Jungheinrich ForkLift ETV 214 EPC & Operating Manual [10.2010]
10.2010 / All Regions / 1 CD / Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP / 32 & 64 bit
Jungheinrich ETV 214 spare parts manual + operating manual
Parts manual:
ETV 214
Operating instructions:
ETM/V 214-325
Languages: English, German, Spanish, Italian, Russian, Polish, Finnish and others
Parts manual information:
Frame and superstructure
Electric drive unit
Wheels / Axis
Steering system
Hoist frame / Load lifting device
Connection chassis / Load lifting device
Hydraulic system
Electric system
Battery / Charger
Miscellaneous
Operating instructions information:
Correct application
Approved application conditions
Proprietor responsibilities
Adding attachments and/or accessories
Truck Description
Application
Assemblies and Functional Description
Truck
Load handling
Standard Version Specifications
Performance Data
Dimensions
Standard mast version dimensions
Weights
Wheels/tyres
Battery
Hydraulics
Mast weights
EN norms
Conditions of use
Electrical requirements
Identification points and data plates
Truck data plate
Truck load chart (capacity)
Attachment load chart
Stability
Transport and Commissioning
Transport
Lifting by crane
Lifting the basic truck by crane
Lifting the basic truck and cabin by crane
Securing the truck during transport
Using the truck for the first time
Battery Maintenance, Charging & Replacement
Safety regulations for handling acid batteries
Battery types
Exposing the battery
Charging the battery
Battery removal and installation
Operation
Safety Regulations for the Operation of Forklift Trucks
Controls and Displays
Starting up the truck
Entry and exit
Setting up the operator position
To prepare the truck for operation
Emergency stop device
Testing after daily operation
Industrial Truck Operation
Safety regulations for truck operation
Procedure in extraordinary situations
Emergency Disconnect
Travel, steering, braking
Adjusting the forks
Lifting and depositing loads
Emergency lowering (-10/07)
Emergency lowering (10/07-)
Operating Attachments
Parking the truck safely
Driver’s display (t)
Driver’s Display LED Buttons
Driver Display Switches
Driver’s Display Warning Messages
On board computer
On board computer display symbols
Keypad (CANCODE)
Code Lock
Parameters
Parameter Settings
ISM
Changing truck parameters
Troubleshooting
Moving the truck without a battery, recovery
Optional equipment
Headlights
Beacon / strobe
Limit switch system / electrical lift limit switch
Seat heating
12 V DC / 24 V DC transformer
180°/360° steering angle display
Sideshift centre position
Forks horizontal button
Weigher
Clamp button
Weatherproof cab
Parabolic mirror
Removable load backrest
Rack Height Select
ISM access module
Assembly and hydraulic ports of additional attachments
Industrial Truck Maintenance
Operational Safety and Environmental Protection
Maintenance safety regulations
Servicing and Inspection
ETM/V 214-325 Maintenance Checklist
ETM/V 214-325 Maintenance Schedule
Lubricants and Lubrication Schedule
Consumables
Reservoir capacity
Maintenance Instructions
Preparing the truck for maintenance and repairs
Remove seat panel
Check the hydraulic oil level
Opening the fuse cover
Opening the instrument panel cover
Checking electrical fuses
Checking the wheel attachments
Recommissioning
Decommissioning the industrial truck
Prior to decommissioning
During decommissioning
Returning the truck to operation after decommissioning
Safety checks to be performed at regular intervals and following any unusual incidents
Final de-commissioning, disposal
Human vibration measurement
Parts manual:
ETV 214
ETM/V 214-325
Electric drive unit
Wheels / Axis
Steering system
Hydraulic system
Electric system
Battery / Charger
Miscellaneous
Correct application
Truck Description
Application
Truck
Load handling
Performance Data
Dimensions
Weights
Wheels/tyres
Battery
Hydraulics
Mast weights
EN norms
Conditions of use
Truck data plate
Stability
Transport
Lifting by crane
Battery types
Operation
Entry and exit
Adjusting the forks
On board computer
Keypad (CANCODE)
Code Lock
Parameters
Parameter Settings
ISM
Troubleshooting
Optional equipment
Headlights
Beacon / strobe
Seat heating
Weigher
Clamp button
Weatherproof cab
Parabolic mirror
Rack Height Select
ISM access module
Consumables
Reservoir capacity
Remove seat panel
Recommissioning
