Chivas99
Administrators
Staff member
Jun 16, 2013
151
49
Detroit Diesel first time the company has had an effect 60 years ago, releasing diesel engines that can generate electricity. With the gradual increase in popularity of automotive products company Detroit Diesel has improved its production. Now Detroit Diesel engines feature low fuel consumption, less noise and engine vibration and the least toxicity. Modern engines meet all the requirements of European organizations for the protection of the environment.
If you have any questions on the maintenance or detecting faults in computer systems, engines, you must use the program for diagnostic computer Detroit Diesel Diagnostic Link 7.05 + 6.45.
Diagnostic program Detroit Diesel Diagnostic Link 7.05 + 6.45 is an electronic tool designed to serve the DDEC VI Detroit Diesel, equipped with engines (S-60, MBE 4000, MBE 900, HDE). The diagnostic tool Detroit Diesel Diagnostic Link 7.05 + 6.45 allows users to perform routine tasks, troubleshoot, configure and manage the settings, perform service programs, and other important functions.
The diagnostic tool Detroit Diesel Diagnostic Link 7.05 + 6.45 includes features such:
Proportional Valve Routine to activate outputs
Print Calibrations to PDF file for troubleshooting purposes
Progressive Shift Calculator
Adjustable OI Idle Speed for DDECIV
Save full DDECV diagnostic codes to a text file
Changeable Low Gear torque limiting for DDECIV and DDECV
A read only "Smart Cruise" field added to Cruise Tab
Change OI Target minimum to 800 rpm
Saving I/O config settings in DDEC III / IV the same as DDEC V
Use unsigned seeds for backdoor password (VCU)
Have option in DDDL installation to install Dearborn Group Drivers
Remove Min/Max from fault code display, add associated extreme parm value + stop
Permissions set for DDEC V folder for extraction purposes
  • Detroit Diesel Diagnostic Link 7.05.txt
DHTmaster
Administrators
Staff member
Dec 15, 2021
984
102
43
DHTmaster
Administrators
Staff member
Dec 15, 2021
984
102
43
