, Fuel sender gauge assembly
EMISSION CONTROL - Emission control system, EGR valve, EGR cooler, Vacuum sensor, Canister, Purge valve, Fuel tank cap, PCV valve
INTAKE / EXHAUST - Intake system, Intake manifold, Exhaust manifold, Exhaust pipe
COOLING - Cooling system, Cooling fan system, Exhaust heat recirculation system, Coolant, Water pump, Temperature switch, Thermostat, Exhaust pipe gas control actuator, Cooling fan motor, Radiator, Relay
LUBRICATION - Lubrication system, Oil and Oil filter, Oil pressure switch, Oil pump
STARTING - Power switch
CRUISE CONTROL - Cruise control system, Cruise control main switch, Dynamic Radar cruise control system, Driving support ECU, Millimeter wave radar sensor
DRIVETRAIN
HYBRID TRANSMISSION / TRANSAXLE - Hybrid transaxle system, Electronic shift lever system, Hybrid vehicle transaxle, Generator cable, Motor cable, Hybrid transaxle fluid, Hybrid transaxle oil seal, Input shaft oil seal, Shift lever, Shift control actuator, TCM
DRIVE SHAFT / PROPELLER SHAFT - Drive shaft system, Front drive shaft assembly
AXLE AND DIFFERENTIAL - Axle system, Front axle hub bolt, Front axle hub, Steering knuckle, Rear axle hub bolt, Rear axle hub, Rear axle carrier
SUSPENSION
ALIGNMENT / HANDLING DIAGNOSIS - Front / Rear wheel alignment
FRONT SUSPENSION - Front suspension system, Performance damper, Front shock absorber, Front lower suspension arm, Front lower ball joint, Front stabilizer bar, Front suspension member
REAR SUSPENSION - Rear suspension system, Performance damper, Rear shock absorber, Rear coil spring, Rear upper arm, Rear lower arm, Rear trailing arm, Rear stabilizer bar, Rear suspension member
TIRE / WHEEL - Tire and wheel system, Tire repair seal
BRAKE
BRAKE CONTROL / DYNAMIC CONTROL SYSTEMS - Electronically controlled brake system, Front /Rear speed sensor, Yaw rate and acceleration sensor, Steering angle sensor, Brake pedal stroke sensor, Skid control buzzer
BRAKE SYSTEM - Brake system, Brake line, Brake fluid, Brake pedal, Brake booster, Brake booster pump
REAR / FRONT BRAKE - Front / Rear brake, Front / Rear brake flexible hose
PARKING BRAKE - Parking brake system, Parking brake pedal, Parking brake cable, Parking brake switch
STEERING
POWER ASSIST SYSTEMS - Power steering system, Power steering ECU
STEERING COLUMN - Heated steering wheel system, Steering system, Steering column assembly, Steering wheel, Steering pad switch, Heated steering wheel controller, Steering heater switch
STEERING GEAR / LINKAGE - Steering gear
AUDIO/VISUAL/TELEMATICS
AUDIO / VIDEO - Audio and visual system, Radio receiver, Stereo component amplifier, Front door speaker, Rear door speaker, Quarter trim speaker, Pillar speaker, Instrument panel speaker, Radio antenna cord, Radio antenna pole, Amplifier antenna, Stereo jack adapter assembly, Multi-media interface ECU, Window glass antenna wire, Microphone, Noise filter
NAVIGATION / MULTI INFO DISPLAY - Navigation system (for DVD/HDD), Navigation receiver, Navigation antenna, Multi display, DVD player, Hard disk drive, Remote touch
PARK ASSIST/ MONITORING - Sensor system, Monitor system, Rear view monitor system, Clearance warning ECU, Warning buzzer, Ultrasonic sensor, Television camera, Clearance sonar main switch, Parking assist ECU
GARAGE DOOR OPENER - Garage door opener system, Opener transmitter
POWER SOURCE/NETWORK
BATTERY / CHARGING - Battery, Battery thermometer sensor
POWER DISTRIBUTION - Main body ECU, Power management control ECU, Integration relay
NETWORKING - LIN communication system, CAN communication system
INTERIOR
DOOR LOCK - Power door lock control system, Wireless door lock control system, Transmitter battery, Door control transmitter, Door control switch, Front / Rear / Back door lock, Door control receiver, Wireless door lock buzzer, Door control relay
THEFT DETERRENT / KEYLESS ENTRY - Entry and start system, Push-button start system, Engine immobiliser system, Theft deterrent system, Intrusion system, Electrical key oscillator, Engine hood courtesy switch, Security horn assembly
LIGHTING - Lighting system, Vanity lght, Personal light, Room light, Luggage compartment room light, Glove box light, Footwell light, Front / Rear / Back door courtesy switch
METER / GAUGE / DISPLAY - Meter / Gauge system, Clock system, Combination meter, Light control rheostat
MIRROR - Inner rear view mirror
SUPPLEMENTAL RESTRAINT SYSTEMS - Airbag system, Steering pad, Spiral cable, Knee airbag assembly, Front passenger airbag assembly, Curtain shield airbag assembly, Front seat side airbag assembly, Center airbag sensor assembly, Front airbag sensor, Side airbag sensor, Rear airbag sensor, Seat position sensor, Airbag cut-off switch
