• YouTube
  • Facebook
  • Twitter
  • Google +
CAR & TRUCK TOYOTA HILUX SERVICE & REPAIR MANUAL UPDATE 2015
Discussion in 'Service and Repair Manuals' started by hakota, Sep 13, 2015.
  1. hakota
    hakota Vip Member
    Sep 3, 2015
    76
    12
    Update : 06.2011 --> 2015
    Market : All Regions
    Quantity of CD : 1 CD
    Brand:Toyota
    Product Code: Toyota
    Availability: In Stock
    Toyota Hilux Service information library 06.2011 - up
    GGN15, GGN25, GGN35, KUN10, KUN15, KUN16, KUN25, KUN26, KUN35, KUN36, LAN15, LAN25, LAN35, TGN10, TGN11, TGN15, TGN16, TGN26, TGN36 series
    Engines:
    1GR-FE - 4.0L 6cylinder 24 Valve VVT-i DOHC
    1TR-FE - 2.0L 4cylinder 16Valve VVT-i DOHC
    2TR-FE - 2.7L 4cylinder 16Valve VVT-i DOHC
    1KD-FTV - 3.0L 4cylinder 16Valve D-4D DOHC diesel
    2KD-FTV - 2.5L 4cylinder 16Valve D-4D DOHC diesel
    5L-E - 3.0L 4cylinder 8Valve OHC diesel
    Electrical wiring diagram
    Body Repair
    Service data sheet
    REPAIR MANUAL
    ENGINE
    ENGINE CONTROL SYSTEM
    1GR-FE- SFI system, Mass air flow meter, Camshaft oil control valve, VVT sensor, Crankshaft position sensor, Engine coolant temperature sensor, Throttle body, Knock sensor, Integration relay, Fuel pump relay, ECM, Accelerator pedal rod
    1KD-FTV- ECD system, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Diesel throttle body, Integration relay, ECM, Accelerator pedal rod
    2KD-FTV - ECD system, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Diesel throttle body, Integration relay, ECM, Accelerator pedal rod
    5L-E - ECD system, Diesel throttle body, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Integration relay, ECM, Manifold absolute pressure sensor, Accelerator pedal rod
    1TR-FE - SFI system, Mass air flow meter, Camshaft oil control valve, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Throttle body, Knock sensor, Integration relay, ECM, Accelerator pedal rod
    2TR-FE - SFI system, Mass air flow meter, Camshaft oil control valve, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Throttle body, Knock sensor, Integration relay, ECM, Accelerator pedal rod
    ENGINE MECHANICAL
    1GR-FE - Engine, Drive belt, Valve clearance, Camshaft, Engine assembly, Engine unit
    1KD-FTV - Engine, Drive belt, Valve clearance, Timing belt, Cylinder head, Engine assembly, Engine unit
    2KD-FTV - Engine, Drive belt, Valve clearance, Timing belt, Cylinder head, Engine assembly, Engine unit
    5L-E - Engine, Drive belt, Valve clearance, Timing belt, Cylinder head, Engine assembly, Engine unit
    1TR-FE - Engine, Drive belt, Camshaft, Engine assembly, Engine unit
    2TR-FE - Engine, Drive belt, Camshaft, Engine assembly, Engine unit
    FUEL
    1KD-FTV - Fuel system, Fuel injector, Fuel supply pump, Common rail, Fuel filter, Fuel cooler, Injector driver, Fuel tank
    2KD-FTV - Fuel system, Fuel injector, Fuel supply pump, Common rail, Fuel filter, Fuel cooler, Injector driver, Fuel tank
    1GR-FE - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pressure pulsation damper, Fuel filter, Fuel pump, Fuel pump resistor, Fuel tank
    5L-E - Fuel system, Fuel injection pump, Fuel injection nozzle, Fuel filter, Fuel tank
    1TR-FE - Fuel system, Fuel injector, Fuel pressure regulator, Fuel filter, Fuel pump, Fuel tank
    2TR-FE - Fuel system, Fuel injector, Fuel pressure regulator, Fuel filter, Fuel pump, Fuel tank
    EMISSION CONTROL
    1KD-FTV - Emission control system, EGR valve, EGR cooler, Exhaust gas temperature sensor, Differential pressure sensor, Exhaust fuel addition injector, Vacuum switching valve, Vacuum regulating valve, Air fuel ratio sensor, Fuel tank cap
    2KD-FTV - Emission control system, EGR valve, EGR cooler, Exhaust gas temperature sensor, Differential pressure sensor, Exhaust fuel addition injector, Vacuum switching valve, Vacuum regulating valve, Air fuel ratio sensor, Fuel tank cap
