Mike Alex
25
Ho Chi Minh City, Vietnam
7 SIGNS OF A FAILING ALTERNATOR
I. WHAT IS AN ALTERNATOR?
The alternator is a generator whose purpose is to distribute electricity to the car and recharge the battery. Outside of some hybrid models, all vehicles with a standard internal combustion engine will have an alternator. About the size of a coconut, the alternator is generally mounted to the front of the engine and has a belt running around it.
II. 7 SIGNS OF A FAILING ALTERNATOR
1. DIM OR OVERLY BRIGHT LIGHTS
When an alternator begins to fail, it provides inconsistent voltage to your electronic accessories. Generally, that takes the form of under- or over-performing equipment, such as headlights that are either too dim or extremely bright. You may also experience flickering lights or lights that erratically go from bright to dim and vice-versa.
2. DEAD BATTERY
Sometimes a dead battery is just a dead battery — it’s reached the end of its life after a few years of use — or maybe you accidentally left the headlights on all night. Other times, however, a dead battery could be a sign that your alternator is malfunctioning.
A bad alternator won’t sufficiently charge the battery while the engine is running, causing the charge to deplete faster than usual. One way to test whether the issue is battery- or alternator-related is to jumpstart the car. If you jumpstart your car and it stays running, your battery may need replacing soon. However, if you jumpstart the car and it dies again shortly after, it might mean your alternator isn’t getting enough power to the battery.
3. SLOW OR MALFUNCTIONING ACCESSORIES
An alternator that isn’t supplying enough power to your car’s electronics often results in slow or non-working accessories. If you notice your windows taking longer than usual to roll up or down, or if your seat warmers feel “off”, or even if your speedometer and other instruments start going haywire, you may have an alternator problem.
Many modern vehicles also have a priority list of equipment programmed into the car that tells the onboard computer where to cut power first if the alternator isn’t supplying enough electricity. That way, if you’re driving with a failing alternator, you’ll lose power to your radio (or other nonessential accessories) before losing power to your headlights.
4. TROUBLE STARTING OR FREQUENT STALLING
As previously mentioned, trouble starting your engine might mean that your alternator is failing to charge the battery. This means that when you turn the key in the ignition, all you'll hear is a clicking sound instead of the purr of your engine.
On the other hand, if your car is frequently stalling out while driving, it may be a sign that the spark plugs aren’t getting enough power from the alternator to keep the engine running.
5. GROWLING OR WHINING NOISES
Cars make a ton of odd sounds — some are harmless while others can indicate serious mechanical problems. If you ever hear growling or whining noises coming from under the hood, you could have alternator problems, which should be checked out by a professional ASAP.
This growling or whining sound happens when the belt that turns the alternator’s pulley becomes misaligned or rubs against the side of the pulley. You may also hear this sound if the bearings that spin the rotor shaft are going bad
6. SMELL OF BURNING RUBBER OR WIRES
A foul odor of burning rubber or wires could indicate that parts of your alternator are starting to wear out. Because the alternator’s drive belt is under constant tension and friction — and because it’s close to the hot engine — it may wear out over time and emit an unpleasant burning rubber smell.
Similarly, if your alternator is being overworked or if it has frayed or damaged wires, you may smell a burning odor comparable to an electrical fire. An overworked alternator tries to push too much electricity through its wires, causing them to heat up unsafely. Damaged wires also create resistance to the flow of electricity, causing the wires to heat up and emit a foul odor.
7. BATTERY WARNING LIGHT ON DASH
When the battery warning light pops up on the dashboard, it’s commonly mistaken to be a battery-specific issue. However, the battery warning light indicates that there could be a problem within the wider electrical system of your car, including the alternator.
Alternators are designed to work at a specific voltage, typically between 13-14.5 volts. If your alternator is failing, its voltage may drop below capacity, causing the battery warning light to appear on your dash. Similarly, the battery light will also appear if the alternator is exceeding its voltage limit, depending on how much stress it is under.
Depending on the electrical load from your car’s accessories (headlights, wipers, radio, etc.), you may see the battery warning light flicker on and off as the alternator fluctuates in and out of its intended voltage capacity. While this may seem like a minor annoyance, it’s better to bring your car in for an alternator inspection rather than wind up stuck on the side of the road.
HeidiForge
7
3
Hungary
Excellent site This is a good spot for informing unique and quality helpful tips. The web-site is extremely shocking and will help me with my ideas. I saved this forum and will visiting often for new information. I came upon the info that I had already looked everywhere and just couldn't locate. What a great spot. On my weekends I am forever studying <span style=color:#000>metal roofers in flagstaff</span>.
