• YouTube
  • Facebook
  • Twitter
  • Google +
CAR & TRUCK LEXUS RX350-RX270 SERVICE & REPAIR MANUAL UPDATE 2015
Discussion in 'Service and Repair Manuals' started by Global Master, Sep 8, 2015.
  1. Global Master
    Global Master Vip Member
    Jun 6, 2015
    118
    16
    LEXUS RX350 / RX270 SERVICE & REPAIR INFORMATION MANUAL UPDATE 2015
    Description :
    Brand:Lexus
    Product Code: Lexus
    Availability: In Stock
    Update : 03.2012 -->2015
    Region : All Regions
    Quantity of Files : 1 CD
    Lexus RX350 / RX270 Service information library 03.2012 - up
    GGL15, AGL10 series
    Engines:
    2GR-FE - 3.5L V6 24 Valve DOHC Dual VVT-i
    1AR-FE - 2.7L 4 cylinder 16 Valve DOHC Dual VVT-i
    Features :
    New car features
    Electrical wiring diagram
    Body Repair
    Service data sheet
    REPAIR MANUAL
    ENGINE CONTROL SYSTEM
    1AR-FE - SFI system, Ignition system, Camshaft oil control valve, Throttle body, ECM, Mass Air flow meter, Camshaft position sensor, Crankshaft position sensor, Ignition coil and spark plug, Engine coolant temperature sensor, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Relay
    2GR-FE - SFI system, Ignition system, Camshaft oil control valve, Throttle body, Vacuum switching valve, Active control engine mount, ECM, Accelerator pedal, Mass Air flow meter, Camshaft position sensor, Crankshaft position sensor, Ignition coil and spark plug, Engine coolant temperature sensor, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Relay
    ENGINE MECHANICAL
    1AR-FE - Engine, Drive Belt, Camshaft, Cylinder head gasket, Front crankshaft oil seal, Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
    2GR-FE - Engine, Drive Belt, Camshaft, Cylinder head gasket, Front crankshaft oil seal, Rear crankshaft oil seal, Engine assembly, Engine unit, Cylinder head, Cylinder block
    FUEL
    1AR-FE - Fuel system, Fuel injector, Fuel pressure regulator,Fuel pressure pulsation damper, Fuel pump, Fuel tank, Fuel sender gauge assembly
    2GR-FE - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pump, Fuel pump resistor, Fuel tank, Fuel sender gauge assembly
    EMISSION CONTROL
    1AR-FE - Emission control system, Canister, Purge valve, Fuel tank cap, PCV valve
    2GR-FE - Emission control system, Canister, Purge valve, Fuel tank cap, PCV valve
    INTAKE / EXHAUST
    1AR-FE - Intake system, Intake manifold, Intake air control valve actuator, Intake air control valve, Vacuum switching valve, Exhaust manifold, Exhaust pipe
    2GR-FE - Intake system, Intake manifold, Intake air control valve, Vacuum tank, Vacuum switching valve, Exhaust manifold, Exhaust pipe
    COOLING
    1AR-FE - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan ECU, Radiator, Relay
    2GR-FE - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan ECU, Radiator, Relay
    LUBRICATION
    1AR-FE - Lubrication system, Oil and Oil filter, Oil pressure switch, Oil pump, Engine oil cooler
    2GR-FE - Lubrication system, Oil and Oil filter, Oil pressure switch, Oil level sensor, Oil pump, Engine oil cooler
    STARTING
    1AR-FE - Starting system, Starter, Engine switch, Relay
    2GR-FE - Starting system, Starter, Engine switch, Relay
    CRUISE CONTROL - Cruise control system, Dynamic Radar cruise control system, Main switch, Driving support ECU, Millimeter wave radar sensor
    Drivetrain
    U660F AUTOMATIC TRANSMISSION / TRANSAXLE - Automatic transaxle system, Fluid, Speed sensor, ATF temperature sensor, Transmission wire, Valve body assembly, Park/Neutral position switch, Oil cooler, Shift lever, Shift paddle switch, Transmission control cable, Differential oil seal, Transaxle assembly, Transaxle unit, Torque converter clutch and drive plate, TCM, Oil pump, Differential case
