disinfetor
44
de
PLEASE READ THIS TEXT UNTIL THE END. ALMOST EVERY INFORMATION IS HERE, DONT PM ME FOR HELP AND THE ANSWER ALLREADY HERE. FOR HELP ASK HERE!
This is the next edition of the unique native running Universal Xentry/DAS System without needing any pc virtualization.
It is a portable system with lot of MB stuff. A Windows 10 based system installed in a dynamic VHDX-File, which can be located everywhere (USB, or Hard disk) and booting natively by a boot-loader (on a USB-Stick or local hard disk). So no change to the running system and without the need for any virtual PC’s.
FEATURES:
+No need for to make any change on the laptop you will use. You don’t even need to have a hard-disk in the laptop!
+No need for separate hard-disks for each diagnosis System.
+No need to be worried if the laptop has an irreparable software or hardware error, as it will not run.
+No need to split your hard-disk to many annoying partitions.
+No need to mix up your hard-disk with many Windows versions.
+No need to waste unused space on each system, when you can place data on a common partition.
+No need to be worried about having any unwanted changes to the diagnosis system from someone else, as it has built in protect sandbox-functions.
+No need to fear from ruining your laptop system when removing or replacing the diagnosis system.
+No need for big hard-disk storage for huge vmware files, when you only need to have DAS/Xentry (27GB)
+No need for virtual PCs anymore!
+No need for powerful CPS’s anymore!
+No need for driver configurations at host system anymore!
Hardware Requirements:
-Any laptop with BIOS or UEFI boot.
-HDD, SSD, External-USB-Drive, or USB-Stick.
-30GB space for the basic edition, and up to 100GB with all packages.
-Windows OS: 2000, XP, Vista, 7, 8, 8.1 and 10.
-Linux is also possible using chain loading to a grub4dos bootloader.
-Install time is ~20 minutes for the installation of the basic edition (may vary according to the hardware you have).
-Install time is ~ 1 hour for all packages (time may vary according to the hardware you have)
- Supports both Mux: C3 (serial RS232 COM2) and SDconnect C4
Known issues and limitations:
-Still working on the “hhtwin” so it’s not available yet.
-Don’t change the files structure! e.g. change, copy, move the partitions or the files inside. The protection software is very sensitive to such file activities. So don’t make any fundamental changes to the system without informing me please!
-The VHDX file is dynamic in size. That means it grows from 27GB as you add more data up to 100GB. Be sure the disk has enough free space on the host drive to be able to expand. It is like a balloon in a box. If you try to expand the balloon further, the balloon will explode, and the VHDX will get corrupted!
The Software Installation has 3 parts:
- VHD-file: This is the base system, containing Windows 10 and the basic MB software.
- Boot-loader: This is required to get the base system loaded and running.
- Add-on-Packages: These are the files for the MB software packages such as WIS, EPC, and SDmedia etc.
After the Boot-loader restart the system twice as the first boot will detect changed hardware (it takes time) and the second reboot installs all the drivers. See the folder "may need" on the desktop.
The keys (Xentry/DAS/WIS/EPC) are hardware related, so you will need to insert new keys each time you use this system with new hardware for the first time. (Also see “may need” folder).
LICENCING MODEL, via Request and Responce Codes. Licence Codes are Hardware dependent and work only on that hardware. SEE VIDEO NO2
Anyone who obtained the S/W without my permission is under the risk of the reaction of the many build-in software protections.
When it detects that you are a leecher, your car may get damaged by silently manipulating car ECU files, and you will not even notice that! So, YOU'VE BEEN WARNED! SO PLEASE DON’T SHARE THE SOFTWARE! DON’T SHARE THE DOWNLOAD LINK! DON’T MAKE MIRRORS! BE FAIR, AND BE SAFE!
The Basic Edition:
(you may use this to test, it is only 17GB to download)
1. AIO MB LiveDiagSys VHD-File (XentryDas only cars)
2. Boot-loader Installer
The Silver edition:
1. AIO MB LiveDiagSys VHD-File (XentryDas but only for cars)
3. Add-on Packages:
+ Disassembly Assistant
+ Offline Parts Price List 06.2015
+ Vediamo 5.0.0.6
+ WIS-ASRA 10.2015
The Gold edition:
3. Add-on Packages:
+ XentryDAS with all remaining vehicles
+ Vediamo 5.0.0.6
+ WIS-ASRA 10.2015
+ Dis's MB Computer Based Training CDs Collection
+ Dis's MB Technical Information Collection
+ dis's MB Vintage Service Manual Library
+ Star Finder 2009 Dis’s Edition.
+ EPC 09.2015
+ SDmedia
Please visit the download link regularly for updates!
Donate if you like my work and want it to continue. Paypal:-> disinfetor@web.de
All donations left from costs will be given to a government-approved local charity organisation.
(please donate as to a friend, else paypal takes fees)
Presenting the Aio MB UnivLiveDiagSystem win10 v0.89
Howto Activate Licence when Installing:
Installation videos are time lapsed but it took around 20minutes, to have a running Xentry system.
How to install the new AIO SW to Windows 2000, XP and 7:
(PS: No password anymore, now online activating method)
How to install AIO SW to Windows 8, 8.1 and 10
How to install the new AIO SW to a different drive as standalone (without any previous Windows on it):
Some videos (shown is the old XP 7-2014 but is similar)
https://www.youtube.com/watch?v=bdfMu0xAvoU
and a video of QuickTest:
https://www.youtube.com/watch?v=YRB1b8nE6Ec
https://www.youtube.com/watch?v=sE23LzM6Lmc
Registration for keys use: dis.internetservices4all.com
-Please first register with a working email, else you will not get te response key.
-After registration you can get the responce key for the request key immediately. If you have your email correct and no email with the key, then check your spam folder. If not worked, use another email.
  • dhauto-DL-92015r1-basic.txt
  • dhauto-DL-92015r1 - silver.txt
  • dhauto-DL-92015r1 - gold.txt
