- If you download this document, you will be lost 1500 Beer
Landrover & Jaguar Electrical Guides ,Tech Guides & More Full [2015]
Capacity: 1.9GB
Version: 2015
Brand: Land rover & Jaguar
Supported models:
1/ Jaguar Files_05-07-2014
Jag Tech Resource File
1986-2002 Electrical Guides
2003-2011 Electrical Guides
2012 Electrical Guides
2013 Electrical Guides
2014 Electrical Guides
2015 Electrical Guides
Jaguar Technical Guides
1986-1999 Tech Guides
2000-2008 Tech Guides
Vehicle Specification Books
02 2009 Jaguar Specifications Guide
06 2011 Jaguar Specifications Guide
08 2012 Jaguar Specifications Guide
09 2009 Jaguar Specifications Guide
11 2007 Jaguar Specifications Guide
Wire Repair
Ford connector catalog_06-28-2010
LR Wiring Harness Repair Kit LRT-86-010
Wiring Repair_TOPIx
Jag-OBD
1994-1997_XJ_XJS_4.0_AJ16_EMS
1994-1997_XJ_XJS_GM 4L80E_TCM
1994-1997_XJ_XJS_V12_EMS
1997-2002_XJ_XK8_ZF5HP24_TCM
1999-2002_XJ_XK8_AJ27_EMS
2000-2002_XJR_XKR_4.0_SC_W5A580_TCM
2001 MY on X-Type_Jatco
2001-2008_X & S-Types_XK_XJ_Denso EMS
2006 MY on_S-Type _ XJ_V6
2006 MY on_S-Type _ XJ_V8
2007-2008_XK_V8_Denso
2008 MY on_XF_V8
2010 MY on_XF_4.2_V8
2010 MY on_XK_XF_5.0_V8_TCM
2010 MY_XK_XF_5.0_V8_EMS
2010 on_XF_4.2_V8_TCM
2011_XF_XJ_XK_5.0_V8
2012 MY_XF_XJ_XK_5.0_V8_EMS
2013_XF_XJ_3.0_V6_AJ126_Bosch
2013_XF_XJ_5.0_V8_AJ133_Bosch
2014_F-TYPE_3.0_SC_AJ126_Bosch
2014_F-TYPE_5.0_SC_AJ133_Bosch
2014_XF_XJ_3.0_V6_AJ126
2014_XF_XJ_5.0_V8_AJ133
Jaguar NPs
NP07-XK
NP09-XF
NP10-V8 Course Book
NP11- X351
NP13-JAG
NP14-FT_F-TYPE
JAGUAR SERVICE ACTIONS & RECALLS 1988-2006
01. Service Actions and Recalls List 1988 - 2006
B339 - California Oxygen sensor - Ser.3 XJ6 Aug. 1989
C002 - XJS Purge Kit Feb. 1990
D315 - Cruise-Brake switch XJ6 3.6 July 1987
D325 - Spring pan bolts - XJ6 3.6 Feb. 1988
D348 - HP hose & accumulator switches - 88-89 XJ6 June 1990
D349 - Cruise control - XJS & XJ12 Ser. 3 May 1990
R135 - Seat belt buckle - S-Type Dec. 2000
R136 - Check ball joints - S-Type Dec. 2000
R166 - Park brake warning - S-Type Feb. 2005
R167 - Rear wheel braking - S-Type Dec. 2004
R171 - Brake fluid label - S-Type Jan. 2005
R351 - No. 7 - XJS Fuel tank Dec. 1990
R351 - No. 7 (2) - XJS Fuel tank Feb. 1991
R351 - No. 7 (3) - XJS Fuel tank April 1991
R367 - Expansion valve - 1992 XJS Sept. 1991
R374 - High tension leads - 89-91 XJS March 1992
R466 - Throttle nut - 1998 XJ & XK Feb. 1998
R469 - Hood liner - 1994 XJ12 March 1999
R478 - Replace transmission - 1999 XJ & XK July 1999
R493 - EGR and PROM replacement - 1995-96 XJS 4.0 Aug. 2002
R493 - EGR and PROM replacement - 1995-97 XJ Sedan Aug. 2002
R513 - ZF Transmission - 2003-04 S-Type April 2004
R513 - ZF Transmission - 2003-04 XK April 2004
R513 - ZF Transmission - 2004 XJ April 2004
R525 - ZF Transmission - 2006 S-Type & XJ Nov. 2005
R607 - Ball joint nuts - 1995 XJ Feb. 1995
R691 - Emission label - 1995 XJR April 1998
R719 - Passenger air bag door - 2004 XJ April 2004
R815 - Differential circlip - 1997 on XK May 1997
R842 - Headlamp alignment supplement - 1997-03 XK March 2004
