• YouTube
  • Facebook
  • Twitter
  • Google +
CAR & TRUCK TOYOTA AVENSIS MODELS DIESEL SERVICE & REPAIR MANUAL UPDATE 2015
Discussion in 'Service and Repair Manuals' started by hakota, Sep 11, 2015.
  1. hakota
    hakota Vip Member
    Sep 3, 2015
    76
    TOYOTA AVENSIS T27 2008 - 2015 DIESEL SERVICE & REPAIR INFORMATION MANUAL
    Brand:Toyota
    Product Code: Toyota
    Availability: In Stock
    Update :
    11.2008 --> 2015
    Market : Europe
    Quantity of CD : 1 CD
    Toyota Avensis Diesel models Service information library 11.2008 - up
    ADT270, ADT271 series
    Engines:
    1AD-FTV - 2.0L 4-cylinder 16 Valve D-4D DOHC
    2AD-FHV - 2.2L 4-cylinder 16 Valve D-4D D-CAT DOHC
    2AD-FTV - 2.2L 4-cylinder 16 Valve D-4D DOHC
    Electrical wiring diagram
    Body Repair
    Service data sheet
    REPAIR MANUAL
    ENGINE
    ENGINE CONTROL SYSTEM
    1AD-FTV - ECD system, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Diesel throttle body, ECM, Accelerator pedal, Manifold absolute pressure sensor, Air fuel ratio sensor, Integration relay, Relay
    2AD-FHV - ECD system, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Diesel throttle body, ECM, Accelerator pedal, Manifold absolute pressure sensor, Air fuel ratio sensor, Integration relay, Relay
    2AD-FTV - ECD system, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Diesel throttle body, ECM, Accelerator pedal, Manifold absolute pressure sensor, Air fuel ratio sensor, Integration relay, Relay
    ENGINE MECHANICAL
    1AD-FTV - Engine, Drive belt, Camshaft, Cylinder head gasket, Cylinder head, Cylinder block, Front/Rear crankshaft oil seal, Engine assembly, Engine unit
    2AD-FHV - Engine, Drive belt, Camshaft, Cylinder head gasket, Cylinder head, Cylinder block, Front/Rear crankshaft oil seal, Engine assembly, Engine unit
    2AD-FTV - Engine, Drive belt, Camshaft, Cylinder head gasket, Cylinder head, Cylinder block, Front/Rear crankshaft oil seal, Engine assembly, Engine unit
    FUEL
    1AD-FTV - Fuel system, Fuel injector, Fuel supply pump, Common rail, Fuel filter, Injector driver, Fuel tank, Fuel sender gauge assembly, Fuel sedimenter warning switch
    2AD-FHV - Fuel system, Fuel injector, Fuel supply pump, Common rail, Fuel filter, Injector driver, Fuel tank, Fuel sender gauge assembly, Fuel sedimenter warning switch
    2AD-FTV - Fuel system, Fuel injector, Fuel supply pump, Common rail, Fuel filter, Injector driver, Fuel tank, Fuel sender gauge assembly, Fuel sedimenter warning switch
    EMISSION CONTROL
    1AD-FTV - Emission control system, EGR valve, EGR cooler, EGR bypass valve switching valve, Exhaust gas temperature sensor, Fuel tank cap, Exhaust fuel addition injector, Monolithic converter, Differential pressure sensor, Vacuum regulating valve
    2AD-FHV - Emission control system, EGR valve, EGR cooler, EGR bypass valve switching valve, Exhaust gas temperature sensor, Fuel tank cap, Exhaust fuel addition injector, Monolithic converter, Differential pressure sensor, Vacuum regulating valve
    2AD-FTV - Emission control system, EGR valve, EGR cooler, EGR bypass valve switching valve, Exhaust gas temperature sensor, Fuel tank cap, Exhaust fuel addition injector, Monolithic converter, Differential pressure sensor, Vacuum regulating valve
    INTAKE / EXHAUST
    1AD-FTV - Intake system, Intake manifold, Turbocharger, Intercooler, Exhaust manifold, Exhaust pipe
    2AD-FHV - Intake system, Intake manifold, Turbocharger, Intercooler, Exhaust manifold, Exhaust pipe
    2AD-FTV - Intake system, Intake manifold, Turbocharger, Intercooler, Exhaust manifold, Exhaust pipe
    COOLING
