• YouTube
  • Facebook
  • Twitter
  • Google +
CAR & TRUCK LEXUS IS350 / IS300 / IS250 / IS220D / IS200D SERVICE & REPAIR MANUAL Update 2015
Discussion in 'Service and Repair Manuals' started by Global Master, Sep 8, 2015.
  1. Global Master
    Global Master Vip Member
    Jun 6, 2015
    118
    15
    LEXUS IS350 / IS300 / IS250 / IS220D / IS200D SERVICE & REPAIR INFORMATION MANUAL Update 2015
    Brand: Lexus
    Product Code: Lexus
    Availability: In Stock
    Update : 08.2010 --> 2015
    Market : All Regions
    Lexus IS350 / IS300 / IS250 / IS220D / IS200D Service information library 08.2010 - up
    New car features
    Electrical wiring diagram
    Body Repair
    Service data sheet
    LEXUS-IS350-IS300-IS250-IS220D-IS200D-SERVICE-REPAIR-INFORMATION-MANUAL-Update-2015.jpg
    ALE20, GSE20, GSE21, GSE22 series
    Engines:
    2GR-FSE - 3.5L 24-Valve DOHC V6
    3GR-FE - 3.0L 24-Valve DOHC V6
    4GR-FSE - 2.5L 24-Valve DOHC V6
    2AD-FHV - 2.2L 4cylinder 16-Valve DOHC D-4D D-CAT
    2AD-FTV - 2.2L 4cylinder 16-Valve DOHC D-4D
    REPAIR MANUAL
    Engine control system
    2AD-FHV - ECD system, Diesel throttle body, ECM, Accelerator pedal, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Manifold absolute pressure sensor, EFI relay, EDU relay
    2AD-FTV - ECD system, Diesel throttle body, ECM, Accelerator pedal, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Manifold absolute pressure sensor, Air fuel ratio sensor, EFI relay, EDU relay
    3GR-FE - SFI system, Camshaft oil control valve, Throttle body, ECM, Accelerator pedal, Mass air flow meter, VVT sensor, Crankshaft position sensor, Engine coolant temperature sensor, Knock sensor, Integration relay, Fuel pump relay
    2GR-FSE - SFI system, Camshaft oil control valve, Throttle body, ECM, Accelerator pedal, Mass air flow meter, VVT sensor, Crankshaft position sensor, Engine coolant temperature sensor, Knock sensor, Air fuel ratio sensor, Heated oxygen sensor, Integration relay, Fuel pump relay
    4GR-FSE - SFI system, Camshaft oil control valve, Throttle body, ECM, Accelerator pedal, Mass air flow meter, VVT sensor, Crankshaft position sensor, Engine coolant temperature sensor, Knock sensor, Integration relay, Fuel pump relay
    Engine mechanical
    2AD-FHV - Engine, Drive belt, Front/Rear crankshaft oil seal, Engine assembly, Engine unit
    2AD-FTV - Engine, Drive belt, Camshaft, Cylinder head gasket, Cylinder head, Cylinder block, Front/Rear crankshaft oil seal, Engine assembly, Engine unit
    3GR-FE - Engine, Drive belt, Front/Rear crankshaft oil seal, Engine assembly, Engine unit
    2GR-FSE - Engine, Drive belt, Camshaft, Cylinder head gasket, Cylinder head, Cylinder block, Front/Rear crankshaft oil seal, Engine assembly, Engine unit
    4GR-FSE - Engine, Drive belt, Front/Rear crankshaft oil seal, Engine assembly, Engine unit
    Fuel
    2AD-FHV - Fuel system, Fuel injector, Fuel supply pump, Common rail, Fuel filter, Injector driver, Fuel pump, Fuel tank, Fuel sender gauge assembly, Fuel tank solenoid return valve
    2AD-FTV - Fuel system, Fuel injector, Fuel supply pump, Fuel pressure regulator, Common rail, Fuel filter, Injector driver, Fuel pump, Fuel tank, Fuel sender gauge assembly, Fuel sedimenter warning switch, Fuel tank solenoid return valve
    3GR-FE - Fuel system, Fuel injector, Fuel pressure pulsation damper, Fuel pump, Fuel pump resistor, Fuel tank, Fuel sender gauge assembly
    2GR-FSE - Fuel system, Fuel injector, Fuel pressure regulator, Fuel pressure pulsation damper, Fuel relief valve, Injector driver, Fuel pump, Fuel pump resistor, Fuel tank, Fuel sender gauge assembly
    4GR-FSE - Fuel system, Fuel injector, Cold start injector, Fuel pressure pulsation damper, Fuel pressure sensor, Fuel relief valve, Injector driver, Fuel pump, Fuel pump resistor, Fuel tank, Fuel sender gauge assembly
    Emission Control
    2AD-FHV - Emission control system, EGR valve, EGR cooler, Exhaust gas temperature sensor, Exhaust fuel addition injector, Exhaust manifold converter, Differential pressure sensor, Vacuum regulating valve, Air fuel ratio sensor, Fuel tank cap
    2AD-FTV - Emission control system, EGR valve, EGR cooler, Exhaust gas temperature sensor, Exhaust fuel addition injector, Exhaust manifold converter, Differential pressure sensor, Vacuum regulating valve, Fuel tank cap
    3GR-FE - Emission control system, Canister, Purge valve, PCV valve, Air fuel ratio sensor, Heated oxygen sensor
    2GR-FSE - Emission control system, Canister, Purge valve, PCV valve, Fuel tank cap
    4GR-FSE - Emission control system, Canister, Purge valve, PCV valve, Air fuel ratio sensor, Heated oxygen sensor
