1,425
229
Lexus IS250 / IS220D Service Information Library [2005 - 2008]
08.2005 - 07.2008 / All Regions / 1 CD / Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP / 32 & 64 bit
Lexus IS250 / IS220D 2005 - 2008 Service information library
GSE20, ALE20 series
Engines:
2AD-FHV 2.2L D-4D 16-Valve DOHC
4GR-FSE 2.5L D-4 24-Valve DOHC V6 Dual VVT-i
New car features
Electrical wiring diagram
Body Repair
Service data sheet
REPAIR MANUAL
ENGINE
ENGINE CONTROL SYSTEM
2AD-FHV - ECD system, Mass air flow meter, Camshaft position sensor, Crankshaft position sensor, Engine coolant temperature sensor, Intake air temperature sensor, Diesel throttle body, EFI relay, EDU relay, ECM, Manifold absolute pressure sensor, Accelerator pedal,
4GR-FSE - SFI system, Mass air flow meter, Camshaft timing oil control valve assembly, VVT sensor, Crankshaft position sensor, Engine coolant temperature sensor, Throttle body, Knock sensor, Integration relay, Fuel pump relay, ECM, Accelerator pedal
ENGINE MECHANICAL
2AD-FHV - Engine, Drive belt, Engine front oil seal, Engine rear oil seal, Engine assembly, Engine unit
4GR-FSE - Engine, Drive belt, Engine front oil seal, Engine rear oil seal, Engine assembly, Engine unit
FUEL
2AD-FHV - Fuel system, Fuel injector, Fuel supply pump, Common rail, Fuel filter, Injector driver, Fuel pump, Fuel tank
4GR-FSE - Fuel system, Fuel injector, Fuel pressure pulsation damper, Fuel pressure sensor, Injector driver, Fuel pump, Fuel pump resistor, Fuel tank
EMISSION CONTROL
2AD-FHV - Emission control system, EGR valve, EGR cooler, Exhaust fuel addition injector, Exhaust manifold converter, Vaccum switching valve, Air fuel ratio sensor, Differential pressure sensor, Exhaust gas temperature sensor, Fuel tank cap
4GR-FSE - Emission control system, Canister, Vacuum switching valve, Ventilation valve, Air fuel ratio sensor, Heated oxygen sensor
INTAKE / EXHAUST
2AD-FHV - Intake air control system, Turbocharger, Vacuum regulating valve, Intercooler, Exhaust pipe
4GR-FSE - Intake system, Exhaust pipe
COOLING
2AD-FHV - Cooling system, Coolant, Water pump, Thermostat, Radiator, Fan motor, Fan relay
4GR-FSE - Cooling system, Coolant, Water pump, Thermostat, Radiator, Fan motor, Fan relay
LUBRICATION
2AD-FHV - Lubrication system, Oil filter, Oil pump, Engine Oil cooler
4GR-FSE - Lubrication system, Oil filter, Oil pump
IGNITION
4GR-FSE - Ignition system, Ignition coil
STARTING
2AD-FHV - Starting system, Pre-heating system, Entry and start system, Glow plug, Starter, Starter relay, Glow relay, Engine switch
4GR-FSE - Starting system, Entry and start system, Starter, Starter relay, Starter cut relay, Engine switch
CHARGING
2AD-FHV - Charging system, Generator, Battery current sensor, Battery thermometer sensor
4GR-FSE - Charging system, Generator, Battery current sensor, Battery thermometer sensor
TRANSMISSION
A960E AUTOMATIC TRANSMISSION - Automatic transmission system, Fluid, Extension housing rear oil seal, Speed sensor, Transmission wire, Park/Neutral position switch, Valve body assembly, Shift lock system, Transmission control switch, Shift paddle awitch, Pattern select switch, Shift lever assembly, Automatic transmission assembly, Torque converter and drive plate, Transmission unit, Oil pump, Clutch drum and input shaft assembly, Shift solenoid valve
CLUTCH - Clutch system, Clutch pedal, Clutch master cylinder, Clutch release cylinder, Clutch accumulator, Clutch unit, Clutch start switch
RA62 MANUAL TRANSMISSION - Manual transmission system, Oil, Transmission extension housing oil seal, Transmission unit, Transmission assembly, Input shaft, Output shaft, Counter gear and reverse idler gear