    U760E AUTOMATIC TRANSMISSION / TRANSAXLE - Automatic transaxle system, Fluid, Speed sensor, Transmission wire, Valve body assembly, Park/Neutral position switch, Shift lever, Transmission control cable, Differential oil seal, Transaxle assembly, Transaxle unit, Torque converter clutch and drive plate, TCM, Oil pump, Differential case
    MF1A transfer / 4WD / AWD - Active torque control 4WD system, Transfer system, Transfer oil, Case front oil seal, Case rear oil seal, Transfer assembly, 4WD control switch, 4WD control ECU
    DRIVE SHAFT / PROPELLER SHAFT - Drive shaft system, Front drive shaft assembly, Rear drive shaft assembly, Propeller shaft system
    AXLE AND DIFFERENTIAL - Axle system, Front axle hub bolt, Front axle hub, Steering knuckle, Rear axle hub bolt, Rear axle hub, Rear axle carrier, Differential system, Differential oil, Differential carrier oil seal, Differential carrier assembly, Differential mount cushion
    SUSPENSION CONTROL - Air suspension system, Suspension control system, Height control compressor, Pneumatic tank, Control valve assembly, Height control sensor, Suspension control ECU, Absorber control ECU, Height control switch
    ALIGNMENT / HANDLING DIAGNOSIS - Front / Rear wheel alignment
    FRONT SUSPENSION - Front suspension system, Performance damper, Front shock absorber, Front lower suspension arm, Front lower ball joint, Front stabilizer bar, Front suspension member
    REAR SUSPENSION - Rear suspension system, Performance damper, Rear shock absorber, Rear coil spring, Rear pneumatic cylinder, Rear upper arm, Rear lower arm, Rear trailing arm, Rear stabilizer bar, Rear suspension member
    TIRE / WHEEL - Tire and wheel system
    BRAKE CONTROL / DYNAMIC CONTROL SYSTEMS - Vehicle stability control system, Brake actuator, Front / Rear speed sensor, Yaw rate and acceleration sensor, Steering angle sensor, Skid control buzzer, VSC off switch, Brake pedal load sensing switch
    BRAKE SYSTEM - Brake system, Brake line, Brake fluid, Brake pedal, Brake master cylinder, Brake booster
    REAR / FRONT BRAKE - Front / Rear brake, Front / Rear brake flexible hose
    PARKING BRAKE - Parking brake system, Parking brake pedal, Parking brake cable, Parking brake switch, Parking brake assembly
    POWER ASSIST SYSTEMS - Power steering system, Power steering ECU
    STEERING COLUMN - Power tilt and power telescopic steering column system, Steering lock system, Heated steering wheel system, Steering system, Steering column assembly, Steering wheel, Multiplex tilt and telescopic ECU, Tilt and telescopic manual switch, Heated steering wheel controller
    STEERING GEAR / LINKAGE - Steering gear
    Audio / Visual / Telematics
    AUDIO / VIDEO - Audio and visual system, Rear seat entertainment system, Radio receiver, Stereo component amplifier, Luggage speaker, Front door speaker, Rear door speaker, Instrument panel speaker, Rear package tray speaker, Television display, Radio antenna cord, Amplifier antenna, Stereo jack adapter assembly, Rear seat entertainment ECU, Microphone, Window glass antenna wire, Digital audio broadcasting antenna, Noise filter
    NAVIGATION / MULTI INFO DISPLAY - Navigation system, Navigation receiver, Multi display, Hard disk drive, Remote touch, Navigation antenna
    G-BOOK - G-Book system, Telematics transceiver, Telephone antenna, Mayday battery, Mayday switch
    PARK ASSIST/ MONITORING - Lexus parking assist system, Parking assist monitor system, Side monitor system, Rear view monitor system, Clearance warning ECU, Clearance warning buzzer, Ultrasonic sensor, Television camera, Parking assist ECU