R847 - Accelerator Pedal - 2006 XK July 2005
R935 - Replace GECM - 2002-03 X-Type March 2003
R955 - Fuel cap seal - 2004 X-Type Oct. 2004
R957 - Park brake lever - 2002-03 X-Type Jan. 2005
S106 - Steering Wheel - S-Type Sept. 1999
S114 - Steering Lock - S-Type July 1999
S115 - Jack Bolt - S-Type July 1999 - Amended Feb. 2004
S120 - Enhancement Program - S-Type June 2000
S126 - Vacuum hose - S-Type - May 2000
S129 - PCM Software update - S-Type - Jan. 2001
S137 - Oil cooler - S-Type Dec. 2000
S138 - Vacuum label - S-Type Jan. 2001
S139 - PCM Reflash - S-Type July 2002
S140 - Assist Module - S-Type Feb. 2002
S142 - Rear door glass - S-Type July 2004
S144 - Loss of engine performance - S-Type Oct. 2001
S145 - Coolant sensor - S-Type Nov. 2001
S150 - Rear toe - S-Type May 2002
S151 - S.C. Idler pulley - S-Type R Aug. 2002
S155 - Telephone echo - S-Type Jan. 2003
S157 - Thrust bearing failure - S-Type Aug. 2003
S158 - Poor idle & MIL - S-Type July 2003
S159 - Limp mode & MIL - S-Type Nov. 2003
S161 - Sun roof wind noise - S-Type Dec. 2003
S163 - Washer hose - S-Type May 2004
S164 - Rain sensing diode & fuse - S-Type Oct. 2004
S427 - Motorized seat belts - 89-92 Sedans & 88-89 XJS
S462 - Power steering pulley bolts - 98-01 XJ & XK
S468 - Rear hub carrier fulcrum bolts - 1998 XJ & XK Nov. 1998
S474 - Part load breather - S-Type Sept. 2001
S474 - Part load breather - XJ & XK Oct. 2004
S476 - Replace transmission - 1999 XJ & XK Dec. 1998
S479 - Difficult cold start - 1997 to 1999 XK & XJ April 2001
S481 - Revised fuel cap - 2000 XJ & XK March 2000
S484 - Instrument pack failure - 2000 XJ & XK Dec. 2001
S490 - Alternator bracket & drive belt - 2000 - 01 XJ & XK Feb. 2001
S494 - MIL illuminated add ground straps - 1994-95 XJS V12 & XJ12
S498 - Engine Fail safe replace throttle body - 1999 XJ & XK July 2003
S499 - Lower wishbone bushings - 1999-2000 XJ & XK Aug. 2003
S501 - Replace EGR valve - 2000 - 2002 XJR, VDP SC & XKR
S503 - PDI - 2003 XK & XK Nov. 2002
S503 - PDI - S-Type 2003 Nov. 2002
S503 - PDI - X-Type 2003 Nov. 2002
S506 - Power steering pump - 2003 XK July 2003
S509 - Fuel Cap 2001-2003 XK & XJ
S511 - Oil drain plug - 2004 XJ Feb. 2004
S511 - Oil drain plug - S-Type 4.2 Feb. 2004
S514 - Closed throttle operation - XJ and XK Nov. 2004
S515 - Fuel cap seal - 2005 S-Type Nov. 2004
S516 - Spare tire label - 2004 XJ Nov. 2004
S516 - Spare tire label - 2004 X-Type Nov. 2004
S516 - Spare tire label - 2005 S-Type Nov. 2004
S518 - V6 coolant pump hose - 2004-05 S-Type 3.0 Nov. 2004
S524 - Navigation drop out - 2005-06 XJ Oct. 2005
S525 - Navigation drop out - 2005-06 X-Type Oct. 2005
S619 - Water entering ECM - 1995 XJ April 1995
S652 - Radiator drain plug - 1995 XJ Sept. 1995
S653 - DTC P0410 - 1995 XJ12 July 2001
S657 - Oil pressure gauge - 1995 XJ Nov. 1995
S661 - Missing rear seat heaters - 1995-96 XJ LWB Feb. 1996
S666 - EGR valve harness - 1996 XJR June 1996
S669 - EGR harness reroute - 1996 XJR June 1996
S675 - DTC P0441 - 1995 XJ Nov. 2001
S676 - Momentary hesitation - 1996-97 XJ Nov. 2001