RA63 MANUAL TRANSMISSION - Manual transmission system, Oil, Transmission assembly, Transmission unit, Input shaft, Output shaft, Counter gear and reverse idler gear
DRIVE LINE
PROPELLER SHAFT - Propeller shaft system, Shaft assembly
DRIVE SHAFT - Drive shaft system, Rear drive shaft assembly
DIFFERENTIAL - Differential system, Oil, Rear differential side gear shaft oil seal, Rear differential carrier, Mount cushion
SUSPENSION & AXLE
AXLE - Axle system, Front axle hub, Steering knuckle, Rear axle hub
SUSPENSION - Suspension system, Front wheel alignment, Rear wheel alignment, Front shock absorber, Front suspension upper arm, Front lower ball joint, Front suspension lower arm, Front stabilizer bar, Rear shock absorber, Rear upper control arm, Toe control link, Rear suspension arm, Rear stabilizer bar
TIRE AND WHEEL - Tire and wheel system
BRAKE
BRAKE CONTROL - Vehicle stability control system, Brake actuator, Front speed sensor, Rear speed sensor, Yaw rate and acceleration sensor, Steering angle sensor, Skid control ECU, Skid control buzzer, Traction off switch, ABS relay, Stol light control relay, Brake pedal load sensing switch
BRAKE - Brake system, Brake fluid, Brake pedal, Brake master cylinder, Brake booster, Vacuum pump, Front brake, Rear brake, Rear brake flexible hose
PARKING BRAKE - Parking brake system, Parking brake lever, Parking brake cable, Parking brake pedal, Parking brake assembly
STEERING
STEERING COLUMN - Steering system, Power tilt and power telescopic steering column system, Electric steering lock, Steering column assembly, Multiplex tilt and telescopic ECU
POWER STEERING - Power steering system, Electronic power steering system, Power steering gear, ECU
HEATER & AIR CONDITIONING SYSTEM
AIR CONDITIONING - Air conditioning system, Refrigerant, Refrigerant line, Air conditioning unit, Blower unit, Compressor and magnetic clutch, Compressor and pulley, Condenser, Room temperature sensor, Ambient temperature sensor, Evaporator temperature sensor, Pressure switch, Heater glow plug, Water hose joint, Integration control and panel, Air conditioning amplifier
HEATER - Combustion type power heater system, Heater switch, Heater assembly, Heater exhaust pipe, Heater fuel pump
RESTRAINTS
PRE-CRASH SAFETY - Safety system
SUPPLEMENTAL RESTRAINT SYSTEM - Airbag system, Steering pad, Spiral cable, Driver side knee airbag assembly, Front passenger airbag assembly, Curtain shield airbag assembly, Front seat side airbag assembly, Center airbag sensor assembly, Front airbag sensor, Side airbag sensor, Rear airbag sensor, Seat position sensor, Airbag cut-off switch
SEAT BELT - Occupant detection sensor, Seat belt tension reducer, Seat belt warning system, Front seat inner belt assembly, Front seat outer belt assembly, Rear seat inner belt assembly, Rear seat outer belt assembly, Child restraint seat tether anchor, Belt control ECU
SECURITIES
THEFT DETERRENT - Theft deterrent system, Engine hood courtesy switch, Security horn assembly
ENGINE IMMOBILISER - Engine immobiliser system
CRUISE CONTROL SYSTEM
CRUISE CONTROL - Cruise control system, Dynamic radar cruise control system, Cruise control main switch, Distance control ECU, Millimeter wave radar sensor, Clutch switch
BODY ELECTRICAL
