• YouTube
  • Facebook
  • Twitter
  • Google +
TOYOTA AVENSIS T25 SERVICE & REPAIR MANUAL UPDATE 2008
Discussion in 'Service and Repair Manuals' started by novaland, Sep 21, 2015.
  1. novaland
    novaland New Member
    Sep 18, 2015
    19
    TOYOTA AVENSIS T25 2003 - 2008 SERVICE & REPAIR INFORMATION MANUAL
    Code:
    Product Code: Toyota
    Availability: In Stock
    Qty:  01
    Update : 01.2003 - 10.2008
    Market ; Europe
    Qty :  1 CD
    Toyota Avensis T25 Service information library 01.2003 - 10.2008
    ZZT250, ZZT251, AZT250, AZT251, ADT250, ADT251, CDT250 series
    Engines:
    2AZ-FSE - 2.4L 4-cylinder 16 Valve DOHC D-4 VVT-i
    1AZ-FSE - 2.0L 4-cylinder 16 Valve DOHC D-4 VVT-i
    1AZ-FE - 2.0L 4-cylinder 16 Valve DOHC
    1ZZ-FE - 1.8L 4-cylinder 16 Valve DOHC VVT-i
    3ZZ-FE - 1.6L 4-cylinder 16 Valve DOHC VVT-i
    1CD-FTV - 2.0L 4-cylinder 16 Valve DOHCD-4D diesel
    1CD-FTV D-CAT - 2.0L 4-cylinder 16 Valve DOHCD-4D diesel
    2AD-FTV - 2.2L 4-cylinder 16 Valve DOHCD-4D diesel
    2AD-FHV D-CAT - 2.2L 4-cylinder 16 Valve DOHCD-4D diesel
    Electrical wiring diagram
    Body Repair
    New Car Features
    Service data sheet
    REPAIR MANUAL
    Introduction, Preparation, Service specifications, Diagnostics, Engine control system, Fuel, Emission control, Intake, Engine mechanical, Exhaust, Cooling, Lubrication, Ignition, Starting & Charging, Front suspension, Rear suspension, Tire & Wheel, Drive shaft / Propeller shaft, Brake, Parking Brake, Manual transmission / Transaxle, Automatic transmission, Clutch, Steering column, Power steering, Heater & Air conditioner, Supplemental restraint system, Seat belt, Lighting, Wiper & Washer, Audio & Visual system, Wiring, Communication system, Windshield / Windowglass / Mirror, Instrument panel / Meter, Seat, Theft deterrent & Door lock, Sliding roof / Convertible, Engine hood / Door, Exterior / Interior trim, Vehicle control system
    Engine Repair manual (2AZ-FSE)
    Introduction, Preparation, Service specifications, Engine mechanical, Cooling, Lubrication, Starting & Charging
    Engine Repair manual (1AZ-FSE)
    Engine Repair manual (1AZ-FE)
    Engine Repair manual (1ZZ-FE, 3ZZ-FE)
    Engine Repair manual (1CD-FTV)
    Introduction, Preparation, Service specifications, Intake, Engine mechanical, Cooling, Lubrication, Starting & Charging
    Manual transmission repair manual (E354, E357)
    Introduction, Preparation, Service specifications, Manual transmission / Transaxle, Manual transaxle assembly, Input shaft assembly,
    Output shaft assembly, Shift & select lever shaft assembly, Differential case assembly
    Manual transmission repair manual (C250)
    Manual transmission repair manual (C50)
    Introduction, Preparation, Service specifications, Manual transaxle assembly, Input shaft assembly,
    Automatic transmission repair manual (U341E)
    Introduction, Preparation, Service specifications, Components, Automatic transmission / Transaxle, Transaxle assembly, Oil pump assembly, Input shaft assembly, Second brake piston,
    Intermediate shaft, Transaxle rear cover, Transmission valve body assembly, Front differential assembly
    Automatic transmission repair manual (U241E)
    Introduction, Preparation, Service specifications, Components, Automatic transmission / Transaxle, Transaxle assembly, Oil pump assembly, Forward clutch assembly, Direct clutch assembly,
    Second brake piston assembly, Underdrive clutch assembly, Underdrive planetary gear assembly, Transmission valve body assembly, Front differential assembly
    Automatic transmission repair manual (U151E, U151F)
    Engine Repair manual (2AD-FHV)
    ECD system, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Diesel throttle body,
    EFI relay, EDU relay, Manifold absolute pressure sensor, ECM, Accelerator pedal rod
    Engine, Drive belt, Camshaft, Engine assembly, Engine unit
    Fuel system, Fuel injector, Fuel supply pump, Common rail, Fuel filter, Injector driver, Fuel tank
    Emission control system, EGR valve, EGR cooler, Exhaust manifold converter, Vacuum switching valve, Air fuel ratio sensor,
    Differential pressure sensor, Exhaust gas temperature sensor, Fuel tank cap
    Cooling, Lubrication, Intake / Exhaust, Starting, Charging
    Engine Repair manual (2AD-FTV)
    Emission control system, EGR valve, EGR cooler, Fuel tank cap
    Manual transaxle repair manual (EA60 / EA61)
    Manual transmission system, Oil, Differential oil seal, Floor shift lever, Transmission control cable, Transaxle assembly, Transaxle unit, Input shaft, Output shaft, Differential case, Shift and select lever shaft
    NEW CAR FEATURES
    Introduction, New model outline, Engine, Chassis, Body, Body electrical
    New car features, Technical specifications
    ELECTRICAL WIRING DIAGRAM
    Introduction, Relay locations, Electrical wiring routing, Connector list, Part number of connectrors, System circuits, Ground point,
    Power source, Overall electrical wiring diagram
    BODY REPAIR
    Body Panel Replacement, Paint, Coating
    OTHER INFORMATION
    Toyota-Avensis-T25-Service-information-library-01-2003-10-2008-.JPG Toyota-Avensis-T25-Service-information-library-01-2003-10-2008.JPG Toyota-Avensis-T25-Service-information-library-01-2003-10-2008-.JPG Toyota-Avensis-T25-Service-information-library-01-2003-10-2008-1.JPG Toyota-Avensis-T25-Service-information-library-01-2003-10-2008-2.JPG Toyota-Avensis-T25-Service-information-library-01-2003-10-2008-3.JPG
  2. Edward
    Edward New Member
    Jun 8, 2015
    121
    thank you friend
Share This Page