    5L-E - Emission control system, Fuel tank cap
    1GR-FE - Emission control system, Canister, Vacuum switching valve, PCV valve, Air fuel ratio sensor, Heated oxygen sensor, Fuel tank cap
    1TR-FE - Emission control system, Canister, Vacuum switching valve, Ventilation valve, Heated oxygen sensor, Fuel tank cap
    2TR-FE - Emission control system, Air pump, Air switching valve, Canister, Vacuum switching valve, PCV valve, Air fuel ratio sensor, Heated oxygen sensor, Fuel tank cap
    INTAKE / EXHAUST
    1KD-FTV - Intake system, Intake manifold, Turbocharger, Intercooler, Exhaust pipe
    2KD-FTV - Intake system, Intake manifold, Turbocharger, Intercooler, Exhaust pipe
    1GR-FE - Intake system, Vacuum switching valve, Exhaust pipe
    5L-E - Exhaust pipe
    1TR-FE - Exhaust pipe
    2TR-FE - Exhaust pipe
    COOLING
    1KD-FTV - Cooling system, Coolant, Water pump, Thermostat, Radiator, Fan
    2KD-FTV - Cooling system, Coolant, Water pump, Thermostat, Radiator, Fan
    5L-E - Cooling system, Coolant, Water pump, Thermostat, Radiator, Fan
    1TR-FE - Cooling system, Coolant, Water pump, Thermostat, Radiator, Fan
    2TR-FE - Cooling system, Coolant, Water pump, Thermostat, Radiator, Fan
    1GR-FE - Cooling system, Coolant, Water pump, Thermostat, Radiator, Fan
    LUBRICATION
    1KD-FTV - Lubrication system, Oil filter, Oil pump, Oil pressure switch, Oil level sensor, Engine Oil cooler
    2KD-FTV - Lubrication system, Oil filter, Oil pump, Oil pressure switch, Oil level sensor, Engine Oil cooler
    5L-E - Lubrication system, Oil filter, Oil pump, Engine Oil cooler
    1TR-FE - Lubrication system, Oil filter, Oil pump
    2TR-FE - Lubrication system, Oil filter, Oil pump
    1GR-FE - Lubrication system, Oil filter, Oil pump
    IGNITION
    1TR-FE - Ignition system, Ignition coil and spark plug
    2TR-FE - Ignition system, Ignition coil and spark plug
    1GR-FE - Ignition system, Ignition coil and spark plug
    STARTING
    1KD-FTV- Starting system, Pre-heating system, Glow plug, Glow plug controller, Starter, Starter relay, Glow relay, Ignition switch
    2KD-FTV- Starting system, Pre-heating system, Glow plug, Glow plug controller, Starter, Starter relay, Glow relay, Ignition switch
    5L-E - Starting system, Pre-heating system, Glow plug, Starter, Starter relay, Glow relay, Ignition switch
    1TR-FE - Starting system, Starter, Starter relay, Ignition switch
    2TR-FE - Starting system, Starter, Starter relay, Ignition switch
    1GR-FE - Starting system, Starter, Starter relay, Ignition switch
    CHARGING
    1KD-FTV - Charging system, Generator
    2KD-FTV - Charging system, Generator
    5L-E - Charging system, Generator
    1TR-FE - Charging system, Generator
    2TR-FE - Charging system, Generator
    1GR-FE - Charging system, Generator
    TRANSMISSION
    A340E Automatic Transmission - Automatic transmission system, Fluid, Extension housing rear oil seal, Speed sensor, Transmission wire, ATF temperature sensor, Park / Neutral position switch, Valve body assembly, Shift lock system, Floor shift assembly, Automatic transmission assembly, Torque converter clutch and drive plate, Transmission control cable, Transmission unit, Oil pump, Second coast brake, Overdrive brake, Overdrive direct clutch, Direct clutch, Forward clutch, Sun gear and one way clutch, Second brake, Rear planetary gear, Valve body
    A340F Automatic Transmission - Electronic controlled automatic transmission system, Fluid, Speed sensor, Transmission wire, ATF temperature sensor, Park / Neutral position switch, Valve body assembly, Shift lock system, Floor shift assembly, Automatic transmission assembly, Torque converter clutch and drive plate, Transmission control cable, Transmission unit, Oil pump, Second coast brake, Overdrive brake, Overdrive direct clutch, Direct clutch, Forward clutch, Sun gear and one way clutch, Second brake, Rear planetary gear, Valve body