    1AD-FTV - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Cooling fan motor, Relay, Radiator
    2AD-FHV - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Cooling fan motor, Relay, Radiator
    2AD-FTV - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Cooling fan motor, Relay, Radiator
    LUBRICATION
    1AD-FTV - Lubrication system, Oil and oil filter, Oil pressure switch, Oil level sensor, Oil pump, Engine oil cooler
    2AD-FHV - Lubrication system, Oil and oil filter, Oil pressure switch, Oil level sensor, Oil pump, Engine oil cooler
    2AD-FTV - Lubrication system, Oil and oil filter, Oil pressure switch, Oil level sensor, Oil pump, Engine oil cooler
    STARTING
    1AD-FTV - Starting system, Pre-heating system, Glow plug, Starter, Engine switch, Ignition switch, Relay
    2AD-FHV - Starting system, Pre-heating system, Glow plug, Starter, Engine switch, Ignition switch, Relay
    2AD-FTV - Starting system, Pre-heating system, Glow plug, Starter, Engine switch, Ignition switch, Relay
    CRUISE CONTROL - Cruise control system, Speed limiter system, Dynamic radar cruise control system, Lane-keeping assist system, Cruise control main switch, Adjustable speed limiter switch, Lane recognition camera sensor, Driving support ECU, Millimeter wave radar sensor
    DRIVETRAIN
    CLUTCH - Clutch system, Clutch pedal, Clutch master cylinder, Clutch release cylinder, Clutch accumulator, Clutch unit, Clutch pedal switch
    U660E AUTOMATIC TRANSMISSION - Automatic transmission system, Transaxle fluid, Speed sensor, ATF temperature sensor, Transmission wire, Valve body assembly, Park/Neutral position switch, Oil cooler, Shift lever, Shift paddle switch, Transmission control cable, Differential oil seal, Automatic transaxle assembly, Torque converter clutch and drive plate, TCM, Oil pump, Differential case
    EA62 MANUAL TRANSMISSION/TRANSAXLE - Manual transaxle system, Transaxle oil, Differential oil seal, Shift lever assembly, Back-up light switch, Park/Neutral position switch, Manual transaxle assembly, Manual transaxle unit, Input shaft, Output shaft, Shift and select lever shaft, Defferential case
    EA63 MANUAL TRANSMISSION/TRANSAXLE - Manual transaxle system, Transaxle oil, Differential oil seal, Shift lever assembly, Back-up light switch, Park/Neutral position switch, Manual transaxle assembly, Manual transaxle unit, Input shaft, Output shaft, Shift and select lever shaft, Defferential case
    EA65 MANUAL TRANSMISSION/TRANSAXLE - Manual transaxle system, Transaxle oil, Differential oil seal, Shift lever assembly, Back-up light switch, Park/Neutral position switch, Manual transaxle assembly, Manual transaxle unit, Input shaft, Output shaft, Shift and select lever shaft, Defferential case
    DRIVE SHAFT/PROPELLER SHAFT - Drive shaft system, Front drive shaft assembly
    AXLE AND DIFFERENTIAL - Axle system, Front axle hub, Steering knuckle, Rear axle hub
    SUSPENSION
    FRONT SUSPENSION - Suspension system, Front shock absorber, Front lower suspension arm, Front lower ball joint, Front stabilizer bar, Front suspension member
    REAR SUSPENSION - Suspension system, Rear shock absorber, Rear coil spring, Rear upper arm, Rear lower arm, Rear trailing arm, Rear stabilizer bar, Rear suspension member
    TIRE AND WHEEL - Tire and wheel system, Tire repair seal, Front/Rear wheel alignment
    BRAKE
    BRAKE CONTROL/DYNAMIC CONTROL SYSTEM - Vehicle stability control, Brake actuator, Front speed sensor, Rear speed sensor, Yaw rate and deceleration sensor, Steering angle sensor, Brake pedal stroke sensor, Skid control buzzer, VSC off switch
    BRAKE - Brake system, Brake line, Brake fluid, Brake pedal, Brake master cylinder, Brake booster, Vacuum pump, Front brake, Rear brake
