• YouTube
  • Facebook
  • Twitter
  • Google +
TOYOTA RAV4 SERVICE & REPAIR MANUAL UPDATE 2008
Discussion in 'Service and Repair Manuals' started by Patrick, Sep 22, 2015.
  1. Patrick
    Patrick New Member
    Jun 8, 2015
    94
    3
    TOYOTA RAV4 2005 - 2008 SERVICE & REPAIR INFORMATION MANUAL
    Code:
    Product Code: Toyota
    Availability: In Stock
    Update : 11.2005 - 11.2008
    Market : All Regions
    Qty : 1 CD
    Toyota RAV4 Service information library 11.2005 - 11.2008
    ACA30, ACA33, ACA38, ALA30 series
    Engines:
    2AD-FHV - 2.2L 4cylinder D-CAT 16 Valve DOHC turbo diesel
    2AD-FTV - 2.2L 4cylinder D-4D 16 Valve DOHC turbo diesel
    1AZ-FE - 2.0L 4cylinder 16 Valve DOHC
    2AZ-FE - 2.4L 4cylinder 16 Valve DOHC
    New car features
    Electrical wiring diagram
    Body Repair
    Service data sheet
    REPAIR MANUAL
    ENGINE
    ENGINE CONTROL SYSTEM
    2AD-FHV - ECD system, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Diesel throttle body, IG1 relay, IG2 relay, ECM, Manifold absolute pressure sensor, Accelerator pedal rod
    2AD-FTV - ECD system, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Diesel throttle body, Integration relay, IG1 relay, IG2 relay, ECM, Manifold absolute pressure sensor, Accelerator pedal rod
    1AZ-FE - SFI system, Mass air flow meter, Camshaft timing oil control valve assembly, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Throttle body, Knock sensor, Integration relay, IG1 relay, IG2 relay, Circuit opening relay, ECM, Accelerator pedal rod
    2AZ-FE - SFI system, Mass air flow meter, Camshaft timing oil control valve assembly, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Throttle body, Knock sensor, Integration relay, IG1 relay, IG2 relay, Circuit opening relay, ECM, Accelerator pedal rod
    ENGINE MECHANICAL
    2AD-FHV - Engine, Drive belt, Engine assembly, Engine unit
    2AD-FTV - Engine, Drive belt, Engine assembly, Engine unit
    1AZ-FE - Engine, Drive belt, Valve clearance, Timing chain, Cylinder head, Engine assembly, Engine unit
    2AZ-FE - Engine, Drive belt, Valve clearance, Timing chain, Cylinder head, Engine assembly, Engine unit
    FUEL
    2AD-FHV - Fuel system, Fuel injector, Fuel supply pump, Common rail, Fuel filter, Injector driver, Fuel tank
    2AD-FTV - Fuel system, Fuel injector, Fuel supply pump, Common rail, Fuel filter, Fuel cooler, Injector driver, Fuel tank
    1AZ-FE - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pressure pulsation damper, Fuel pump, Fuel tank
    2AZ-FE - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pressure pulsation damper, Fuel pump, Fuel tank
    EMISSION CONTROL
    2AD-FHV - Emission control system, EGR valve, EGR cooler, Exhaust fuel addition injector, Exhaust manifold converter, Vacuum switching valve, Air fuel ratio sensor, Differential pressure sensor, Exhaust gas temperature sensor
    2AD-FTV - Emission control system, EGR valve, EGR coller, Fuel tank cap
    1AZ-FE - Emission control system, Canister, Vacuum switching valve, Ventilation valve, Air fuel ratio sensor, Heated oxygen sensor, Fuel tank cap
    2AZ-FE - Emission control system, Canister, Vacuum switching valve, Ventilation valve, Air fuel ratio sensor, Heated oxygen sensor, Fuel tank cap
    INTAKE / EXHAUST
    2AD-FHV - Intake air control system, Vacuum regulating valve, Turbocharger, Intercooler, Exhaust pipe
    2AD-FTV - Intake air control system, Vacuum regulating valve, Turbocharger, Intercooler, Exhaust pipe
    1AZ-FE - Exhaust pipe
    2AZ-FE - Exhaust pipe
    COOLING
    2AD-FHV - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Fan motor, Fan relay, Radiator
    2AD-FTV - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Fan motor, Fan relay, Radiator
    1AZ-FE - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Fan motor, Fan relay, Radiator
    2AZ-FE - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Fan motor, Fan relay, Radiator
    LUBRICATION
    2AD-FHV - Lubrication system, Oil filter, Oil pump, Engine Oil cooler
    2AD-FTV - Lubrication system, Oil filter, Oil pump, Engine Oil cooler
    1AZ-FE - Lubrication system, Oil filter, Oil pump, Engine oil cooler