    Power source / Network
    BATTERY / CHARGING - Battery, Battery thermometer sensor
    POWER DISTRIBUTION - Main body ECU, Power management control ECU, Integration relay
    NETWORKING - LIN communication system, CAN communication system
    Vehicle Interior
    DOOR LOCK - Power door lock control system, Wireless door lock control system, Transmitter battery, Door control transmitter, Door control switch, Front / Rear door lock, Back door lock, Door control receiver, Wireless door lock buzzer, Door control relay
    THEFT DETERRENT / KEYLESS ENTRY - Entry and start system, Engine immobiliser system, Theft deterrent system, Blocking system, Intrusion sensor, Electrical key oscillator, Entry lock and unlock switch, Engine hood courtesy switch, Security horn assembly, Security indicator light assembly
    LIGHTING - Lighting system, Vanity light, Personal light, Room light, Luggage compartment room light, Door courtesy light, Glove box light, Console box light, Footwell light, Scuff plate light, Front / Rear / Back door courtesy switch
    METER / GAUGE / DISPLAY - Meter / Gauge system, Clock system, Combination meter, Accessory meter, Headup display, Light control rheostat, Satellite switch
    MIRROR - Inner rear view mirror
    SUPPLEMENTAL RESTRAINT SYSTEMS - Airbag system, Steering pad, Spiral cable, Knee airbag assembly, Front passenger airbag assembly, Curtain shield airbag assembly, Front seat side airbag assembly, Rear seat side airbag assembly, Center airbag sensor assembly, Front airbag sensor, Side airbag sensor, Rear airbag sensor, Seat position sensor, Airbag cut-off switch
    PRE-CRASH SAFETY - Pre-crash safety system, Pre-crash brake cancel switch, Seat belt control ECU
    SEAT - Front power seat control system, Seat heater system, Climate control seat system, Front seat assembly, Rear seat assembly, Seat memory switch, Power seat switch, Lumbar switch, Seat variable cushion switch, Seat heater switch, Front seatback heater, Front seat cushion heater, Seat heater control
    SEAT BELT - Seat belt tension reducer system, Seat belt warning system, Front passenger seat belt warning light, Occupant detection sensor, Front seat inner belt assembly, Front seat outer belt assembly, Rear seat inner belt assembly, Rear seat outer belt assembly, Rear center seat inner belt assembly, Rear center seat outer belt assembly
    HEATING / AIR CONDITIONING - Air conditioning system, Refrigerant, Refrigerant line, Air conditioning unit, Blower unit, Front blower motor, Compressor, Condenser, Room temperature sensor, Ambient temperature sensor, Front evaporator temperature sensor, Solar sensor, Smog ventilation sensor, Air conditioning pressure sensor, Air conditioning panel, Air conditioning amplifier
    POWER OUTLETS - Power outlet socket, Rear power outlet socket
    INTERIOR PANELS / TRIM - Roof sunshade system, Instrument panel safety pad, Front console box, Roof sunshade, Roof sunshade switch
    Vehicle Exterior
    WINDOW / GLASS - Power window control system, Power window master switch, Front passenger side power window switch, Rear power window switch, Power window regulator motor, Windshield glass, Front side fix window glass, Back door glass, Roof window fix glass, Windshield deicer system, Window defogger system, Windshield deicer switch, Window defogger wire, Quarter window glass, Relay
    SLIDING ROOF / CONVERTIBLE - Sliding roof system, Sliding roof housing, Sliding roof switch assembly