PRE-CRASH SAFETY - Pre-crash safety system, Pre-crash brake cancel switch, Seat belt control ECU
SEAT - Front power seat control system, Seat heater system, Front seat assembly, Rear seat assembly, Seat memory switch, Power seat switch, Lumbar switch, Front seatback heater, Front seat cushion heater
SEAT BELT - Seat belt tension reducer system, Seat belt warning system, Occupant detection sensor, Front seat inner belt assembly, Front seat outer belt assembly, Rear seat inner belt assembly, Rear seat outer belt assembly, Rear center seat outer belt assembly, Tongue plate stopper, Child restraint seat anchor bracket
HEATING / AIR CONDITIONING - Air conditioning system, Refrigerant, Air conditioning unit, Blower unit, Front blower motor, Compressor, Condenser, Room temperature sensor, Humidity sensor, Ambient temperature sensor, Front evaporator temperature sensor, Solar sensor, Air conditioning pressure sensor, Air conditioning panel, Air conditioning amplifier
POWER OUTLETS - Power outlet socket
INTERIOR PANELS / TRIM - Upper instrument panel, Lower instrument panel, Front console box, Roof headlining
EXTERIOR
WINDOW / GLASS - Power window control system, Power window master switch, Front passenger side power window switch, Rear power window switch, Power window regulator motor, Windshield glass, Back door glass, Windshield deicer system, Window defogger system, Windshield deicer switch, Window defogger wire, Quarter window glass
SLIDING ROOF / CONVERTIBLE - Sliding roof system, Sliding roof housing, Sliding roof switch assembly
DOOR / HATCH - Fuel lid opener system, Hood, Hood lock control cable assembly, Front door, Rar door, Back door, Back door opener switch, Back door support, Fuel lid opener motor assembly, Fuel lid opener switch, Relay
MIRROR - Power mirror control system, Outer rear view mirror, Outer mirror switch, Outer mirror control ECU
WIPER / WASHER - Wiper and washer system, Front wiper motor, Rear wiper motor, Front wiper motor, Front / Rear wiper rubber, Wiper switch, Washer motor, Washer nozzle, Washer level warning switch, Headlight cleaner actuator, Headlight cleaner switch, Headlight cleaner motor, Hedlight cleaner control relay, Wiper ECU, Rain sensor
LIGHTING - Lighting system, Headlight assembly, Fog light assembly, Side turn signal light assembly, Rear combination light assembly, Rear light, Licence plate light, High mounted stop light, Headlight dimmer switch, Hazard warning switch, Headlight leveling switch, Stop light switch, Automatic light control sensor, Height control sensor, Headlight leveling ECU, Turn signal flasher assembly, Stop light control relay, Relay
HORN - Horn system, Horn
EXTERIOR PANELS / TRIM - Front bumper, Rear bumper, Front spiler, Rear spoiler, Name plate, Front door belt moulding, Rear door belt moulding, Rocker panel moulding, Front door window frame moulding, Rear door window frame moulding, Windshield outside moulding, Quarter window moulding, Roof drip side finish moulding, Back door outside garnish, Front pillar upper cover, Rear wheel house plate, Black out tape
NEW CAR FEATURES
Engine / Hybrid System - ENGINE CONTROL, HYBRID / BATTERY CONTROL, ENGINE MECHANICAL, FUEL, EMISSION CONTROL, INTAKE / EXHAUST, COOLING, CRUISE CONTROL, LUBRICATION
Drivetrain - HYBRID TRANSMISSION / TRANSAXLE, DRIVE SHAFT / PROPELLER SHAFT, AXLE AND DIFFERENTIAL
Suspension - FRONT / REAR SUSPENSION, TIRE / WHEEL
Brake - BRAKE CONTROL / DYNAMIC CONTROL SYSTEMS, BRAKE SYSTEM, FRONT / REAR BRAKE, PARKING BRAKE
Steering - POWER ASSIST SYSTEMS, STEERING COLUMN
Audio/Visual/Telematics - AUDIO/ VIDEO, NAVIGATION / MULTI INFO DISPLAY, PARKING ASSIST / MONITORING
Power Source, Network - NETWORKING
Vehicle Interior, Vehicle Exterior - DOOR LOCK, THEFT DETERRENT / KEYLESS ENTRY, LIGHTING, METER / GAUGE / DISPLAY, PRE-CRASH SYSTEM, SEAT, HEATING / AIR CONDITIONING,
WINDOW / GLASS, SLIDING ROOF / CONVERTIBLE, DOOR / HATCH, MIRROR, WIPER / WASHER, LIGHTING, EXTERIOR PANELS / TRIM
ELECTRICAL WIRING DIAGRAM
COOLING FAN, CRUISE CONTROL, DYNAMIC RADAR, ENGINE CONTROL, HYBRID SYSTEM, IGNITION, SHIFT CONTROL SYSTEM, ABS, HILL START ASSIST CONTROL, TRC, VSC, EPS, HEATED STEERING WHEEL SYSTEM, AUDIO SYSTEM, GARAGE DOOR OPENER, NAVIGATION, PARKING ASSIST, DLC3, CAN, POWER SOURCE, AIR CONDITIONER, ENTRY & START SYSTEM, SRS, SEAT HEATER, HEADLIGHT, TAILLIGHT, HORN, SLIDING ROOF AND OTHERS
BODY REPAIR
INTRODUCTION, BODY WELD POINT, BODY DIMENSIONS, PAINTING / COATING
OTHER INFORMATION
ZWA10 series
Engines:
New car features
Body Repair
Service data sheet
REPAIR MANUAL
DRIVETRAIN
SUSPENSION
BRAKE
STEERING
INTERIOR
EXTERIOR
NEW CAR FEATURES
BODY REPAIR
OTHER INFORMATION