    Intake / Exhaust
    2AD-FHV - Intake system, Turbocharger, Intercooler, Exhaust pipe
    2AD-FTV - Intake system, Intake manifold, Turbocharger, Intercooler, Exhaust manifold, Exhaust pipe
    3GR-FE - Intake system, Exhaust pipe, Exhaust manifold, Exhaust pipe
    2GR-FSE - Intake system, Intake manifold, Exhaust manifold, Exhaust pipe
    4GR-FSE - Intake system, Exhaust pipe
    Cooling
    2AD-FHV - Cooling system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan relay, Radiator
    2AD-FTV - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan relay, Radiator
    3GR-FE - Cooling system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan relay, Radiator
    2GR-FSE - Cooling system, Cooling fan system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan relay, Radiator
    4GR-FSE - Cooling system, Coolant, Water pump, Thermostat, Cooling fan motor, Cooling fan relay, Radiator
    Lubrication
    2AD-FHV - Lubrication system, Oil filter, Oil pump, Engine oil cooler
    2AD-FTV - Lubrication system, Oil and oil filter, Oil pressure switch, Oil level sensor, Oil pump, Engine oil cooler
    3GR-FE - Lubrication system, Oil filter, Oil pump
    2GR-FSE - Lubrication system, Oil and oil filter, Oil pressure switch, Oil level sensor, Oil pump
    4GR-FSE - Lubrication system, Oil filter, Oil pump
    Ignition
    3GR-FE - Ignition system, Ignition coil and spark plug
    2GR-FSE - Ignition system, Ignition coil and spark plug
    4GR-FSE - Ignition system, Ignition coil and spark plug
    Starting
    2AD-FHV - Starting system, Pre-heating system, Entry and start system, Glow plug, Starter, Starter relay, Starter cut relay, Glow relay, Engine switch
    2AD-FTV - Starting system, Pre-heating system, Entry and start system, Glow plug, Starter, Starter relay, Starter cut relay, Glow relay, Engine switch
    3GR-FE - Starting system, Entry and start system, Starter, Starter relay, Starter cut relay, Engine switch
    2GR-FSE - Starting system, Entry and start system, Starter, Starter relay, Starter cut relay, Engine switch
    4GR-FSE - Starting system, Entry and start system, Starter, Starter relay, Starter cut relay, Engine switch
    Charging
    2AD-FHV - Charging system, Generator, Battery current sensor, Battery thermometer sensor
    2AD-FTV - Charging system, Generator, Battery current sensor, Battery thermometer sensor
    3GR-FE - Charging system, Generator
    2GR-FSE - Charging system, Generator, Battery current sensor, Battery thermometer sensor
    4GR-FSE - Charging system, Generator, Battery current sensor, Battery thermometer sensor
    Transmission
    A760E Automatic transmission - Automatic transmission system, Extension housing rear oil seal, Speed sensor, Transmission wire, Park / Neutral position switch, Valve body assembly, Shift lock system, Transmission control switch, Shift paddle switch, Pattern select switch, Shift lever assembly, Automatic transmission assembly, Torque converter and drive plate, Transmission unit, Oil pump, Clutch drum and input shaft assembly, Shift solenoid valve
    A960E Automatic transmission - Automatic transmission system, Extension housing rear oil seal, Speed sensor, Transmission wire, Park / Neutral position switch, Valve body assembly, Shift lock system, Transmission control switch, Shift paddle switch, Pattern select switch, Shift lever assembly, Automatic transmission assembly, Torque converter and drive plate, Transmission unit, Oil pump, Clutch drum and input shaft assembly, Shift solenoid valve
    Clutch - Clutch system, Clutch pedal, Master cylinder, Release cylinder, Clutch accumulator, Clutch unit, Pedal switch
    RA63 manual transmission - Manual transmission system, Oil, Transmission unit, Input shaft, Output shaft, Counter gear
    Drive Line
    Propeller Shaft - Propeller shaft system, Propeller shaft assembly
    Drive Shaft - Drive shaft system, Rear drive shaft assembly
    Differential - Differential system, Differential oil, Differential side gear shaft oil seal, Differential carrier assembly, Mount cushion
    Suspension & Axle
    Axle - Axle system, Front axle hub bolt, Front axle hub, Steering knuckle, Rear axle hub bolt, Rear axle hub
    Suspension - Suspension system, Front wheel alignment, Rear wheel alignment, Front shock absorber, Front upper suspension arm, Front lower suspension arm, Front lower ball joint, Front stabilizer bar, Rear shock absorber, Rear upper No1 control arm, Rear upper No2 control arm, Rear No1 suspension arm, Rear No2 suspension arm, Toe control link, Rear stabilizer bar