    PARKING BRAKE - Electric parking brake system, Brake actuator, Brake switch
    STEERING
    STEERING COLUMN - Power tilt and power telescopic steering column, Steering system, Steering column assembly, Steering wheel, Multiplex tilt and telescopic ECU, Steering gear
    POWER ASSIST SYSTEM - Power steering system, Steering ECU
    AUDIO/VISUAL/TELEMATICS
    AUDIO/VIDEO - Audio and visual system, Radio receiver, Stereo component amplifier, Front door speaker, Rear door speaker, Instrument panel speaker, Radio antenna cord, Amplifier antenna, Stereo jack adapter assembly, Microphone amplifier, Window glass antenna wire
    NAVIGATION/MULTI INFO DISPLAY - Navigation system, Navigation receiver, Navigation antenna
    PARKING ASSIST / MONITORING - Toyota parking assist-sensor system, Rear view monitor system, Clearance warning ECU, Clearance warning buzzer, Ultrasonic sensor, Television camera, Clearance sonar main switch
    POWER SOURCE/NETWORK
    BATTERY/CHARGING - Charging system, Generator
    POWER DISTRIBUTION - Battery current sensor, Power management control ECU
    NETWORKING - LIN communication system, CAN communication system
    VEHICLE INTERIOR
    DOOR LOCK - Power door lock control system, Wireless door lock control system, Key reminder warning system, Transmitter battery, Door control transmitter, Door control transmitter, Front / Rear door lock, Door control receiver, Wireless door lock buzzer
    THEFT DETERRENT / KEYLESS ENTRY - Engine immobiliser system, Entry and start system, Theft deterrent system, Electrical key oscillator, Engine hood courtesy switch, Security horn assembly, Transponder key amplifier
    LIGHTING - Lighting system, Vanity light, Personal light, Room light, Luggage compartment room light, Door courtesy light, Glove box light, Front / Rear door courtesy switch
    METER / GAUGE / DISPLAY - Meter / Gauge system, Clock system, Combination meter
    MIRROR - Inner rear view mirror
    SUPPLEMENTAL RESTRAINT SYSTEMS - Airbag system, Steering pad, Spiral cable, Knee airbag assembly, Front passenger airbag assembly, Curtain shield airbag assembly, Front seat side airbag assembly, Center airbag sensor assembly, Front airbag sensor, Side airbag sensor, Rear airbag sensor, Airbag cut-off switch
    PRE-CRASH SAFETY - Pre-crash safety system, Pre-crash brake cancel switch, Seat belt control ECU
    SEAT - Front power seat control system, Seat heater system, Front seat assembly, Rear seat assembly, Seat memory switch, Power seat switch, Front power seat motor assembly, Lumbar switch, Seat heater switch, Front seatback heater, Front seat cushion heater, Seat heater control
    SEAT BELT - Seat belt warning system, Occupant detection sensor, Front seat inner belt assembly, Front seat outer belt assembly, Rear seat inner belt assembly, Rear seat outer belt assembly, Rear center seat inner belt assembly, Rear center seat outer belt assembly, Child restraint seat anchor
    HEATING / AIR CONDITIONING - Air conditioning system, Combustion type power heater system, Refrigerant, Refrigerant line, Air conditioning unit, Blower unit, PTC heater assembly, Compressor, Condenser, Room temperature sensor, Ambient temperature sensor, Front evaporator temperature sensor, Solar sensor, Air conditioning pressure sensor, Heater fuel pump, Heater assembly, Heater exhaust pipe, Air conditioning panel, Air conditioning amplifier
    POWER OUTLETS - Power outlet socket
    INTERIOR PANELS / TRIM - Roof sunshade system, Upper instrument panel, Lower instrument panel, Front console box, Roof headlining, Roof sunshade
    VEHICLE EXTERIOR