    2AZ-FE - Lubrication system, Oil filter, Oil pump, Engine oil cooler
    IGNITION
    1AZ-FE - Ignition system, Ignition coil
    2AZ-FE - Ignition system, Ignition coil
    STARTING
    2AD-FHV - Starting system, Pre-heating system, Entry and start system, Glow plug, Starter, Starter relay, Glow relay, Engine switch, Ignition switch
    2AD-FTV - Starting system, Pre-heating system, Entry and start system, Glow plug, Starter, Starter relay, Glow relay, Engine switch, Ignition switch
    1AZ-FE - Starting system, Entry and start system, Starter, Starter relay, Engine switch, Ignition switch
    2AZ-FE - Starting system, Starter, Starter relay, Ignition switch
    CHARGING
    2AD-FHV - Charging system, Generator, Battery current sensor
    2AD-FTV - Charging system, Generator, Battery current sensor
    1AZ-FE - Charging system, Generator, Battery current sensor
    2AZ-FE - Charging system, Generator, Battery current sensor
    TRANSMISSION
    U140F Automatic Transaxle - Automatic transaxle system, Fluid, Speed sensor, Park / Neutral position switch, Transmission wire, Valve body assembly, Shift lock system, Oil cooler, Transmission control cable assembly, Floor shift assembly, Differential oil seal, Automatic transaxle assembly, Torque converter and drive plate, Transaxle unit, Oil pump, Second brake piston, Forward clutch, Direct clutch, Underdrive planetary gear, Underdrive clutch, Valve body, Differential case
    U241E Automatic Transaxle - Automatic transaxle system, Fluid, Speed sensor, Park / Neutral position switch, Transmission wire, Valve body assembly, Shift lock system, Oil cooler, Transmission control cable assembly, Floor shift assembly, Differential oil seal, Automatic transaxle assembly, Torque converter and drive plate, Transaxle unit, Oil pump, Second brake piston, Forward clutch, Direct clutch, Underdrive planetary gear, Underdrive clutch, Valve body, Differential case
    Clutch - Clutch system, Clutch pedal, Master cylinder, Release cylinder, Clutch accumulator, Clutch unit, Clutch start switch, Clutch start cancel switch
    E352 Manual Transaxle - Manual transaxle system, Oil, Differential oil seal, Floor shift lever assembly, Transmission control cable, Back up light, Transaxle assembly, Transaxle unit, Input shaft, Output shaft, Shift and select lever shaft, Differential case
    E352F / E359F Manual Transaxle - Manual transaxle system, Oil, Differential oil seal, Floor shift lever assembly, Transmission control cable, Back up light, Transaxle assembly, Transaxle unit, Input shaft, Output shaft, Shift and select lever shaft, Differential case
    EA64F Manual Transaxle - Manual transaxle system, Oil, Differential oil seal, Floor shift lever assembly, Transmission control cable, Back up light, Transaxle assembly, Transaxle unit, Input shaft, Output shaft, Shift and select lever shaft, Differential case
    DRIVE LINE
    GF1A Transfer - Transfer system, Active torque control 4WD system, Oil, Case oil seal, Transfer assembly, 4WD control ECU
    Propeller Shaft - Propeller shaft system, Propeller shaft assembly
    Drive Shaft - Drive shaft system, Front drive shaft assembly, Rear drive shaft assembly
    Differential - Differential system, Differential oil, Rear differential side gear shaft oil seal, Diaphragm oil seal, Rear differential carrier assembly
    SUSPENSION & AXLE
    Axle - Axle system, Front axle hub bolt, Front axle hub, Rear axle hub bolt, Rear axle hub and bearing
    Suspension - Suspension system, Front wheel alignment, Rear wheel alignment, Front shock absorber, Front suspension lower arm, Front lower ball joint, Front stabilizer bar, Rear coil spring, Rear shock absorber, Rear upper control arm, Rear suspension arm, Rear trailing arm, Rear stabilizer bar
    Tire and Wheel - Tire and wheel system, Tire pressure warning system
    BRAKE
    Brake Control - Anti lock brake system, Vehicle stability control, Brake actuator, Front speed sensor, Skid control system, Rear speed sensor, Yaw rate and deceleration sensor, Steering angle sensor, Downhill assist control switch
