aleksey-ms
58
Ukraine
taplink.cc
Remote Install - Renault Can Clip, Reprog, Dialogys, DDT2000, Impact, Trucks Consult, LCV, Renolink
Renault Can Clip - $35
For Renault CAN Clip Alliance VCI it'll work on Windows 7/10 x32/x64
For Renault CAN Clip RLT 2002 VCI it'll work on Windows 7 x32
For Passthru - Win 10 x64
Renault Dialogys 2022 1 year - $4300
1 month - $555
1 week - $199
1 day - $55
What inside:
PR - Spare Parts
MD - Diagnostic Method
MR - Repair Method
TM - Labor Time
WD - Wiring Diagram
BT - Technical Bulletin
OTS - Recall Campaigns
ST - Special Tools
GE - Garage Equipment
REP - Periodic Revision Sheet
AG - LCV Axle Geometry
ICP - Renault Tech-Converted Product
Renault Dialogys 4.9 2019 - $35
Renault Dialogys 2018 - $29
It's the electronic version of documentation for Renault. Dialogys includes everything from repair manuals and parts catalogs for all models of cars Renault, except for vehicles up to 1996. This electronic version of the documentation. Dialogys includes every repair manual, parts catalogs for all models of the car brand Renault.
Renault DDT2000 4.0.9 + bases 2021 - $35
Renault DDT (Diagnostic Data Tool) is a program for deep diagnostics of Renault / Nissan vehicles. Allows you to diagnose all ECUs more fully than Can Clip. Also, the program contains many useful programs from developers, for example, an emulator of ECU responses.
Renault Trucks Impact 2019 online (via remote desktop) 12 months - $135
Renault Trucks Impact 2019 online (via remote desktop) 3 months - $59
Renault Trucks Impact 2019 online (via remote desktop) 1 month - $35
Renault Impact 06.2021 - $199
Renault Impact 2016 - $49
Electronic catalog of spare parts for trucks - Renault Impact contains complete information on trucks and minibusses. In the spare parts search catalog, there is information on Renault trucks. The program for finding parts works with VIN codes - there is a history of changing numbers, searching by number and the name of the part.
Renault Trucks RVI Consult online (via remote desktop) 12 months - $99
Renault Trucks Consult 2019 - $145
Renault Trucks Consult 2018 - $55
The Renault Trucks Consult Parts Catalog contains complete information on Renault trucks and minibusses. Works with VIN codes - there is a history of replacing numbers, search by number, and name of the part.
Renault Trucks LCV + Diagnostic - $75
The program for the diagnosis of trucks Renault.
Renolink 1.95 - $125
RenoLink it's the car diagnostic all systems + programming software for Renault and Dacia. It works with ELM327, ELS27, OBDLink.
Main functions:
  • Reading fault codes for all systems (engine, transmission, ABS, AirBag, electronics,...)
  • Deletion of fault codes
  • Lights off on the vehicle's dashboard
  • Resetting maintenance/oil changes
  • Real-time reading of vehicle parameters (temperatures, pressures, probes,...)
  • Reading the PIN or ISK code
  • Resetting the power steering computer
  • Programming/coding of injectors
  • Key programming/coding
  • Resetting the airbag computer
  • Flash calculator
  • And others.
Renault Euro 5-6 Software Reprogramming module + Auto configuration module + Unlock Gateway Module - $165
Renault 10 tokens - $187
Renault 2 tokens - $47
Renault Euro 5 will support for the vehicles which compliance with emission control standard 05 and above. Also, it consists the new vehicles release from 2005 to 2022 (e.g Laguna 3, Megane 3, Master 3 etc.).
Reprogramming
It involves downloading a software package to a computer (following its replacement or to update it). Computers concerned (different for each vehicle):
Injection (petrol/diesel)
Gas injection
Manual or automatic gearbox
ABS / ESP
Automatic configuration
It involves programming certain computers with the characteristics of the vehicle in which they are fitted (following replacement or certain reprogramming procedures).
Gateway unlocking
This module consists in unlocking the gateway if the vehicle is equipped with a gateway, in order to access to the calibration of the front camera or ADAS systems for example
Renault ADT Reprogramming j2534 Software - $259
Renault ADT Reprogramming License 1 month - $359
Renault ADT Reprogramming License 1 week - $187
Renault physical USB token - $75
Renault ADT contain all the operations before repair / Reprogramming / Configuration / after repair.
The ADT tool will allow:
Start the computer repair procedure which will contain all the operations before repair / Reprogramming / Configuration / after repair.
Carry out a diagnosis of the vehicle.
Resetting computer faults.
ADT eprogramming
Reprogramming consists of downloading a software package to a computer (after its replacement or update). Calculators concerned (different for each vehicle):
Injection (petrol / diesel)
Gas injection
ABS / ESP
Need it? Write to me to discuss.
