Detroit Diesel Spec Manager v5.3.2 2015
Spec Manager software sets up and compares various vehicle specifications to fine tune drivelines saving time and money.
This fun and simple-to-use tool can help you determine what driveline specifications fit your needs. With Spec Manager, a service person can troubleshoot a low power problem. Simply choose engine, vehicle, transmission, tires, and rear axle ratio and Spec Manager will determine the vehicle's fuel economy and operating performance.
Spec Manager can even predict the number of shifts to be made on a trip and the fuel economy before purchasing a truck. Develop and troubleshoot tailor-made truck specifications for your customers with this easy-to-use vehicle specification software. Its a really useful program. Has simulation mode to check avg fuel economy.
DATA TABLE UPDATES:
Added GHG14 (2013) Engine Ratings for:
DD16, DD15, DD15TC, DD13
Added DT12 Detroit Transmission
FEATURE-BASED UPDATES:
None
BUG FIXES:
Corrected various dialog inconsistencies.
1. Locate the file named 'SpecManager_532_Setup.exe' on your Desktop and double-click the icon.
2. The Spec Manager Installation Wizard will Start. Follow the directions as described.
3. After the installation is completed IT IS RECOMMENDED THAT YOU REBOOT YOUR PC.
Running Spec Manager
Spec Manager should be run like any other Windows program. When Spec Manager starts you will be asked to login. Spec Manager will allow you to enter any user name.
User Id: any name
Password: ddc
*NOTE* Create your own user account and use password:ddc
Any name & any company WILL WORK--Tested
DATA TABLE UPDATES:
None
BUG FIXES:
User Id: any name
Password: ddc
