• YouTube
  • Facebook
  • Twitter
  • Google +
TOYOTA LAND CRUISER 200 STATION WAGON SERVICE & REPAIR MANUAL UPDATE 2015
Discussion in 'Service and Repair Manuals' started by Global Master, Sep 13, 2015.
  1. Global Master
    Global Master Vip Member
    Jun 6, 2015
    118
    15
    TOYOTA LAND CRUISER 200 STATION WAGON 2011 - 2015 SERVICE & REPAIR INFORMATION MANUAL
    Description :
    Update : 09.2011 --> 2015
    Market : All Regions
    Quantity of download file : 1 file
    Toyota Land Cruiser 200 series Station Wagon Service information library 09.2011 - up
    UZJ200, URJ200, GRJ200, VDJ200 series
    Engines:
    1GR-FE - 4.0L V6 24-Valve VVT-i DOHC
    3UR-FE - 5.7L V8 32-Valve DOHC Dual VVT-i
    2UZ-FE - 4.7L V8 32-Valve DOHC VVT-i
    1VD-FTV - 4.5L V8 32-Valve DOHC D-4D turbo diesel
    Electrical wiring diagram
    Body Repair
    New Car Features
    Service data sheet
    REPAIR MANUAL
    ENGINE CONTROL SYSTEM
    1GR-FE - SFI system, Ignition system, Camshaft oil control valve, Throttle body, ECM, Accelerator pedal, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Ignition coil and spark plug, Engine coolant temperature sensor, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Power steering oil pressure switch, Relay
    3UR-FE - SFI system, Ignition system, Camshaft oil control valve, Throttle body, ECM, Accelerator pedal, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Ignition coil and spark plug, Engine coolant temperature sensor, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Power steering oil pressure switch, Relay
    2UZ-FE - SFI system, Ignition system, Camshaft oil control valve, Throttle body, ECM, Accelerator pedal, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Ignition coil and spark plug, Engine coolant temperature sensor, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Power steering oil pressure switch, Relay
    1VD-FTV - ECD system, Diesel throttle body, Vacuum switching valve, Active control engine mount, ECM, Accelerator pedal, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Manifold absolute pressure sensor, Power steering oil pressure switch, Relay
    ENGINE MECHANICAL
    1GR-FE - Engine, Drive belt, Valve clearance, Camshaft, Cylinder head gasket, Front/Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
    3UR-FE - Engine, Drive belt, Camshaft, Cylinder head gasket, Front/Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
    2UZ-FE - Engine, Drive belt, Valve clearance, Timing belt, Camshaft, Cylinder head gasket, Front/Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
    1VD-FTV - Engine, Drive belt, Camshaft, Cylinder head gasket, Front/Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
    FUEL
    1GR-FE - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pressure pulsation damper, Fuel filter, Fuel pump, Fuel pump ECU, Fuel tank, Fuel sub tank, Fuel sender gauge assembly
    3UR-FE - Fuel system, Fuel injector, Fuel pressure regulator, Fuel filter, Fuel pump, Fuel pump ECU, Fuel tank, Fuel sub tank, Fuel sender gauge assembly
    2UZ-FE - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pressure pulsation damper, Fuel filter, Fuel pump, Fuel pump ECU, Fuel tank, Fuel sub tank, Fuel sender gauge assembly
    1VD-FTV - Fuel system, Fuel injector, Fuel supply pump, Common rail, Fuel filter, Fuel cooler, Injector driver, Fuel pump, Fuel tank, Fuel sub tank, Fuel sender gauge assembly
    EMISSION CONTROL
    1GR-FE - Emission control system, Canister, Purge valve, Fuel tank cap, PCV valve
    3UR-FE - Emission control system, Canister, Purge valve, Fuel tank cap, PCV valve
    2UZ-FE - Emission control system, Air pump, Air switching valve, Air injection driver, Canister, Purge valve, Fuel tank cap, PCV valve
    1VD-FTV - Emission control system, EGR valve, EGR cooler, Fuel tank cap
    INTAKE / EXHAUST
    1GR-FE - Intake system, Intake manifold, Vacuum switching valve, Exhaust manifold, Exhaust pipe
    3UR-FE - Intake system, Intake manifold, Vacuum switching valve, Exhaust manifold, Exhaust pipe
    2UZ-FE - Intake system, Intake manifold, Vacuum switching valve, Exhaust manifold, Exhaust pipe
