Humss
33
Jaguar AJ-V8 Engine and 5HP24 Transmission Introduction
Format: Pdf
Page: 256
This Technical Guide introduces the new AJ V8 engine and 5HP24 transmission installed in the XK8 Sports car. It is intended to give Jaguar Dealer workshop personnel an overview of their construction and operation, and is for information purposes only. The contents of this Technical Guide must not be used as a reference source for servicing procedures; all servicing procedures must be in accordance with the appropriate Service Manual.
This Technical Guide will not be updated. While every effort is made to ensure accuracy, changes may occur between going to press and the equipment being introduced to the market. Once the equipment is in service, details of changes can be obtained from Service Bulletins and revisions to the Service Manuals.
All rights reserved. No part of this publication may be reproduced, stored in a retrieval system or transmitted, in any form, electronic, mechanical, photocopying, recording or other means without prior written permission from the Service Division of Jaguar Cars Limited.
Subject Glossary
Abbreviations
Introduction
Basic Engine
Engine Cooling
Engine Lubrication
Variable Valve Timing
Air Intake System
Fuel System
Ignition System
Crankcase Ventilation
EGR System
Engine Accessories
Accessory Drive
Engine Harness
Engine Covers
Engine Specifications
Engine Management
ECM
Electronic Throttle
Fuel Pump
Fuel Injection
Ignition
EVAP System
EGR System
Engine Starting
HO2S Heaters
Instrument Cluster
A/C Compressor Clutch
Windshield and Backlight Heaters
Radiator Cooling Fans
Diagnostics
Transmission
Introduction
Technical Data
Gearshifting
Mechanical Description
Electrical Description
Transmission Management
Service Tools
New Tools
  • Jaguar AJ-V8 Engine and 5HP24 Transmission Introduction.txt
  • Like
Reactions: Chivas99
