• YouTube
  • Facebook
  • Twitter
  • Google +
Cummins INSITE v8.0 Full
Discussion in 'Diagnostic' started by HerculesCraven, Nov 21, 2018.
  1. HerculesCraven
    HerculesCraven Super Moderators
    Jan 9, 2016
    1,439
    86
    What is Cummins INSITE:
    Cummins INSITE is a Windows software application that works with Cummins Electronic Control Modules (ECMs) to diagnose engine problems, store and analyze historical information about an engine, and modify parameters of engine operation. Cummins INSITE also allows you to download an ECM calibrations to working with Cummins INCAL.
    Insite 8.x Laptop requirements:
    • O.S.: Windows XP, Windows Vista, Windows 7, Windows 8, Windows 8.1
    • CPU: Pentium/Athlon 2 GHz or higher
    • RAM: 512 MB of system memory
    • Hard Drive: 10 GB of available space
    • Optical Drive: DVD-ROM
    • Size: 1,94Gb
    • Language: English
    • 1 DVD ISO
    • Year / Release Date : 2015
    • Version : 8.0.0.402
    • System requirements : Windows 7 or higher
    • Language : Multilanguage
    INSITE 8.0.2 Released Notes:
    • Installations upgrade capability
    • Upgrade from INSITE 8.0.1
    • Work Orders
    Images and Templates
    Beginning with INSITE version 8.0.1, images or templates imported from later versions of INSITE will be highlighted in the Work Order window.
    For Example: If templates or images from INSITE 8.0.2 are imported into INSITE 8.0.1, those images or templates will be highlighted. When hovering over those images or templates, an informative message will be displayed.
    ECM Image Analyzer
    To open this new feature Right-Click on any image and select ‘Analyze Image’ to open. This can be used to view key features of an image and contains improved graphics. The current feature, or all features, can be exported to Adobe (pdf) or Excel (xlsx) file formats.
    For Example: Duty Cycle Monitor will show a 3-D, multi-colored graph, and it can be rotated using the mouse.
    New Features and Parameters
    ***These will only be displayed if they are supported by the calibration.
    Crankcase Pressure Speed Derate
    This feature provides the ability to enable the crankcase pressure speed derate as partof the Engine Protection special feature.
    Inducement Override Switch
    This feature provides the ability to enable the Inducement Override Switch.
    Engine Oil Level
    This feature provides the ability to set the Engine Oil Level sensor type.
    Driver Reward Distance Reset
    This feature expands Driver Reward to include the ability to reset Driver Reward every time the engine is turned off as well as to configure the distance the driver reward can be applied.
    Multiple Load Based Speed Control Limit
    This feature expands User Adjustable Fuel Economy to configure the minimum and maximum breakpoint speed offsets.
    SAE J1939 Multiplexing
    This feature has been updated to include the following parameters: Machine Interlock Switch, Desorb inhibit, and Inducement Override Switch.
    Load Based Acceleration Control
    This feature provides the ability to limit the engine acceleration.
    OEM Simple Lockout
    This feature provides the ability to derate engine speed or prevent the engine from starting when used with OEM hardware.
    Cruise Control Type
    This feature expands Cruise Control to configure the different cruise control types to achieve the desired fuel economy.
    Intelligent Coast Management
    This feature expands Cruise Control to allow the vehicle to coast further during low torque demand when the driveline is disengaged.
    This feature name has been modified:
    Feature name prior to 8.0.2 Feature name starting with 8.0.2
    Coolant Level Sensor Engine Coolant Level Sensor 2
    Advanced ECM Data
    Engine Protection and Engine Protection Settings
    These features have been updated to include Crankcase Pressure, Boost Pressure Differential and Bank Vacuum Detection information.
    Fuel or Timing System Table Reset Component Replacement
    This feature allows the adaptive learning table values to be reset after fuel or engine timing
    components have been replaced.
    Operating Systems Supported
    • Windows® 7 32-bit and 64-bit
    • Windows® 8 32-bit and 64-bit
    Cummins-INSITE-v8.0-1.png Cummins-INSITE-v8.0-2.png Cummins-INSITE-v8.0-3.png Cummins-INSITE-v8.0-4.png Cummins-INSITE-v8.0-5.png Cummins-INSITE-v8.0-6.png Cummins-INSITE-v8.0-7.png Cummins-INSITE-v8.0-8.png
    • Cummins INSITE v8.0 Full.txt
      Fee: 2500 beer
      Your beer : 0
      Login for download
Share This Page