    1VD-FTV - Intake system, Snorkel air cleaner, Intake manifold, Exhaust manifold, Turbo motor driver, Intercooler, Exhaust pipe
    COOLING
    1GR-FE - Cooling system, Coolant, Water pump, Thermostat, Radiator
    3UR-FE - Cooling system, Coolant, Water pump, Thermostat, Radiator
    2UZ-FE - Cooling system, Coolant, Water pump, Thermostat, Radiator
    1VD-FTV - Cooling system, Coolant, Water pump, Thermostat, Radiator
    LUBRICATION
    1GR-FE - Lubrication system, Oil and oil filter, Oil pressure sensor, Oil level sensor, Oil pump, Engine oil cooler
    3UR-FE - Lubrication system, Oil and oil filter, Oil pressure sensor, Oil pump, Engine oil cooler
    2UZ-FE - Lubrication system, Oil and oil filter, Oil pressure sensor, Oil level sensor, Oil pump, Engine oil cooler
    1VD-FTV - Lubrication system, Oil and oil filter, Oil pressure sensor, Oil level sensor, Oil pump, Scavenging pump, Engine oil cooler
    STARTING
    1GR-FE - Starting system, Starter, Engine switch, Ignition switch, Relay
    3UR-FE - Starting system, Starter, Engine switch, Relay
    2UZ-FE - Starting system, Starter, Engine switch, Relay
    1VD-FTV - Starting system, Pre-heating system, Glow plug, Starter, Engine switch, Ignition switch, Relay
    CRUISE CONTROL - Cruise control system, Cruise control main switch, Clutch switch
    Drivetrain
    A750F Automatic transmission / Transaxle - Automatic transmission system, Fluid, Speed sensor, Transmission wire, Valve body assembly, Park/Neutral position switch, Oil cooler, Shift lever, Transmission assembly, Transmission unit, Torque converter clutch and drive plate, Oil pump
    AB60F Automatic transmission / Transaxle - Automatic transmission system, Fluid, Speed sensor, Transmission wire, Valve body assembly, Park/Neutral position switch, Oil cooler, Shift lever, Transmission assembly, Transmission unit, Torque converter clutch and drive plate, Oil pump
    Clutch - Clutch system, Clutch pedal, Master cylinder, Release cylinder, Clutch accumulator, Clutch unit, Clutch pedal switch
    H150F Manual transmission / Transaxle - Manual transmission system, Oil, Transmission case oil seal, Back-up light switch, Transmission assemly, Transmission unit, Input shaft, Output shaft, Oil pump
    JF2A transfer / 4WD / AWD - Transfer system, Transfer oil, Transfer case front oil seal, Transfer case rear oil seal, Transfer assembly, Center differential lock switch, 4WD control switch, 4WD control ECU
    Drive shaft / Propeller shaft - Drive shaft system, Front drive shaft assembly, Propeller shaft system, Front propeller shaft assembly, Propeller shaft assembly
    Axle and Differential - Axle system, Front axle hub bolt, Front axle hub, Steering knuckle, Rear axle hub bolt, Rear axle shaft, Differential system, Differential oil, Front differential carrier oil seal, Front differential side gear shaft oil seal, Front differential carrier assembly, Rear differential carrier oil seal, Rear differential carrier assembly, Rear differential lock actuator, Rear differential lock control switch
    Suspension control - Suspension control system, Active height control suspension, Height control pump and motor, Height control accumulator, Control valve assembly, Suspension control cylinder, Stabilizer control valve, Damping force control actuator, Height control sensor, Suspension control ECU, Front acceleration sensor, Absorber control switch, Relay
    Alignment / Handling diagnosis - Front wheel alignment
    Front suspension - Front suspension system, Shock absorber, Upper suspension arm, Lower suspension arm, Stabilizer bar
    Rear suspension - Suspension system, Shock absorber, Coil spring, Upper arm, Lower arm, Lateral control rod, Stabilizer bar
    Tire / Wheel - Tire and wheel system
    Brake Control / Dynamic control systems - Anti-lock brake system, Vehicle stability control system, Front speed sensor, Rear speed sensor, Deceleration sensor, Yaw rate and deceleration sensor, Steering angle sensor, Skid control buzzer, VSC off switch, Crawl switch, Relay
    Brake system - Brake system, Brake line, Fluid, Pedal, Brake booster, Hydraulic brake booster, Vacuum pump
