80
Product description
Detroit Diesel Diagnostic Link 7.11/6.50
The main features of the diagnostic program Detroit Diesel Diagnostic Link 7.11/6.50 is to provide services for Detroit Diesel EPA07, EPA10 and GHG14 equipped engines (S- 60 , MBE4000, MBE900, DD13, DD15, DD16).
Note: The program DDDL 7.11 / 6.50 is not backward compatible with earlier versions of Detroit Diesel electronic systems. These systems will continue to be serviced with DDDL 6.x. DDEC electronic system contains two controllers, the MCM (engine control module) and CPC (Common Powertrain Controller). The system includes DDEC10 MCM, PDAs and ACM (Rehabilitation Management Module).
DDDL 7.11 enables the user to perform the following standard operations on both platforms engines:
1- Perform Standard Fault Code Operations
2- Links to Traditional and Advanced Troubleshooting Information
3- Read Actual Values
4- Configure and Manage Parameters
5- Perform Service Routines
6- Playback Logs of All Connected Activity
7- Automatic Software Updates from our server
System Requirements
IMPORTANT NOTE: As the diagnostic and reprogramming software applications have evolved, the requirements for additional computer storage capacity and memory has increased. Please review these computer specifications carefully and take any necessary steps to update your hardware as needed.
Minimum components:
Windows XP, Windows Vista, Windows 7, or Windows 8 (32 & 64 bit)
1.8 Ghz processor
1.0 GB RAM
40 Gigabyte Hard drive with 20 Gigabyte free
32x CD ROM Drive
Monitor and graphics card supporting 1024 x 768 resolution and 16-bit color
1 free USB port
Internet or Mainframe Connection to DDC Server (for updates)
Hardware Adapter Device (One of the following):
- Nexiq MagiKey device with parallel cable
- Nexiq USB-Link with USB cable (Required for Cascadia diagnostics)
- Laptops purchased from Detroit Diesel beginning in August 2006 meet the minimum specifications. Any purchase prior to this time may need to be upgraded. As of May 1, 2011, Detroit Diesel discontinued offering the Dell Laptop.
Recommended components:
IntelR Core. 2 Duo, AMD Athlon. 64X2, or equivalent
2.0+ GHz Dual-Core processor
2 GB RAM or more
100 GB hard drive with 20 GB free space
DVD ROM drive
Monitor and graphics card supporting 1280 x 1024 resolution and 32-bit color
Parallel port, three free USB ports
High Speed Internet - Broadband Internet
Hardware:
Adapter device (One of the following)
Note: Bluetooth functionality NOT approved at this time
Operating System Windows XP, Windows Vista, Windows 7, or Windows 8 (32 & 64 bit)
Translator box / cables requirements - Here are some key general points to remember when connecting to the MCM, ACM and CPC with DDDL 7.11:
1 - For DDDL 7.11 the only translator box fully validated with Detroit Diesel software applications is the Nexiq USB Link, which is RP1210A compliant with J1939 and CAN connectivity. (P/N 125032) Translators that support J-1708 communication only will not work with DDDL 7.11 under any circumstances.
2 - All EPA07 vehicles contain a 9-pin Deutsch connector wired to support J-1939/ CAN communications and J-1708 communications. EPA10 vehicles support J1939/CAN exclusively.
3 - All operations may be carried out on a vehicle that has both the MCM and CPC properly installed.
Note: There must be a CPC physically present on the vehicle in order for communications to be established with the MCM.
4 - When plugging into the 9 pin Deutsch connector on the vehicle you must see mating 9-pin connector fully wired to support J-1939 / CAN communications. The old style 6 to 9-pin Deutsch adapter will not work.
5 - Diagnostic adapters that will work with the DDEC VI/DDEC10 system include P/N 405048 (6 and 9-pin ¡§Y¡¨ adapter) and P/N J-46931, the J1939 9-pin Deutsch Connector that was part of the DDEC V programming station upgrade kit.
Installing DDDL 7.11
Before installing DDDL 7.11 you must remove any version of Detroit Diesel software to minimize the chance of any conflicts with older versions of the software. Please use the Windows Control Panel. Add / Remove Software option to perform this operation.
NEW: With this version, both DDDL 7.11 and DDDL 6.50 installed together and will share the same registration key. DDDL 6.50 cannot be used unless DDDL 7.11 is installed and registered on the same computer.
  • Detroit Diesel Diagnostic Link 7.116.50 Full Keygen !.txt