    A343E Automatic Transmission - Automatic transmission system, Fluid, Extension housing rear oil seal, Speed sensor, Transmission wire, ATF temperature sensor, Park / Neutral position switch, Valve body assembly, Shift lock system, Floor shift assembly, Automatic transmission assembly, Torque converter clutch and drive plate, Transmission control cable, Transmission unit, Oil pump, Second coast brake, Overdrive brake, Overdrive direct clutch, Direct clutch, Forward clutch, Sun gear and one way clutch, Second brake, Rear planetary gear, Valve body
    A343F Automatic Transmission - Automatic transmission system, Fluid, Speed sensor, Transmission wire, ATF temperature sensor, Park / Neutral position switch, Valve body assembly, Shift lock system, Floor shift assembly, Automatic transmission assembly, Torque converter clutch and drive plate, Transmission control cable, Transmission unit, Oil pump, Second coast brake, Overdrive brake, Overdrive direct clutch, Direct clutch, Forward clutch, Sun gear and one way clutch, Second brake, Rear planetary gear, Valve body
    A750E Automatic Transmission - Electronic controlled automatic transmission system, Extension housing rear oil seal, Fluid, Speed sensor, Transmission wire, Park / Neutral position switch, Valve body assembly, Shift lock system, Floor shift assembly, Automatic transmission assembly, Torque converter clutch and drive plate, Transmission control cable, Transmission unit, Oil pump, Clutch drum and input shaft assembly, Valve body
    A750F Automatic Transmission - Electronic controlled automatic transmission system, Fluid, Speed sensor, Transmission wire, Park / Neutral position switch, Valve body assembly, Shift lock system, Floor shift assembly, Automatic transmission assembly, Torque converter clutch and drive plate, Transmission control cable, Transmission unit, Oil pump, Clutch drum and input shaft assembly, Valve body
    Clutch - Clutch system, Clutch pedal, Master cylinder, Release cylinder, Clutch accumulator, Clutch unit, Clutch pedal switch
    G58 Manual Transmission - Manual transmission system, Oil, Extension housing oil seal, Back-up light switch, Transmission assembly, Transmission unit, Input shaft, Output shaft, Counter gear
    G58F Manual Transmission - Manual transmission system, Oil, Transfer adaptor oil seal, Back-up light switch, Transmission assembly, Transmission unit, Input shaft, Output shaft, Counter gear
    R150/R151/R156 Manual Transmission - Manual transmission system, Oil, Extension housing oil seal, Back-up light switch, Transmission assembly, Transmission unit, Input shaft, Output shaft, Counter gear
    R150F/R151F/R156F Manual Transmission - Manual transmission system, Oil, Transfer adaptor oil seal, Back-up light switch, Transmission assembly, Transmission unit, Input shaft, Output shaft, Counter gear
    DRIVE LINE
    VF2A Transfer - Transfer system, Oil, Case oil seal, Extension housing oil seal, Transfer assembly, Indicator switch
    Propeller Shaft - Propeller shaft system, Propeller shaft assembly, Front propeller shaft assembly
    Drive Shaft - Drive shaft system, Front drive shaft assembly
    Differential - Differential system, Differential oil, Front differential carrier oil seal, Front differential side gear shaft oil seal, Differential carrier assembly, Differential vacuum actuator
    SUSPENSION & AXLE
    Axle - Axle system, Front axle hub bolt, Front axle hub, Steering knuckle, Rear axle hub bolt, Rear axle shaft