    DOOR / HATCH - Back door closer system, Power back door system, Fuel lid opener system, Hood, Hood support, Hood lock control cable assembly, Front door, Rear door, Back door, Back door opener switch, Power back door main switch, Power back door control switch, Power back door closer switch, Power back door touch sensor, Power back door drive unit, Back door support, Fuel lid opener motor assembly, Fuel lid opener switch, Relay
    MIRROR - Power mirror control system, Outer rear view mirror, Outer mirror switch, Outer mirror control ECU
    WIPER / WASHER - Wiper and washer system, Front wiper motor, Rear wiper motor, Front / Rear wiper rubber, Wiper switch, Washer motor, Washer nozzle, Washer level warning switch, Headlight cleaner actuator, Headlight cleaner switch, Headlight cleaner motor, Rain sensor, Relay
    LIGHTING - Lighting system, Headlight assembly, High intensity discharge headlight bulb, Fog light assembly, Rear fog light assembly, Side turn signal light assembly, Rear combination light assembly, Rear light assembly, Licence plate light, High mounted stop light, Headlight dimmer switch, Hazard warning switch, Stop light switch, Automatic light control sensor, AFS ECU, Height control sensor, Turn signal flasher assembly, Stop light control relay, Relay
    HORN - Horn system, Low pitched horn, High pitched horn, Relay
    EXTERIOR PANELS / TRIM - Front bumper, Rear bumper, Rear spoiler, Radiator grille, Name plate, Mudguard, Roof rack, Front door belt moulding, Rocker panel moulding, Side moulding, Front door window frame moulding, Rear door window frame moulding, Roof drip side finish moulding, Quarter panel wheel opening moulding, Back door outside garnish, Rear wheel house plate
    NEW CAR FEATURES
    Engine - ENGINE CONTROL, ENGINE MECHANICAL, FUEL, EMISSION CONTROL, INTAKE / EXHAUST, COOLING, CRUISE CONTROL, LUBRICATION
    Drivetrain - TRANSMISSION / TRANSAXLE, DRIVE SHAFT / PROPELLER SHAFT, AXLE AND DIFFERENTIAL
    Suspension - AIR SUSPENSION SYSTEM, FRONT / REAR SUSPENSION, TIRE / WHEEL
    Brake - BRAKE CONTROL SYSTEM, BRAKE SYSTEM, FRONT / REAR BRAKE, PARKING BRAKE
    Steering - POWER STEERING SYSTEM, STEERING COLUMN, HEATED STEERING WHEEL SYSTEM
    Audio/Visual/Telematics - AUDIO/ VISUAL SYSTEM, NAVIGATION / MULTI INFO DISPLAY, G-BOOK, PARKING ASSIST / MONITORING
    Power Source, Network - ELECTRIC POWER CONTROL, NETWORKING
    Vehicle Interior, Vehicle Exterior - DOOR LOCK, ENTRY AND START SYSTEM, THEFT DETERRENT, AIRBAG SYSTEM, LIGHTING, METER / GAUGE / DISPLAY, SUPPLEMENTAL RESTRAINT SYSTEM, SEAT, HEATING / AIR CONDITIONING,
    WINDOW / GLASS, SLIDING ROOF, DOOR / HATCH, MIRROR, WIPER / WASHER, LIGHTING, EXTERIOR PANELS / TRIM
    ELECTRICAL WIRING DIAGRAM
    COOLING FAN, IGNITION, SHIFT LOCK, AIR SUSPENSION, TIRE PRESSURE WARNING SYSTEM, VEHICLE DYNAMICS INTEGRATION MANAGEMENT, EPS, POWER TILT AND POWER TELESCOPIC, AUDIO SYSTEM, PARKING ASSIST, SAFETY CONNECT, MULTIPLEX COMMUNICATION, POWER SOURCE, SRS, HYBRID SYSTEM, LIGHT and others
    BODY REPAIR
    INTRODUCTION, BODY PANEL REPLACEMENT, BODY DIMENSIONS, PAINTING / COATING
    OTHER INFORMATION
    LEXUS-RX350-RX270-SERVICE-REPAIR-MANUAL-UPDATE-2015-1.jpg LEXUS-RX350-RX270-SERVICE-REPAIR-MANUAL-UPDATE-2015-2.jpg LEXUS-RX350-RX270-SERVICE-REPAIR-MANUAL-UPDATE-2015-3.jpg LEXUS-RX350-RX270-SERVICE-REPAIR-MANUAL-UPDATE-2015-4.jpg
    Donate beer to download this manuals :http://dhtauto.com/payment-paypal/
  2. lavenue
    lavenue Donate
    Sep 18, 2015
    78
    3
    thank for your post
  3. JaPjr
    JaPjr New Member
    Oct 15, 2016
  4. Irene J. Barth
    Irene J. Barth Moderator
    Sep 20, 2016
    91
    thank for your post
Share This Page
