• YouTube
  • Facebook
  • Twitter
  • Google +
Software Toyota Land Cruiser 150/Prado 2011-2015 Service & Repair Information Manual
Discussion in 'Repair Softwares' started by DHTAuto Support, Aug 3, 2015.
  1. DHTAuto Support
    DHTAuto Support Super Moderators
    Staff Member
    Jul 27, 2015
    182
    34
    Toyota land cruiser 150/Prado 2011-2015 Service & Repair Information Manual.
    Product Code: Toyota
    Availability: In Stock
    Qty: 01
    [​IMG]
    Description.
    Update : 04.2011 -->2015
    Region : All Regions
    Quantity of CD : 1 CD
    OS : Windows 8, Windows 7, Windows Vista, Windows XP / 32 & 64 bit
    Toyota Land Cruiser / Land Cruiser Prado 150 series Service information library 04.2011 - up
    [​IMG]
    GRJ150, KDJ150, KDJ155, LJ150, TRJ150, TRJ155 series
    Engines:
    1GR-FE - 4.0L V6 VVT-i
    2TR-FE - 2.7L 16Valve DOHC VVT-i
    1KD-FTV - 3.0L diesel
    5L-E - 3.0L diesel
    Electrical wiring diagram
    Body Repair
    Service data sheet
    REPAIR MANUAL
    ENGINE CONTROL SYSTEM
    1GR-FE engine - SFI system, Ignition system, Camshaft oil control valve, Throttle body, ECM, Accelerator pedal, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Ignition coil and spark plug, Engine coolant temperature sensor, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Power steering oil pressure switch, Relay
    1KD-FTV engine - ECD system, Diesel throttle body, Vacuum switching valve, ECM, Accelerator pedal, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Manifold absolute pressure sensor, Air fuel ratio sensor, Power steering oil pressure switch, Relay
    5L-E engine - ECD system, Diesel throttle body, ECM, Accelerator pedal, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Manifold absolute pressure sensor, Relay
    2TR-FE engine - SFI system, Ignition system, Camshaft oil control valve, Throttle body, ECM, Accelerator pedal, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Ignition coil and spark plug, Engine coolant temperature sensor, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Power steering oil pressure switch, Relay
    ENGINE MECHANICAL
    1GR-FE engine - Engine, Drive belt, Camshaft, Cylinder head gasket, Front/Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
    1KD-FTV engine - Engine, Drive belt, Valve clearance, Timing belt, Camshaft, Cylinder head gasket, Front/Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
    5L-E engine - Engine, Drive belt, Valve clearance, Timing belt, Camshaft, Cylinder head gasket, Front/Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
    2TR-FE engine - Engine, Drive belt, Camshaft, Cylinder head gasket, Front/Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
    FUEL
    1GR-FE engine - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pressure pulsation damper, Fuel filter, Fuel pump, Fuel pump ECU, Fuel tank, Fuel sub tank, Fuel sender gauge assembly
    1KD-FTV engine - Fuel system, Fuel injector, Fuel supply pump, Common rail, Fuel filter, Sunction control valve, Fuel cooler, Injector driver, Fuel pump, Fuel tank, Fuel sub tank, Fuel sender gauge assembly, Fuel sedimenter warning switch
    5L-E engine - Fuel system, Fuel injection pump, Fuel injection nozzle, Fuel filter, Fuel tank, Fuel sub tank, Fuel sender gauge assembly, Fuel sedimenter warning switch
    2TR-FE engine - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pressure pulsation damper, Fuel filter, Fuel pump, Fuel tank, Fuel sub tank, Fuel sender gauge assembly
    EMISSION CONTROL
    1GR-FE engine - Emission control system, Air pump, Air switching valve, Air injection driver, Canister, Purge valve, Fuel tank cap, PCV valve
    1KD-FTV engine - Emission control system, EGR valve, EGR cooler, Exhaust gas temperature sensor, Fuel tank cap, Exhaust fuel addition injector, Differential pressure sensor, Vacuum regulating valve, Vacuum switching valve
    5L-E engine - Emission control system, Fuel tank cap
    2TR-FE engine - Emission control system, Air pump, Air switching valve, Air injection driver, Canister, Purge valve, Fuel tank cap, PCV valve
    INTAKE / EXHAUST
    1GR-FE engine - Intake system, Intake manifold, Exhaust manifold, Exhaust pipe
    1KD-FTV engine - Intake system, Intake manifold, Exhaust manifold, Intercooler, Exhaust pipe
    5L-E engine - Intake system, Intake manifold, Exhaust manifold, Exhaust pipe
    2TR-FE engine - Intake system, Intake manifold, Exhaust manifold, Exhaust pipe
    COOLING
    1GR-FE engine - Cooling system, Coolant, Water pump, Thermostat, Radiator
    1KD-FTV engine - Cooling system, Coolant, Water pump, Thermostat, Radiator
    5L-E engine - Cooling system, Coolant, Water pump, Thermostat, Radiator
