Detroit Diesel Diagnostic Link 7.11 (DDDL 7.11 / 6.50) [12/2013] Full
Program for diagnostic Detroit Diesel Diagnostic Link 7.11 (DDDL 7.11 / 6.50) intended for serve and diagnose Detroit Diesel¡¦s EPA07, EPA10, and GHG14 equipped engines (S-60, MBE4000, MBE900, DD13, DD15, DD16).
Note: It is not backward compatible with earlier versions of Detroit Diesel electronic systems. Those systems will continue to be serviced with DDDL 6.X. The DDEC VI electronics system contains two controllers, the MCM (Motor Control Module) and the CPC (Common Powertrain Controller). The Detroit Diesel Diagnostic Link 7.11 (DDDL 7.11 / 6.50) system includes the MCM, CPC and ACM (Aftertreatment Control Module).
Software Detroit Diesel Diagnostic Link 7.11 (DDDL 7.11 / 6.50) allows the user to perform the following standard operations on both engine platforms:
1 - Perform Standard Fault Code Operations
2 - Links to Traditional and Advanced Troubleshooting Information
3 - Read Actual Values
4 - Configure and Manage Parameters
5 - Perform Service Routines
6 - Playback Logs of All Connected Activity
7 - Automatic Software Updates from our server
Software Detroit Diesel Diagnostic Link 7.11 (DDDL 7.11 / 6.50) has enhancements:
- Windows 8 compatible
- Data files (Log, Parameter, XML¡Ke.g.) were moved to a new default location for better Windows 7 support
- Detroit Transmission (DT12) troubleshooting is now included in the tool
- Fixed MCM auto connect issue
- Fixed Chart Instrument update issue
- Crash issue resolved when Exporting parameter file, Fixed MCM auto connect issue
IMPORTANT NOTE: As the diagnostic and reprogramming software applications have evolved, the requirements for additional computer storage capacity and memory has increased. Please review these computer specifications carefully and take any necessary steps to update your hardware as needed.
Component Minimum of program Detroit Diesel Diagnostic Link 7.11:
Windows XP, Windows Vista, Windows 7, or Windows 8 (32 & 64 bit)
1.8 Ghz processor
1.0 GB RAM
40 Gigabyte Hard drive with 20 Gigabyte free
32x CD ROM Drive
Monitor and graphics card supporting 1024 x 768 resolution and 16-bit color
1 free USB port
Internet or Mainframe Connection to DDC Server (for updates)
Component Recommended of program Detroit Diesel Diagnostic Link 7.11:
IntelR Core. 2 Duo, AMD Athlon. 64X2, or equivalent
2.0+ GHz Dual-Core processor
2 GB RAM or more
100 GB hard drive with 20 GB free space
DVD ROM drive
Monitor and graphics card supporting 1280 x 1024 resolution and 32-bit color
Parallel port, three free USB ports
High Speed Internet - Broadband Internet
Before installing software DDDL 7.11/6.50 you must remove any version of Detroit Diesel software to minimize the chance of any conflicts with older versions of the software. Please use the Windows Control NEW: With this version, both DDDL 7.11 and DDDL 6.50 installed together and will share the same registration key. DDDL 6.50 cannot be used unless DDDL 7.11 is installed and registered on the same computer.
