ohenry
746
79
27
ho chi minh
MAN Mantis U511 EPC Update 2014-12
Year / Release Date: 2014-12
Version: u511 v5.10.1.91
Developer: Lexcom
Interface language: Multilingual (Russian is present)
Tabletka: Present
Description: Man Mantis spare parts catalog presents spare parts for trucks, towing vehicles, Man buses, MAN engines.
In the new version of the program it allows you to enter the full VIN of the machine for identification, but determines only the model and release date of the VIN. There is a search for a picture by the original part number and the list of vehicles where the part was used, as well as the replaced part numbers, both new and old. To search for spare parts of a specific machine, you need to know the VIN or know exactly the model, the wheel formula, the center distance, the type of suspension and cab, as well as the type and modification of the engine installed on the machine. Search by VIN in the program is implemented as follows. You can enter a full VIN or use 4 to 6 characters of VIN to determine the type (up to five characters enter the zero) and from 7 to 10 characters to determine the chassis number, you can also select the type and number of the chassis from the list of possible options. All other data indicate require searching directly on the machine.
The abbreviation MAN stands for Augsburg and Nuremberg engineering plants. The company "MAN" was founded in 1915 and is one of the largest manufacturers of vehicles, including buses, as well as components for their assembly (bridges, gearboxes, engines, cabs).
Add. Information: if, after successful launches, it starts swearing at Hardlock - it is enough to restart the emulator using "restart.cmd"
  • MAN Mantis U511 EPC Update 2014-12.txt
  • Like
Reactions: Auto Library