LIGHTING - Lighting system, Headlight assembly, Side turn signal light, Fog light, Rear combination light, Licence plate light, High mounted stop light, Personal lihjt, Rear Room light, Door courtesy light, Luggage compartment room light, Glow box light, Vanity light, Console box light, Scuff plate light, Footwell light, Register illumination, Door mirror foot light, Headlight dimmer, Hazard warning switch, Stop light switch, Front / Rear / Back door courtesy switch, Automatic light control sensor, Height control sensor, AFS ECU, Turn signal flasher assembly, Headlight relay, Taillight relay
WIPER AND WASHER - Wiper and washer system, Front wiper motor, Front wiper rubber, Wiper switch, Washer motor, Washer nozzle, Headlight cleaner actuator, Rain sensor
DOOR LOCK - Power door lock control system, Wireless door lock control system, Entry and start system, Door control transmitter, Door control switch, Front door lock, Rear door lock, Entry lock and unlock switch, Luggage compartment door opener outer switch
METER - Meter / Gauge system, Combination meter, Fuel sender gauge assembly, Engine Oil pressure switch, Engine oil level sensor, Steering pad switch, Light control rheostat, Satellite switch
AUDIO / VISUAL - Audio and visual system, Radio receiver, Stereo component amplifier, Front side speaker, Front center speaker, Rear side speaker, Rear center speaker, Radio antenna cord, Amplifier antenna, Audio terminal, Network gateway ECU, Steering pad switch, Microphone, Window glass antenna wire
NAVIGATION - Navigation system, Multi display, Navigation ECU, Antenna
PARK ASSIST / MONITORING - Clearance sonar system, Parking assist monitor system, Clearance warning ECU, Clearance warning buzzer, Ultrasonic sensor, Television camera, Television camera ECU
HORN - Horn system, Horn relay, High / Low pitched horn
OTHER - Power outlet socket, Cigarette lighter, Clock
BODY
WINDSHIELD / WINDOWGLASS - Power window control system, Power window regulator motor, Windshield glass, Back window glass, Windshield deicer syste, Window defogger system, Windshield deicer relay, Defogger relay
MIRROR - Power mirror control system, Inner rear view mirror, Outer rear view mirror, Mirror heater
INSTRUMENT PANEL - Instrument panel safety pad, Rear console box
SEAT - Front power seat control system, Seat heater system, Climate control seat system, Front seat assembly, Rear seat assembly, Seat memory switch, Power seat switch, Power seat motor, Front power seat lumbar switch, Lumbar support adjuster, Seat heater switch, Front seatback heater, Front seat cushion heater, Seat heater control
ENGINE HOOD / DOOR - Luggage compartment door opener system, Fuel lid opener system, Hood, Hood lock control cable, Front door, Rear door, Luggage compartment door
EXTERIOR - Front bumper, Rear bumper, Name plate, Front / Rear door belt moulding, Roof drip side finish moulding, Rocker panel moulding, Front / Rear door window frame moulding, Luggage compartment door garnish
INTERIOR - Rear sunshade system, Front floor footrest, Rear sunshade assembly, Roof headlining
SLIDING ROOF - Sliding roof system, Sliding roof housing, Sliding roof switch
COMMUNICATION SYSTEM
MULTIPLEX COMMUNICATION SYSTEM
CAN COMMUNICATION SYSTEM
NEW CAR FEATURES
NEW MODEL OUTLINE, EXTERIOR, INTERIOR, ENGINE, CHASSIS, BODY, BODY ELECTRICAL
ELECTRICAL WIRING DIAGRAM
CHARGING, COOLING FAN, ENGINE CONTROL, IGNITION, ENTRY AND START SYSTEM, ECT AND A/T INDICATOR, SHIFT LOCK, ABS, TRC, VSC, EPS, POWER TILT, AIR CONDITIONER, HEATER, SRS, CRUISE CONTROL, AUDIO SYSTEM, INTERIOR LIGHT, HEADLIGHT, FRONT FOG LIGHT, DLC3, NAVIGATION SYSTEM, POWER SEAT, SEAT HEATER, SLIDING ROOF
BODY REPAIR
BODY PANEL REPLACEMENT, BODY DIMENSIONS, PAINT, COATING
OTHER INFORMATION
  • Lexus IS250 IS220D Service Information Library [2005 - 2008].txt
