Volvo Skid Steer Loader MC60C Service and Repair Manual​
Total Size:
51.46 MB
Language:
English
Brand:
Volvo
Machine Type:
Skid Steer Loader
MC60C
Manual Type:​
  • Hydraulic and Electrical Diagrams
  • Service and Repair Manual
Total Number of Pages: 3971 Pages​
Content:
1.MC60C
Air cleaner dust valve, changing'
Air conditioning filters, changing
Alternator belt, checking
Alternator, installing
Alternator, removing
Alternator, testing
Axle hub, installing
Axle hub, removing
Battery isolator, checking
Battery isolator
Battery, maintenance
Battery, replacing
Boom suspension system accumulator, charging
Boom suspension system accumulator, discharging
Bucket, not level
Cab door leak
Cab door, installing
Cab door, removing
Cab gas strut configuration
Cleaning of the machine
Compressor belt, checking
Coolant level, checking
Coolant, draining
Coolant, filling
Cooling package, installing
Cooling package, removing
Description, complete machine
Door handle, replacing
Drive chain case oil level, checking 1
Drive chain case oil, changing 1
Drive chain, installing
Drive chain, removing
Drive motor, description
Drive motor, installing 1
Drive motor, removing
ECU trouble shooting
Electronic control unit (ECU), description
Engine air cleaner system integrity, checking
Engine oil filter, replacing
Engine oil level, checking
Engine oil, changing
Engine oil, draining
Engine oil, filling
Engine, installing 1
Engine, installing
Engine, removing 1
Fan reversing valve, description
Fault code list
Front end accessory drive (FEAD) belt condition, checking 1
Front end accessory drive (FEAD) belt, adjusting 1
Front end accessory drive (FEAD) belt, replacing 1
Front idler wheel, assembling
Front idler wheel, disassembling
Fuel filter element, changing
Fuel water separator, draining
Fuses
Gear pump, description
Gear pump, installing
Gear pump, removing 1
Gear pump, removing
Greasing, daily 1
Greasing, daily
Guide roller, assembling
Guide roller, disassembling
Hydraulic contamination
Hydraulic cylinders, checking
Hydraulic cylinders, description
Hydraulic oil level, checking
Hydraulic oil tank, draining 1
Hydraulic oil tank, filling 1
Hydraulic oil tank, removing
Hydraulic oil, changing 1
Hydraulic pressure, testing
Hydraulic return filter, replacing
Hydraulic service procedures
Improved Cab Door Sealing
Improved ignition switch
Improved lap bar
Improved top glass skylight seal
In-line fuel filter, changing
Left Hand Armrest Rotation
Loader arm lift cylinder, installing
Loader arm lift cylinder, removing
Loader Arm Shimming
Loader arm, installing
Loader arm, removing
Loose wheel drive motor bolts and or leaks
Main control valve, installing
Main control valve, removing
Main valve block, description
Maintenance service, every 500 hours 1
New Magnetic Flywheel Speed Sensor
New Skid Steer Loader models
Operator's platform, lowering
Operator's platform, raising
Optional precleaner available
Poor window adhesive
Rapid Assembly Hoses
Rear door, installing
Rear door, removing
Rear idler wheel, assembling
Rear idler wheel, disassembling
Relays
Road lights, description
Self level valve, description
Self level valve, replacing
Service and Maintenance Introduction
Service position 1
Service position 2
Small platform loader and transmission setup
Spark arrester, cleaning
Starter motor, installing
Starter motor, removing
Starter motor, testing
Stop pad, adjusting 1
Stop pad, adjusting
Throttle control
Tilt cylinder rod scoring
Top Window Leak
Track tension, adjusting
Transmission pump, adjusting
Transmission pump, installing
Transmission pump, removing
Tyre, replacing
Tyres, checking air pressure
Wheel nuts torque, checking
Window cracks and or breaks
Window pane, installation
Window pane, removal'
Component list, Fuses 1
Component list, Motors 1
Component list, Relays 2
Component list, Sensors 1
Component list, Solenoid valves 1
Component list, Switches 1
Explanations to hydraulic diagram descr
Hydraulic diagram 1
Hydraulic diagram 1-1
Hydraulic diagram
Hydraulic diagram
Wiring diagram 1
Wiring diagram 1-1
Wiring diagram 2
Wiring diagram 2-1
Wiring diagram 3
Wiring diagram 3-1
Wiring diagram 4
Wiring diagram 4-1
Wiring diagram 5
Wiring diagram 5-1
Wiring diagram 6
Wiring diagram 6-1
Wiring diagram 7
Wiring diagram 7-1
Wiring diagram 8
Wiring diagram 8-1
Wiring diagram 9
Wiring diagram 9-1
Wiring diagram 10
Wiring diagram 10-1
Wiring diagram 11
Wiring diagram 12
Install Instructions
Road lights kit, right hand dip, installing new 1
Charge pump, specifications
Coolant, specifications
Engine, specification 1
Engine, specifications
Fuel, lubricant and filling capacities
Fuel, specifications
Hydraulic connections, tightening torques 1
Lights, specifications
Loader pump, specifications
Positional adapters
Push lock fittings
Quick release couplings
Radio, specifications
Rapid assembly fittings
Return line filter, specifications
Tyres, specifications
Index
Hooks
2. Measuring equipment
4. Lifting equipment
6. Drifts
8. Pliers
9. Fixtures
10. Tech Tool
11. Spare parts
  • Volvo Skid Steer Loader MC60C Service and Repair Manual.txt