    Tire and Wheel - Tire and wheel system, Tire repair seal
    Brake Control - Stop light control relay, Vehicle stability control system, Brake actuator, Front speed sensor, Rear speed sensor, Yaw rate and acceleration sensor, Steering angle sensor, Skid control buzzer, VSC off switch, Brake pedal load sensing switch
    Brake - Brake system, Fluid, Brake pedal, Master cylinder, Brake booster, Vacuum pump, Front brake, Front brake flexible hose, Rear brake, Rear brake flexible hose
    Parking Brake - Parking brake system, Parking brake lever, Brake pedal, Parking brake cable, Parking brake assembly
    Steering Column - Steering system, Power tilt and power telescopic steering column system, Steering lock system, Steering column assembly, Multiplex tilt and telescopic ECU
    Power Steering - Power steering system, Steering gear, Power steering ECU
    Heater & Air Conditioning system
    Air Conditioning - Air conditioning system, Refrigerant, Refrigerant line, Air conditioning unit, Blower unit, Compressor, Condenser, Room temperature sensor, Ambient temperature sensor, Front evoporator temperature sensor, Smog ventilation sensor, Pressure switch, Heater glow plug, Water hose joint, Air conditioning panel, Air conditioning amplifier
    Heater - Combustion type power heater system, Heater switch, Heater assembly, Heater exhaust pipe, Heater fuel pump
    Restraints
    Pre-crash safety system - Pre-crash safety system, Seat belt control ECU
    Supplemental Restraint System - Airbag system, Steering pad, Spiral cable, Driver side knee airbag assembly, Front passenger side knee airbag assembly, Front passenger airbag assembly, Curtain shield airbag, Front seat side airbag, Center airbag sensor, Front airbag sensor, Side airbag sensor, Rear airbag sensor, Seat position sensor, Airbag cut-off switch
    Seat Belt - Occupant detection sensor, Seat belt tension reducer, Seat belt warning system, Front seat inner belt assembly, Front seat outer belt assembly, Rear seat inner belt, Rear seat outer belt, Togue plate stopper, Child restraint seat tether anchor, Child restraint seat anchor bracket
    Securities
    Theft Deterrent - Theft deterrent system, Engine hood courtesy switch, Security horn assembly
    Engine Immobiliser - Engine immobiliser system
    Cruise Control System
    Cruise Control - Distance control ECU, Millimeter wave radar sensor, Cruise control, Dynamic radar cruise control system, Cruise control main switch, Clutch switch
    Body Electrical
    Lighting, Wiper and Washers, Door Lock, Meter, Audio / Visual, Navigation, G-Book, Park Assit / Monitoring, Horn, Clock, Power outler socket
    Body
    Windshield / Windowglass, Mirror, Instrument Panel, Seat, Engine Hood / Door, Exterior, Interior, Sliding Roof
    Communication System
    CAN communication system, Multiplex communication system
    NEW CAR FEATURES
    New model outline, Engines, Chassis, Body, Body electrical, Technical specifications
    ELECTRICAL WIRING DIAGRAM
    Engine - Charging, Engine control, Cooling fan, Entry and Start system, Ignition
    Transmission - ECT and A/T indicator, Shift lock
    Brake - ABS, TRS, VSC, Vehicle Dynamics integrated management
    Steering - EPS, Power tilt and power telescopic
    Heater & Air Conditioner System - Air conditioner, Power heater
    Restraints - Seat belt warning, SRS, Electric tension reducer, Pre-crash safety system
    Securities - Blocking system, Theft deterrent
    Cruise Control System - Cruise control, Dynamic radar cruise control
    Body Electrical - Audio system, Automatic light control, Back-up light, Cigarette lighter, Front fog light, Headlight, Interior light, Stop light, Navigation system, G-Book, Wireless door lock control and much much more
    Body - Automatic Glare-Resistant EC mirror, Climate control seat, Front window deicer, Mirror heater, Power heater, Power seats, Power windows, Rear sunshade, Rear window defogger, Remote control mirror, Seat heater, Sliding roof
    Communication System - Multiplex communication system
    BODY REPAIR
    OTHER INFORMATION
    LEXUS-IS350-IS300-IS250-IS220D-IS200D-SERVICE-REPAIR-INFORMATION-MANUAL-Update-2015-1.jpg LEXUS-IS350-IS300-IS250-IS220D-IS200D-SERVICE-REPAIR-INFORMATION-MANUAL-Update-2015-2.jpg LEXUS-IS350-IS300-IS250-IS220D-IS200D-SERVICE-REPAIR-INFORMATION-MANUAL-Update-2015-3.jpg LEXUS-IS350-IS300-IS250-IS220D-IS200D-SERVICE-REPAIR-INFORMATION-MANUAL-Update-2015-4.jpg
    Donate beer to download this manuals :http://dhtauto.com/payment-paypal/
    #1 Global Master, Sep 8, 2015
  2. lavenue
    lavenue Donate
    Sep 18, 2015
    78
    thank for sharing
Share This Page
