You Chinese clone that after flashing says beep every second ...
or firmware in the clone for IDS84 program , and you want the software to IDS86 ...
or you have violated the data on the memory card or memory card is broken ...
WARNING ! ALL ACTION AT YOUR SOLE RISK . If you can SAVE YOUR OLD MEMORY CARD .
1. Install a clean copy of the operating system, this system must not be connected VCM2
2. Install the drivers for all devices and update system
3. Download files from the links below
4. Disable updates Disable Firewall, Disable Web
5. Set the date on your computer September 1, 2013, and disable time synchronization via the Internet.
6. Set IDSv86 on your system.
7. reboot
8. kill the following processes if they are running:
CodeServeD.exe
DetectionManager.exe
EngineeringFeedback.exe
FNPLicesingService.exe
ISUSPM.exe
ProbeTickHander
Starburst.exe
SysPage.exe
TDSNetConfig.exe
TDSNetSetup.exe
Tabman.exe
testman.exe
wuauclt.exe
XMLRegistryD.exe
9. This item is optional.
unzip the boot.zip and put it in the folder "C: \ Program Files \ ford motor company \ IDS \ system"
that is, the full name of the folder should be "C: \ Program Files \ ford motor company \ IDS \ system \ boot"
10. Apply the patch from attachments. Up to this point NOT connect device VCM2. 2nd item when using the patch (for VCM 2).
11. Reboot
12. WARNING! your device VCM2 must not connected wires.
13. Remove the side cover from VCM2 with the side where drawn Wifi, install the card 4 or 8GB depending on what was installed in your device. Commonly used
class 4 cards
14. Press the plastic button (to the quiet click) but not much, because the Chinese are very fond of buttons to break.
15. connect the +12 v supply through connector. (Continue to hold the button)
16. Wait a few seconds, the red light, but you must continue to hold the button. When a beep sounds immediately release the button.
17. Wait about two minutes (visually nothing will happen), connect the USB cord from VCM2 to computer.
18. Start Bosh VCI MANAGER. Once connected, you will see your VCM2 in recovery mode.
19. click on "Restore" button and go to drink coffee, it takes about 40 minutes.
20. after flashing VCM2 automatically reboot. (If, after repeated firmware situation BEEP 1 second, you can try to do firmware lower software version number,
eg 84 or 85)
21. Wait 2 minutes.
22. unplug all cables from VCM2
23. Restart the computer, wait for the full load and run the IDS86 (VCM2 not connected). on offer data entry, enter the dealer Ford / Mercury / Lincoln,
dealer code UR097, country Russia
24. Wait until the start IDS86 and connect the device.
25. system will install the drivers and communication protocols VCM2
Everything should work!
p.s. If you broke the paragraph 14 of the button to close the tweezers solder contacts or temporarily remote button on the wires.
If this does not help, follow instructions at the end of all the action as follows:
26. Reboot
27. Press the reset button, plug in the +12v to VCM2, wait for beep, release the reset button
28. Start IDS86 and wait until the boot
29. Connect VCM2 USB cable to the computer program IDSv86 should offer to update the firmware of the device.
30. Update the device.
31. after flashing VCM2 automatically reboot. (If, after repeated firmware situation BEEP 1 second, you can try to do firmware lower software version number,
eg 84 or 85)
32. Wait 2 minutes.
33. unplug all cables from VCM2
Now exactly Everything should work!
7. reboot
CodeServeD.exe
ISUSPM.exe
ProbeTickHander
Starburst.exe
SysPage.exe
TDSNetConfig.exe
TDSNetSetup.exe
Tabman.exe
testman.exe
wuauclt.exe
XMLRegistryD.exe
11. Reboot
class 4 cards
eg 84 or 85)
21. Wait 2 minutes.
26. Reboot
eg 84 or 85)
32. Wait 2 minutes.