    Brake - Brake system, Fluid, Brake pedal, Master cylinder, Brake booster, Vacuum pump, Front brake, Front brake flexible hose, Rear brake, Rear brake flexible hose
    Parking Brake - Parking brake system, Parking brake lever, Parking brake cable, Parking brake assembly
    STEERING
    Steering Column - Steering system, Steering lock system, Steering column assembly
    Power Steering - Electronic power steering system, Steering gear, Power steering ECU
    HEATER & AIR CONDITIONING
    Air Conditioning - Air conditioning system, Refrigerant, Refrigerant line, Air conditioning unit, Blower unit, Blower resistor and motor, Control servo motor, PTC heater assembly, Compressor and pulley, Condenser, Evaporator temperature sensor, Temperature sensor, Solar sensor, Heater relay, Air conditioning control assembly
    Heater - Heater switch, Heater assembly
    RESTRAINTS
    Supplemental Restraint System - Airbag system, Steering pad, Spiral cable, Driver side knee airbag assembly, Front passenger airbag assembly, Curtain shield airbag, Front seat side airbag, Center airbag sensor assembly, Front airbag sensor, Seat position sensor, Airbag cut off switch
    Seat Belt - Seat belt warning system, Front seat inner belt assembly, Front seat outer belt assembly, Rear seat inner belt assembly, Rear seat outer belt assembly, Rear center seat outer belt assembly, Child restraint seat tether anchor
    SECURITIES
    Theft Deterrent - Theft deterrent system, Engine hood courtesy switch
    Engine Immobiliser - Engine immobiliser system, Unlock warning switch
    CRUISE CONTROL SYSTEM
    Cruise Control - Cruise control system, Cruise control main switch
    BODY ELECTRICAL
    Lighting, Wiper and Washers, Door Lock, Meter, Audio / Visual, Navigation, Park Assit/Monitoring, Horn, Other systems
    BODY
    Windshield / Windowglass, Mirror, Instrument Panel, Seat, Engine Hood / Door, Exterior, Interior, Sliding Roof
    COMMUNICATION SYSTEM
    CAN Communication
    NEW CAR FEATURES
    New model outline - Exterior appearance, Exterior, Interior, Equipment, Safety, Performance
    Engines
    Chassis - Clutch, E352, EA64F, E352F / E359F Manual Transaxles; U140F,U241E Automatic Transaxles; Transfer, Drive shaft and Propeller shaft, Rear differential, 4WD system, Suspension & Axle, Tire pressure warning system, Brake, Steering
    Body - Body structure, Enhancement of product appeal
    Body electrical - Multiplex communication, Lighting, Meter, Wiper and Washer, Air conditioner, Navigation system with AV system, Power window system, Smart entry and Start system, Door lock control system, Engine immobilizer, Theft deterrent, SRS airbag, Seat belt reminder, Cruise control, Power seat, Seat heater, Front wiper deicer, Headlight cleaner, Sliding roof, Audio system
    ELECTRICAL WIRING DIAGRAM
    Engine - Charging, Engine control, Entry and Start system, Ignition, Radiator fan and Condenser fan, Starting
    Transmission - ECT and A/T indicator, Shift lock
    Drive line - 4WD
    Suspension & Axle - Tire pressure warning system
    Brake - ABS, TRS, VSC, Downhill assist, Hill start assist
    Steering - EPS
    Heater & Air Conditioner System - Automatic air conditioner, Manual air conditioner
    Restraints - Seat belt warning, SRS
    Securities - Engine immobiliser system, Theft deterrent
    Cruise Control System - Cruise control
    Body Electrical - Audio system, Automatic light control, Back-up light, Cigarette lighter, Front fog light, Headlight, Interior light, Stop light, Navigation system, Wireless door lock control and much much more
    Body - Automatic Glare-Resistant EC mirror, Front window deicer, Mirror heater, Power heater, Power seats, Power windows, Rear window defogger, Remote control mirror, Seat heater, Sliding roof
    Communication System - Multiplex communication system
    BODY REPAIR
    TOYOTA-RAV4-SERVICE-REPAIR-MANUAL-UPDATE-2008.JPG TOYOTA-RAV4-SERVICE-REPAIR-MANUAL-UPDATE-2008-.JPG TOYOTA-RAV4-SERVICE-REPAIR-MANUAL-UPDATE-2008-1.JPG TOYOTA-RAV4-SERVICE-REPAIR-MANUAL-UPDATE-2008-2.JPG TOYOTA-RAV4-SERVICE-REPAIR-MANUAL-UPDATE-2008-3.JPG
  2. ronjerJerp
    ronjerJerp New Member
    Jan 6, 2017
Share This Page