    Front brake - Front brake, Front brake flexible hose
    Rear brake - Rear brake, Rear brake flexible hose
    Parking Brake - Parking brake system, Brake lever, Brake cable, Brake assembly
    Power assist systems - Power steering system, Vane pump
    Variable gear ratio steering - Variable gear ratio steering system, Steering actuator, Steering control ECU,
    Steering Column - Power tilt and power telescopic steering column system, Steering lock system, Steering system, Steering column assembly, Steering wheel, Multiplex tilt and telescopic ECU
    Steering gear / Linkage - Steering linkage
    Audio / Visual / Telematics
    Audio / Video - Audio and visual system, Rear seat entertainment system, Radio receiver, Stereo component amplifier, Luggage speaker, Front door speaker, Rear door speaker, Back door speaker, Pillar speaker, Instrument panel speaker, Television display, Radio antenna cord, Amplifier antenna, Stereo jack adapter assembly, Multi-media interface ECU, Microphone amplifier, Window glass antenna wire
    Navigation / Multi info display - Navigation system, Multi display, Navigation ECU, Hard disk drive, Navigation antenna
    Park assist / Monitoring - Parking assist sensor system, Assist monitor system, Rear view monitor system, Clearance warning ECU, Clearance warning buzzer, Ultrasonic sensor, Television camera, Clearance sonar main switch, Parking assist ECU
    Power source / Network
    Battery / Charging - Charging system, Generator
    Networking - LIN communication system, CAN communication system, Network gateway ECU
    Vehicle Interior
    Door lock, Theft deterrent / Keyless entry, Lighting, Meter / Gauge / Display, Mirror, Supplemental restraint system, Pre-crash safety, Seat, Seat belt, Heating / Air conditioning, Power outlets, Interior panels / Trim
    Vehicle Exterior
    Window / Glass, Sliding roof / Convertible, Door / Hatch, Mirror, Wiper / Washer, Lighting, Horn, Exterior panels / Trim, Winch
    ELECTRICAL WIRING DIAGRAM
    Engine - Cruise control, Engine control, Fuel heater, Ignition, Starting
    Drivetrain - ECT and A/T indicator, Multi mode 4WD, Shift lock
    Suspension - Adaptive variable system, Active height control suspension
    Brake - ABS, A-TRC, Brake assist, Crawl, Downhill assist control, EBD, Hill-Start assist control, VSC
    Steering - Power tilt and power telescopic, Steering lock, VGRS system
    Audio / Visual / Telematics - Audio system, Multi display, Navigation system, Parking assist
    Power source / Network - Charging, DLC3, Multiplex communication system, Power source
    Vehicle Interior - Air conditioner, Combination meter, Illumination, Cool box, Power seat, SRS, Wireless door lock, SRS, Seat heater, Double locking, Cool box, Condenser fan, Key reminder, Pre-crash safety system and many other
    Vehicle Exterior - Front fog light, Back door opener, Window deicer, Back-up light, Wiper and washer, Headlight, Horn, Mirror heater, Rear fog light, Sliding roof, Taillight, Turn signal and hazard warning light, Headlight cleaner, Winch and many other
    NEW CAR FEATURES
    New model outline, Engines, Exterior, Interior, Equipment, Performance, Chassis, Body, Body electrical, Technical specifications
    BODY REPAIR
    OTHER INFORMATION
    TOYOTA-LAND-CRUISER-200-STATION-WAGON-SERVICE-REPAIR-MANUAL-UPDATE-2015.jpg TOYOTA-LAND-CRUISER-200-STATION-WAGON-SERVICE-REPAIR-MANUAL-UPDATE-2015-.jpg TOYOTA-LAND-CRUISER-200-STATION-WAGON-SERVICE-REPAIR-MANUAL-UPDATE-2015-2.jpg TOYOTA-LAND-CRUISER-200-STATION-WAGON-SERVICE-REPAIR-MANUAL-UPDATE-2015-3.jpg TOYOTA-LAND-CRUISER-200-STATION-WAGON-SERVICE-REPAIR-MANUAL-UPDATE-2015-4.jpg
  2. urdu abdo
    urdu abdo New Member
    Sep 21, 2015
    27
    thank you so much,my friend
  3. Charlie
    Charlie New Member
    Jun 8, 2015
    128
    thank for sharing
  4. billcars
    billcars New Member
    Sep 26, 2015
    thank for sharing
  5. afyy27
    afyy27 New Member
    Apr 18, 2016
    thank you
  6. Kyi Min Nyan
    Kyi Min Nyan New Member
    Jan 19, 2018
    thank u alot lot sir
Share This Page