    2TR-FE engine - Cooling system, Coolant, Water pump, Thermostat, Radiator
    LUBRICATION
    1GR-FE engine - Lubrication system, Oil and oil filter, Oil pressure switch, Oil level sensor, Oil pump, Engine oil cooler
    1KD-FTV engine - Lubrication system, Oil and oil filter, Oil pressure switch, Oil pressure sensor, Oil pressure switching valve, Oil level sensor, Oil pump, Engine oil cooler
    5L-E engine - Lubrication system, Oil and oil filter, Oil pressure switch, Oil pump, Engine oil cooler
    2TR-FE engine - Lubrication system, Oil and oil filter, Oil pressure switch, Oil pump
    STARTING
    1GR-FE engine - Starting system, Starter, Engine switch, Ignition switch, Relay
    1KD-FTV engine - Starting system, Pre-heating system, Glow plug controller, Glow plug, Starter, Engine switch, Ignition switch, Relay
    5L-E engine - Starting system, Pre-heating system, Glow plug, Starter, Ignition switch, Relay
    2TR-FE engine - Starting system, Starter, Ignition switch, Relay
    CRUISE CONTROL - Cruise control system, Dynamic radar cruise control system, Cruise control main switch, Driving support ECU, Millimeter wave radar sensor, Clutch switch
    Drivetrain
    A343F Automatic transmission / Transaxle - Automatic transmission system, Fluid, Speed sensor, Transmission wire, Valve body assembly, Park/Neutral position switch, Oil cooler, Shift lever, Transmission control cable, Transfer adapter oil seal, Transmission assembly, Transmission unit, Torque converter clutch and drive plate, Oil pump
    A750F Automatic transmission / Transaxle - Automatic transmission system, Fluid, Speed sensor, ATF temperature sensor, Transmission wire, Valve body assembly, Park/Neutral position switch, Oil cooler, Shift lever, Transmission control cable, Transfer adapter oil seal, Transmission assembly, Transmission unit, Torque converter clutch and drive plate, Oil pump, TCM
    Clutch - Clutch system, Clutch pedal, Master cylinder, Release cylinder, Accumulator, Clutch unit, Pedal switch
    G52F Manual transmission / Transaxle - Manual transmission system, Oil, Transfer adapter oil seal, Back-up light switch, Transmission assemly, Transmission unit, Input shaft, Output shaft, Counter gear
    R150F Manual transmission / Transaxle - Manual transmission system, Oil, Transfer adapter oil seal, Back-up light switch, Transmission assemly, Transmission unit, Input shaft, Output shaft, Counter gear
    RA61F Manual transmission / Transaxle - Manual transmission system, Oil, Back-up light switch, Transmission assemly, Transmission unit, Input shaft, Output shaft, Counter gear
    VF4BM transfer / 4WD / AWD - Transfer system, Transfer oil, Case front oil seal, Case rear oil seal, Transfer assembly, Center differential lock switch, 4WD control switch, 4WD control ECU
    Drive shaft / Propeller shaft - Drive shaft system, Front drive shaft assembly, Propeller shaft system, Front propeller shaft assembly, Propeller shaft assembly
    Axle and Differential - Axle system, Front axle hub bolt, Front axle hub, Steering knuckle, Rear axle hub bolt, Rear axle shaft, Differential system, Differential oil, Front differential carrier oil seal, Front differential side gear shaft oil seal, Front differential carrier assembly, Rear differential carrier oil seal, Rear differential carrier assembly, Rear differential lock control switch, Rear differential lock position switch
    Suspension control - Air suspension system, Kinematic dynamic suspension system, Suspension control system, Height control sompressor, Height control dryer, Control valve assembly, Stabilizer control valve, Height control sensor, Control ECU, Acceleration sensor, Absorber control, Height control off switch, Height control switch
    Alignment / Handling diagnosis - Front wheel alignment
    Front suspension - Front suspension system, Shock absorber, Upper suspension arm, Lower suspension arm, Stabilizer bar
    Rear suspension - Suspension system, Shock absorber, Coil spring, Pneumatic cylinder, Upper arm, Lower arm, Lateral control rod, Stabilizer bar
    Tire / Wheel - Tire and wheel system, Tire repair seal
    Brake Control / Dynamic control systems - Anti-lock brake system, Vehicle stability control, Brake actuator, Front speed sensor, Rear speed sensor, Yaw rate and acceleration sensor, Steering angle sensor, Skid control buzzer, VSC off switch, Downhill assist control switch, Crawl switch
    Brake system - Brake system, Brake line, Fluid, Pedal, Master cylinder, Brake booster, Hydraulic brake booster, Vacuum pump
    Front brake - Front brake, Front brake flexible hose
    Rear brake - Rear brake, Rear brake flexible hose
    Parking Brake - Parking brake system, Brake lever, Brake cable, Brake assembly, Brake switch