    Suspension - Suspension system, Front wheel alignment, Front shock absorber, Front upper suspension arm, Front lower suspension arm, Front stabilizer bar, Rear leaf spring, Rear shock absorber
    Tire and Wheel - Tire and wheel system
    BRAKE
    Brake Control - Anti lock brake system, Vehicle stability control system, Brake actuator, Front speed sensor, Rear speed sensor, Deceleration sensor, Steering angle sensor, VSC
    Brake - Brake system, Fluid, Brake pedal, Master cylinder, Brake booster, Vacuum pump, Front brake, Front brake flexible hose, Rear brake, Rear brake flexible hose, Load sensing proportioning valve
    Parking Brake - Parking brake system, Parking brake lever, Parking brake cable
    STEERING
    Steering Column - Steering system, Steering column assembly
    Power Steering - Power steering system, Vane pump, Steering gear
    HEATER & AIR CONDITIONING
    Air Conditioning - Air conditioning system, Refrigerant, Refrigerant line, Air conditioning and blower unit, Blower resistor and motor, PTC heater assembly, Compressor, Viscous heater magnet clutch, Condenser, Evaporator temperature sensor, Pressure switch, Heater blower motor relay, Magnetic clutch relay, Air conditioning control assembly, Air Conditioning/Heater switch, Solar sensor, Air conditioning amplifier
    RESTRAINTS
    Supplemental Restraint System - Airbag system, Steering pad, Spiral cable, Front passenger airbag assembly, Curtain shield airbag, Front seat side airbag, Center airbag sensor assembly, Front airbag sensor, Side airbag sensor, Rear airbag sensor
    Seat Belt - Seat belt warning system, Front seat inner belt assembly, Front seat outer belt assembly, Rear seat inner belt assembly, Rear seat outer belt assembly
    SECURITIES
    Theft Deterrent - Theft deterrent system, Engine hood courtesy switch, Security horn assembly, Security indicator light
    Engine Immobiliser - Engine immobiliser system, Unlock warning switch, Transponder key amplifier
    CRUISE CONTROL SYSTEM
    Cruise Control - Cruise control system, Cruise control main switch, Clutch switch
    BODY ELECTRICAL
    Lighting, Wiper and Washer, Door Lock, Meter, Audio / Visual, Park assist/Monitoring, Horn, Other systems
    BODY
    Windshield / Windowglass, Mirror, Instrument panel, Seat, Engine Hood / Door, Exterior, Interior
    COMMUNICATION SYSTEM
    CAN communication system
    ELECTRICAL WIRING DIAGRAM
    Engine - Charging, Engine control, Ignition, Starting
    Transmission - ECT and A/T indicator, Shift lock
    Drive line - 4WD, Rear differential lock
    Brake - ABS, TRC, VSC
    Heater & Air Conditioning System - Air conditioner, Heater, PTC heater
    Restraints - Seat belt warning, SRS
    Securities - Engine immobiliser system, Theft deterrent
    Cruise Control System - Cruise control
    Body Electrical - Audio system, Back-up light, Cigarette lighter, Front fog light, Headlight, Interior light, Stop light, Multi display, Wireless door lock control, Taillight and much much more
    Body - Mirror heater, Power seat, Power window, Rear window defogger, Remote control mirror, Seat heater
    Communication System - Multiplex communication system
    BODY REPAIR
    OTHER INFORMATION
    TOYOTA-HILUX-SERVICE-REPAIR-MANUAL-UPDATE-2015.jpg TOYOTA-HILUX-SERVICE-REPAIR-MANUAL-UPDATE-2015-.jpg TOYOTA-HILUX-SERVICE-REPAIR-MANUAL-UPDATE-2015-2.jpg TOYOTA-HILUX-SERVICE-REPAIR-MANUAL-UPDATE-2015-3.jpg TOYOTA-HILUX-SERVICE-REPAIR-MANUAL-UPDATE-2015-11.jpg
    #1 hakota, Sep 13, 2015
  2. trophymanager
    trophymanager New Member
    Sep 7, 2015
    51
    Thanks for sharing
  3. Edward
    Edward New Member
    Jun 8, 2015
    121
    thank you so much,friend
  4. RexMen
    RexMen New Member
    Jan 7, 2017
    4
    No beer!!!
  5. dongphuong
    dongphuong New Member
    Dec 1, 2016
    How can i get enough beer to download it :( ?
Share This Page