S686 - Block heater - Canada - 1998 on XJ Sept. 1998
S691 - Canadian emission label - 1995 XJR May 1998
S694 - Instrument panel harness - 1999 VDP with SC Feb. 1999
S695 - License plate bulbs - 1999 XJ July 1999
S700 - Extended emission warranty - 1995-96 XJ12 Oct. 2004
S701 - Cracked EGR pipe - 1998-99 XJR Jan. 2004
S702 - Ground terminals - 2000 XJ Aug. 2000
S703 - Sending units - 2000 XJ Sept. 2000
S704 - Camshaft sensor harness - 2001 XJR
S712 - Coolant hose routing - 2004 XJR Aug. 2003
S713 - Coolant bleed screw - 2004 XJ Aug. 2003
S717 - Oil cooler pipe - 2004 XJ Feb. 2004
S813 - Service action superceded - coolant 1997-99 XK and XJ Sept. 2001
S817 - Chrome wheels - 1997 XK April 1998
S820 - Air cond. hose & EGR pipe - 1997 XK Aug. 1997
S822 - Driveshaft bolts - 1997-98 XK Feb. 1998
S824 - Water entry - 1998 XK June 1998
S830 - Modify battery cable - 1999 XK July 1999
S831 - Remove EGR pipe - 1997 XK Nov. 1999
S834 - Compliance labels - 2000 XKR Coupe June 2000
S835 - 20 inch tire program - 1997 on XK Nov. 2001
S840 - Dead battery with auto headlamps - 2003 XK June 2003
S841 - canister close valve and pipe - 1999-01 XK Jan 2004
S843 - Battery drain and wipers - 2001-02 XK May 2004
S844 - P1111 readiness - 2003 XKR March 2004
S845 - Canister close valve and pipe - 2001-03 XK June 2004
S846 - Oil cooler hoses and pipes - 2004-05 XK Nov. 2004
S918 - 30 to 15 amp fuse - 2002 X-Type March 2002
S921 - 20 amp micro relay - 2002 X-Type Feb. 2002
S928 - Breather valve - 2002 X-Type Jan. 2003
S930 - Front CV joints - 2002-03 X-Type Oct. 2002
S932 - Overheating - 2002-03 X-Type Jan. 2003
S933 - Fuel tanks - 2002-03 X-Type Aug. 2003
S934 - Reprogram RCM - 2002-03 X-Type March 2003
S936 - Throttle stop - 2002 X-Type March 2003
S937 - Reprogram ECM & TCM - 2002-03 X-Type March 2003
S939 - Thermostat hose clamp - 2002-03 X-Type Feb. 2004
S940 - Headlamp washer cover - 2002-03 X-Type June 2003
S941 - Transmission replacement - 2002 X-Type Sept. 2003
S947 - Fuel tank harness - 2004 X-Type July 2004
S948 - Seat stabilization kit - 2002-03 X-Type Feb. 2004
S951 - Seat harness interference - 2004 X-Type May 2004
S952 - Liftgate spoiler - Canada - 2004 X-Type July 2004
S953 - Shudder & hesitation - 2004 X-Type June 2004
T836 - Activate occupant sensing - 2001 XK Nov. 2001
628-JAG_SRS
Fuel Trim Display
Standard Fasteners - Jaguar
Land Rover Files_01-07-2015
Land Rover 2011 Wiring Diagrams
Land Rover 2012 Wiring Diagrams
Land Rover 2013 Wiring Diagrams
Land Rover 2014 Wiring Diagrams
Land Rover 2015 Wiring Diagrams
Land Rover Defender NAS 2005-2008
Land Rover Electrical Diagrams 1995-2010
Land Rover Freelander NAS 2004
Land Rover LR2 NAS 2007-2010 Electrical Circuit Diagrams
Land Rover LR3 NAS 2005-2009 Electrical Circuit Diagrams
Land Rover LR4 2010
Land Rover Range Rover NAS 2005-2008 Electrical Circuit Diagrams
Land Rover Range Rover Sport NAS 2005-2010 Electrical Circuit Diagrams
Ford Connector Catalog 06-28-2010
Land Rover Wiring Harness Repair Kit LRT-86-010
Wiring Repair_TOPIx