    WINDOW / GLASS - Power window control system, Power window master switch, Front passenger side power window switch, Rear power window switch, Power window regulator motor, Windshield glass, Back door glass, Windshield deicer system, Window defogger system, Window defogger wire, Quarter window glass, Relay
    DOOR / HATCH - Luggage compartment door opener system, Fuel lid opener system, Hood, Hood lock control cable assembly, Front door, Rear door, Back door, Lugagge door, Back door opener switch, Back door support, Fuel lid opener motor assembly, Fuel lid opener switch, Relay
    MIRROR - Power mirror control system, Outer rear view mirror, Outer mirror switch
    WIPER / WASHER - Wiper and washer system, Front wiper motor, Rear wiper motor, Front wiper motor, Front / Rear wiper rubber, Wiper switch, Washer motor, Washer nozzle, Headlight cleaner actuator, Headlight cleaner switch, Headlight cleaner motor, Wiper ECU, Rain sensor, Relay
    LIGHTING - Lighting system, Headlight assembly, Fog light assembly, Rear fog light assembly, Side turn signal light assembly, Rear combination light assembly, Back-up light, Licence plate light, High mounted stop light, Headlight dimmer switch, Hazard warning switch, Headlight leveling switch, AFS off switch, Stop light switch, Automatic light control sensor, AFS ECU, Height control sensor, Turn signal flasher assembly, Stop light control relay, Relay
    HORN - Horn system, Horn, Relay
    EXTERIOR PANELS / TRIM - Front bumper, Rear bumper, Rear spoiler, Radiator grille, Name plate, Front door belt moulding, Rear door belt moulding, Rocker panel moulding, Front door window frame moulding, Rear door window frame moulding, Roof drip side finish moulding, Back door garnish, Front pillar upper cover
    ELECTRICAL WIRING DIAGRAM
    COOLING FAN, ENGINE CONTROL, LANE KEEPING ASSIST, CHARGING, DOUBLE LOCKING, ENTRY AND START SYSTEM, ABS, TRC, VSC, EPS, AIR CONDITIONER, POWER HEATER, POWER SEAT, SEAT BELT WARNING, SRS, ENGINE IMMOBILISER SYSTEM, CRUISE CONTROL, AUDIO SYSTEM, HEADLIGHT, PARKING ASSIST, SEAT HEATER, POWER WINDOW, STOP LIGHT, COMMUNICATION SYSTEM and others
    BODY REPAIR
    BODY PANEL REPLACEMENT, BODY DIMENSIONS, PAINT, COATING
    OTHER INFORMATION
    TOYOTA-AVENSIS-MODELS-DIESEL-SERVICE-REPAIR-MANUAL-UPDATE-2015.jpg TOYOTA-AVENSIS-MODELS-DIESEL-SERVICE-REPAIR-MANUAL-UPDATE-2015-.jpg TOYOTA-AVENSIS-MODELS-DIESEL-SERVICE-REPAIR-MANUAL-UPDATE-2015-2.jpg TOYOTA-AVENSIS-MODELS-DIESEL-SERVICE-REPAIR-MANUAL-UPDATE-2015-3.jpg TOYOTA-AVENSIS-MODELS-DIESEL-SERVICE-REPAIR-MANUAL-UPDATE-2015-1.jpg
    #1 hakota, Sep 11, 2015
  2. Christopher
    Christopher New Member
    Jun 8, 2015
    111
    14
    Thanks for sharing
  3. Shana G. Hale
    Shana G. Hale New Member
    Sep 20, 2016
    58
    Wow i need it
  4. Douglas N. Slayton
    Douglas N. Slayton New Member
    Sep 20, 2016
    75
    thank you verry much
  5. rene allan zangger
    rene allan zangger New Member
    Dec 31, 2017
    3
    Have eny of you resived a link in your email
  6. HerculesCraven
    HerculesCraven Super Moderators
    Jan 9, 2016
    666
    13
    We send link for you at 8:33 2/1/2018
    Please check mail?????
    nguyendinhngoc likes this.
  7. rene allan zangger
    Dec 31, 2017
    3
    I never got the link in the mail.
  8. HerculesCraven
    Jan 9, 2016
    666
    13
    What is your email?
    We think you need check spam mail, thanks
  9. rene allan zangger
    Dec 31, 2017
    3
    Done all that, still no link. My mail is : moensguld@get2net.dk
  10. HerculesCraven
    Jan 9, 2016
    666
    13
    What is your Facebook?
    We will send link download for you on Facebook, ok?
    Thanks
Share This Page
