Status
Not open for further replies.
DHTAuto Support
270
71
31
Singapore
Prodemand Online 2023
1. What is Prodemand Online?
The last offline version of Ondemand software was 2015, since then Ondemand no longer updates the Offline version, but switched to Online version which more convenient, newer, and more feature.
With the Prodemand online version. You can completely look up any data you want directly on the website. The only thing you need to use Prodemand Online is the Internet, as long as you have internet, you can access Prodemand Online whenever and wherever.
With an Prodemand online, you have all the repair information you need: circuit diagrams, component location, specifications, disassembly, reassembly instructions, DTC repair instructions, maintenance information, TSB… for 1 year.
2. Prodemand Online account information
Duration of use: 1 year
Supported device: Computer use Window OS with Internet Access
Supported models: Mainly US market
Supported year: from 1960 to the latest current is 2023
3. The features of Prodemand Online
With Prodemand Online will support you with the following features:
Vehicle identification by VIN: you just need to enter the VIN number, the software will automatically identify the vehicle for you (applicable to US market cars)
Search by part name, part number: with powerful search function, you can find anything you want, the software will show you the details.
– DTC troubleshooting guide
Wiring diagrams: Both diagram versions are supported:
+ OEM diagram version: Version of the manufacturer’s diagram: this version Prodemand is taken directly from the manufacturer’s diagram without any editing: a bit difficult to read but very accurate, suitable for experienced people and used to.
+ Non-OEM diagram version: Same as the OEM version but redesigned by Prodemand: easy to read and understand, if the OEM version is about 7-8 pages long, then this version is redrawn and reduced to about 2-3 pages by the Prodemand. Suitable for new user, inexperienced in reading circuit diagrams or for diagrams of hard-to-read brands such as Audi, Mercedes, etc., everything will become much simpler.
– Components location, connector views, ground, power distribution and splice information.
– Technical specifications.
– Removal (Disassembly), installation (reassembly) instruction, overhaul instruction
– Manufacturer Technical Service Bulletin (TSB) and Recalls
– Parts number, labor time
– Maintenance schedules
  • PRODEMAND2023.txt
Status