    Power assist systems - Power steering system, Drive belt, Vane pump, Power steering ECU
    Steering Column - Power tilt and power telescopic steering column system, Steering lock system, Steering system, Steering column assembly, Steering wheel, Driving support switch control ECU, Multiplex tilt and telescopic ECU, Tilt and telescopic manual switch
    Steering gear / Linkage - Steering gear
    Audio / Visual / Telematics
    Audio / Video - Audio and visual system, Rear seat entertainment system, Radio receiver, Stereo component amplifier, Luggage speaker, Front door speaker, Rear door speaker, Quarter trim speaker, Pillar speaker, Instrument panel speaker, Television display, Radio antenna cord, Amplifier antenna, Stereo jack adapter assembly, Multi-media interface ECU, Microphone amplifier, Window glass antenna wire, Noise folter
    Navigation / Multi info display - Navigation system, DIsplay and navigation assembly, Navigation ECU, Navigation antenna
    Park assist / Monitoring - Parking assist sensor system, Assist monitor system, Wide view front monitor system, Side monitor system, Rear view monitor system, Clearance warning ECU, Clearance warning buzzer, Clearance warning indicator, Ultrasonic sensor, Television camera, Clearance sonar main switch, Parking assist ECU
    Power source / Network
    Battery / Charging - Charging system, Generator
    Power distribution - Main body ECU, Power management control ECU
    Networking - LIN communication system, CAN communication system
    Vehicle Interior
    Door lock, Theft deterrent / Keyless entry, Lighting, Meter / Gauge / Display, Mirror, Supplemental restraint system, Pre-crash safety, Seat, Seat belt, Heating / Air conditioning, Power outlets, Interior panels / Trim
    Vehicle Exterior
    Window / Glass, Sliding roof / Convertible, Door / Hatch, Mirror, Wiper / Washer, Lighting, Horn, Exterior panels / Trim
    ELECTRICAL WIRING DIAGRAM
    Engine - Cruise control, Dynamic radar cruise control, Engine control, Fuel heater, Ignition, Starting
    Drivetrain - 4WD, ECT and A/T indicator, Rear differential lock, Shift lock
    Suspension - Electronic modulated air suspension, Kinetic dynamic suspension system
    Brake - ABS, A-TRC, Crawl, Downhill assist control, Hill-Start assist control, Multi-Terrain select, TRC, VSC
    Steering - Power steering, Power tilt and power telescopic, Steering lock
    Audio / Visual / Telematics - Audio system, Multi display, Multi-Terrain monitor, Navigation system, Parking assist
    Power source / Network - Charging, DLC3, Multiplex communication system, Power source
    Vehicle Interior - Air conditioner, Combination meter, Illumination, Powert outlets, Power seat, SRS, Wireless door lock, Seat heater, Double locking, Cool box, Condenser fan, Glare-resistant, Light, Key reminder, Pre-crash safety system
    Vehicle Exterior - Front light, Back-up light, Wiper and washer, Headlight, Horn, Mirror heater, Rear fog light, Sliding roof, Taillight, Turn signal and hazard warning light, Headlight cleaner, Light control
    BODY REPAIR
    OTHER INFORMATION
    Toyota-land-cruiser-150-Prado-2011-2015-Service-Repair-Information-Manual-01.JPG Toyota-land-cruiser-150-Prado-2011-2015-Service-Repair-Information-Manual-02.JPG Toyota-land-cruiser-150-Prado-2011-2015-Service-Repair-Information-Manual-03.JPG Toyota-land-cruiser-150-Prado-2011-2015-Service-Repair-Information-Manual-04.JPG
    Instructions:
    1. Download archive, run archive and extract files and folders
    2. Open with Internet Explorer file INDEX2.HTML inside the folder contents
    This way --->>> Land Cruiser Service manual library / rm17x1e / INDEX2.HTML
    3. Rightclick on index2.html file, choose Open with --> Internet Explorer
    If you need more information as well as discount policy for this product.
    Please contact us : dhtauto.com@gmail.com
    Skype : dhtauto.team
    #1 DHTAuto Support, Aug 3, 2015
    choco bella likes this.
  2. Edward
    Edward New Member
    Jun 8, 2015
    121
    2011-up ??? Woah,amazing. Thank you
  3. Global Master
    Global Master Vip Member
    Jun 6, 2015
    118
    15
    can we exchange this program ?
  4. Sandro
    Sandro New Member
    Jul 30, 2015
    13
    4
    very good!
  5. Shana G. Hale
    Shana G. Hale New Member
    Sep 20, 2016
    69
    good job !
  6. vinh
    vinh New Member
    Apr 19, 2017
    thank my friend
  7. JALAZAM
    JALAZAM New Member
    Feb 11, 2018
    4
    THANKS
  8. JALAZAM
    JALAZAM New Member
    Feb 11, 2018
    4
    EXCELLENT JOB
  9. choco bella
    choco bella Banned
    Oct 4, 2015
    24
    Can you please link me download it?
    gmai: xuantruong211093@gmail.com
    Thanks you!
Share This Page
