80
TOYOTA INNOVA REMOTE KEY FOB PROGRAMMING
- Key removed from the ignition
- Drivers door open, all other doors closed
- Insert key into ignition then remove it – do this twice
- Close and Open drivers door twice
- Insert the key into the Ignition then remove it
- Close the door and Insert key into the ignition
- Turn ignition from off to on and back to on – once to add a new remote while retaining the original remotes, and twice to erase original remotes
- Remove the key from the ignition cylinder (Locks will cycle once for adding remote, and twice if erase mode was selected)
- Press the Lock and Unlock Buttons on the remote at the same time for 1 second
- Press any button on the remote (Door locks will cycle once if programming is correct, and twice if unsuccessful)
- To close procedure open drivers door and insert key into the ignition
